11-16-2016, 02:01 PM
And we don't, and may never, know the answer. See post [url=http://cb1100forum.com/forum/showthread.php?tid=9767&pid=154630#pid154630]#15.
Bike stalled today...
11-16-2016, 02:40 PM
(11-16-2016, 07:50 AM)Pete Erickson_imp Wrote: OK guys, if you are using the fuel gauge or the computers guess on miles to empty.....STOP. You might as well use Tarot cards.Depends on how you ride, be sure to go with a very conservative value. I've never gotten less than 40 mpg average, I like to twist the throttle, so that's a decent number I'd guess. I have found the digital fuel gages in my bikes to be very reliable, only when I pushed the ZX-10R to the limit did I run out of gas. They all give plenty of warning.
12-14-2016, 05:27 PM
Bike was level, but clearly not much fuel left in the tank with a reading of 22 miles to go 'till empty. Bike was then leaned over onto the kickstand. Gas pools in the lowest part of the tank. Starves the pickup. I can't disprove odder, less likely causes, but fuel starvation is way at the top of the list, isn't it?
02-11-2019, 03:06 PM
Hasn’t happened since so it’s still a mystery. I think it was just lowernon fuel than the computer was indicating.
02-11-2019, 03:16 PM
(02-11-2019, 03:06 PM)ryanschillinger_imp Wrote: Hasn’t happened since so it’s still a mystery. I think it was just lowernon fuel than the computer was indicating. That behaviour seems to have been experienced by a few Forum members over the years in regards to displayed vs. actual fuel remaining. The computer knows exactly how much fuel it has metered out the injectors, but I wonder if other variances like evaporation, ethanol content (?), bike lean (e.g. on side stand), and possibly exact refill measure is throwing off the estimation a bit.
02-11-2019, 04:37 PM
This is probably the case. The only time I ran out of fuel, the bike said I had nearly 25 miles remaining to empty but I got stranded about 1.5 miles from a gas station at the top of a freeway overpass. That sucked. Maybe it just doesn’t have a very accurate float in the tank or whatever. I’ve ran it till the low fuel warning came on before and did not run out. I keep it above 1/4 now if I can help it.
02-11-2019, 10:01 PM
(02-11-2019, 04:37 PM)ryanschillinger_imp Wrote: This is probably the case. The only time I ran out of fuel, the bike said I had nearly 25 miles remaining to empty but I got stranded about 1.5 miles from a gas station at the top of a freeway overpass. That sucked. Maybe it just doesn’t have a very accurate float in the tank or whatever. I’ve ran it till the low fuel warning came on before and did not run out. I keep it above 1/4 now if I can help it. The lowest I have ever taken the tank was 2 L (about 1/2 gallon) before reaching a gas station. Your experience is good to keep in mind. I also have CAA (like AAA) that will deliver gasoline if my m/c goes dry. Useful for rides in North America. |
« Next Oldest | Next Newest »
| Bike Shut Off While Riding Today | Johnny62087_imp | 16 | 978 |
09-20-2018, 03:07 PM Last Post: DBM_imp |
| Stalled | Nemo_imp | 17 | 1,198 |
09-14-2017, 11:22 AM Last Post: cooldrum_imp |
| Bike wouldn't start today.. bad battery? | PowderToastMan_imp | 23 | 1,391 |
12-30-2014, 08:52 AM Last Post: rboe |
| Dyno'ed the stock bike today | hondahoarder_imp | 11 | 704 |
08-03-2013, 10:05 AM Last Post: Deanohh_imp |
