Buzzing Instrument Cluster
I've found I can pretty much hold anything--flyscreen, instruments, whatever and make it stop. Of course, my screen is a Puig plus and mounts to the headlight shell. Hard to narrow down.
Here is a pic of my 2013 headlight shell
[url=http://s284.photobucket.com/user/everettmclendon/media/20150501_162556_zpscbk1wymy.jpg.html][Image: d6df758ac59871418b9a5422512cb205.jpg]
Notice on the bottom that the red accessory connector just lays on the shell and can vibrate. Also notice at the top, on the bottom back of the bundle also touch the shell. This may be the buzzing.
So here is what I did
[url=http://s284.photobucket.com/user/everettmclendon/media/headlight%202_zpspcav1xkw.jpg.html][Image: beba8ba508c0a2af794cf78e814d45ca.jpg]
I wrapped some foam around the accessory connector, and around the wire bundle at the top. Don't know if it eliminated the buzzing, but it can't hurt.
Now I have to go put the headlight and flyscreen back on.
Yes, I just taped the top and I know it will end up coming off from age and heat, but is easy to redo and the foam is not going anywhere.
And ????? That's it ? you are killing me ..... i need answers ... i need results ! ..... just kidding.
Exactly what i have in mind as well .... hope it will work ....
I hope that's it! Haven't ridden it yet as its cold, windy, and rainey all day. But I'll fire it up tomorrow and let it idle. That's when I get it. Or hear it anyway.
Also, that is the NON ABS wire harness. There may be more in the ABS bike shell. I'll have to check the book.
You know, I just noticed that the big black connector might vibrate against the headlight. I'll take care of that in the AM.
Good idea you have there. Let us know if it helps. I'm in the middle of a major project but if it works for you, it should work for many, so that will be my next project.
Hay! Popgun! Look at you! Posting beautiful pictures like a pro.
All we have to do now is get the Ferret onto Paypal. Big Grin
Good luck with that!
As for me, you created a monster! Wink
I went back and wrapped the rest of the connectors and put the headlight back in and the Puig back on.
Cranked it up and---NO BUZZ! Celebrate
So in my case, either the connectors were buzzing, or for some reason the Puig had something to do with it. I'm thinking it was the connectors.
Thanks for this thread. I thought the buzzing was coming from under my tank. Wrapped the headlight harness with foam no more buzzing.
Thumbs Up Clap
  Instrument Cluster Needles Cormanus 14 980 02-04-2026, 02:29 PM
  Instrument Cluster A & B Button Repair Phadreus_imp 36 3,098 08-17-2021, 09:09 AM
Last Post: furious_blue_imp
  Loose Instrument Panel / cluster ecka00_imp 12 784 06-07-2019, 06:50 PM
Last Post: Bazbro_imp
  "BUZZING" while riding - NOTHING at idle rozbabbo1100_imp 11 892 09-12-2017, 03:58 AM
Last Post: rozbabbo1100_imp
  Lower Cover instrument panel linuxology_imp 5 461 11-01-2016, 10:19 AM
  Instrument panel cover removal help Stratus_imp 22 1,291 07-03-2015, 03:15 AM
Last Post: Redbird_imp
  Chrome instrument covers ? Johnboy_imp 8 849 02-19-2015, 10:41 AM
Last Post: Johnboy_imp
  Buzzing sound on startup and slow return to idle? Wereignsupreme_imp 19 1,325 05-03-2014, 05:28 AM
  Instrument cluster loose? Phat Ham_imp 5 554 05-14-2013, 02:18 PM
Last Post: GSAviator_imp
