stained stainless and chrome
(11-22-2020, 04:27 AM)j3gq_imp Wrote:
(11-11-2020, 12:35 AM)peterbaron_imp Wrote: All above advices are good.
Very tough maintenance as beautiful Spain is located between the Mediterranean Sea and the Atlantic Ocean, both of high salinity, 38-40 ppt and 33-37 ppt respectively.
Exhaust is getting hot and cold and salt just loves this type of catalysis.
You need more frequent chrome maintenance with adequate product to your climate, in general.
For your exhaust, I would recommend ceramic coating treatment.
Here is the link explaining what it is:
http://hightechcoatings.com/
Do your local research first. Good luck.
I think, you live close to the water line...?
When I saw your link, I opened it and went to the product page. Here is the first sentence I read:
High Tech Coatings Ceramic Header Coating is a Patented Metal filled ceramically bonded inorganic coating that is non-electrostaticly applied and cured at high temperature.
I am not saying it cannot or does not work, but this sentence does not really inspire a lot of confidence - neither in the product, nor in AI for translation.Exclamation
(11-14-2020, 04:37 AM)Ayrshire Dunx_imp Wrote: Before anything else try rubbing it with wet aluminium foil.
Are you serious ? (not meant sarcastically)
How can metal on metal not produce scratches, even if one is soft and one is hard ?
As said before: I tried just that, and it has worked wonders! I removed most of the rust with no effort.
Aluminium is softer than stainless, so it doesn't leave any marks on my pipes.
I've tried aluminium foil on rust on stainless steel in the past and it's worked really well.
This site (as do others) tell why it works: http://www.slipperyrockgazette.net/index...ageId/1948
  Speedo & Tacho chrome covers Chris Goldson_imp 22 1,724 05-23-2026, 04:43 PM
Last Post: LucienLeFranc
  Chrome cylinder head cap Juancho76_imp 21 1,713 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Protecting Stainless Steel Phadreus_imp 18 1,355 01-11-2022, 06:04 AM
  Cleaning Chrome Headers DAC 7 644 02-09-2019, 04:31 AM
Last Post: Nortoon_imp
  Chrome Pitting on Fork Tubes dave 11 873 09-07-2018, 11:22 PM
Last Post: SportsterDoc
  Chrome instrument covers ? Johnboy_imp 8 850 02-19-2015, 10:41 AM
Last Post: Johnboy_imp
  Rear chrome rack from Honda Kyhiker1100_imp 8 646 03-10-2014, 12:18 PM
Last Post: Pterodactyl_imp
