FYI: Honda Service Bulletin on CB 1100
(06-22-2014, 01:11 PM)davidsargee_imp Wrote:
(06-22-2014, 12:23 AM)Elipten_imp Wrote: Sound like time for a science fair experiment of cooking some Honda 10w-30 on a camping grill with a deep fat frying thermometer and see what happens, but I suspect higher temps are used to cook french fries or a turkey but I never worked fast food so don't have first hand knowledge.
But I am interested in a temp gauge if someone figures it out as I never like warning lights.
You can fry foods in vegetable oil at 300 deg F. and up, 350 deg is generally optimum for french fries, etc. A deep fat frying thermometer would certainly cover the temp range discussed in this thread.
No matter the measure, 342 degrees F is hot enough to fry a turkey, for sure. I'm no engineer, but that seems mighty hot for engine oil.
I was in some really bad stop and stop traffic the other day, I shut the engine down a couple of times in stopped traffic, temps were in the high 90s. I was watching for the oil temp warning light, and it did not light up, so I have no indication of excessive heat. However, when I got to my destination, I heard some tapping sounds coming from the engine. I was at a little over 7600 miles on the odometer, about due for the 8000 mile servicing, so I thought maybe the tapping was related to the need for the oil to be changed, or perhaps even valve adjustment, (unlikely at 8000 miles, but valve clearance is checked at 8000). When I left about an hour later, the tapping noise was there for a minute or so after start up, then faded away. Now I'm wondering if the tapping was heat related.............
I've ridden my bike in 110*F ambient temperatures in traffic without seeing an oil temp light, so you're fine. The engine definitely makes different noises depending on whether it's hot or cool, which should be expected.
Same same. 110degF at speed and in traffic for two whole days. No abnormal indications from the bike. I was pouring water into my mesh jacket to try to keep myself cool. And cleaning the tar off the pipes and the engine was a real bastard.
I believe the API tests all motor oils to 102 deg. C (350 deg. F) for 100 hours. So, if your oil meets API certification, you are OK and Honda chose the correct value for the oil temperature warning. If you are nervous, use good synthetic oil as it generally has higher temperature limits. For perspective, I follow Corvette production racing and oil temperatures typically reach about 290 deg. F in race conditions in hot climates.
102 C = 215 F. Not very hot for oil.
(07-25-2014, 06:52 AM)Ack-CB11_imp Wrote: 102 C = 215 F. Not very hot for oil.
Correct. For a liquid cooled auto engine (which is what API specs are concerned with) that's higher than you'd see on a typical hot day in traffic. Air cooled engines experience a wider range of operating temps, both on the high and low side, since it's the oil that carries the heat away.
Dino base oil stocks will start breaking down starting at temps above 250F. Synth base stocks are more heat resistant and will typically give you another 20 - 30 degrees above that.
Given that, I still think the trigger for the oil temp light on the CB1100 is ridiculously high. I don't even know of any synth oils that can withstand that temp without serious thermal breakdown. In fact, the procedure that is commonly used to test oils for thermal breakdown is done at 302F.
My cb rattles like crazy in hot weather. I am sure it will be quite noisy at tomorrows cruise on Telegraph Rd. Stop and go & show all day. Lots of fast cars & bikes.
I apologize for a recent typo. The believe the API tests oils to 350 deg. F, which converts to about 177 deg. C. for 100 hours. Another article I read says 150 deg. C MINIMUM. The viscosity breakdown allowed is dependent on the service level for which the oil is being certified.
The API does a great job testing oils for gasoline and diesel powered cars and trucks, etcetera. I have not found any tests that are specific to motorcycles.
Avoid using oil engineered to improve gas mileage in your Honda
So...referencing the tech bulletin, are we supposed to wash the headers before starting her up on delivery? How do I know that coating is off my headers and will not burn and stain?
Is that the "hot" smell she has when she is idling? I just chalked that up to new smell...
Probably late if smelling it and ran bike. I think it posted here somewhere.
(08-16-2014, 06:29 AM)NightRider_imp Wrote: So...referencing the tech bulletin, are we supposed to wash the headers before starting her up on delivery? How do I know that coating is off my headers and will not burn and stain?
The dealer is supposed to wash the exhaust system before starting the bike. Unless you picked up yours in the crate, this should have been done for you.
  Service manual Billie_imp 32 2,636 11-27-2025, 06:35 AM
Last Post: TheLegend
  Service Manual for CB 1100/A/SA 2013-2016 N4RN_imp 14 1,345 05-06-2025, 04:29 PM
Last Post: Karidis
  How To do your own 600 mile service the Ferret 163 9,066 08-10-2023, 07:42 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 523 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,089 04-23-2023, 01:35 AM
  Service and Repair Manual alexzanutto_imp 5 591 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Factory Service Manual Download ??? markT_imp 24 1,766 10-14-2021, 09:30 AM
Last Post: furious_blue_imp
  Service indicator - unleashed j3gq_imp 6 567 07-27-2021, 03:12 AM
  Free Honda SERVICE Manuals dan88_imp 9 793 03-30-2021, 08:18 PM
Last Post: Enzofour_imp
  HONDA Oxygen Sensor Eliminator CB 1100 2013-2016 Enzofour_imp 1 253 03-07-2021, 05:16 PM
Last Post: jtopiso_imp
