engine oil change time interval in kilometers CB1100 EX 2015
The CB will show a high temp warning long before your oil sees any temps it cannot handle. 3000 rpm in first is as good or bad as 3000 rpm in the 5th (unless you stay in 2nd for 6000km, which extends the hours on the engine). Gear changes, and acceleration make no difference either.
But GoldOx is right, the environment counts (air the engine breathes), and the quality of the gas burned counts too (by-blast past the cyl rings). So you either stick to the Honda recommendation, or you need a way to guess whether your oil can stay in longer. If you like to go this route, let me know, and I try to explain.
(11-22-2020, 05:27 PM)Alfgaxatico_imp Wrote: gracias amigo . el aceite repsol; 10 40w sintetico cuesta 16 € / litro. y aqui en zaragoza, norte se españa en verano es unos 30 grados y lleva mi CB1100 ex 2014; 23700 kms. conduzco siempre maximo 2500 rpm (en 1a y 2a velocidad) muy suave (soy ya viejo 55 años).
Yo voy a probar también el Repsol 10w40 sintetico en el próximo cambio. Además es producto nacional. Y Repsol trabaja con Honda.
  Oil change CB1100@2013: photos valkyrie_rider_imp 12 1,180 02-14-2024, 11:25 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 253 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Air Filter Change Interval? dave 25 1,987 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  tire change Tom_imp 7 748 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,966 02-20-2021, 02:42 PM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 691 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Rust/corrosion - 2015 EX model N4RN_imp 7 693 10-26-2020, 08:25 PM
Last Post: syncronizator_imp
  Oil Change interest? Scotty_imp 10 943 09-15-2020, 09:40 PM
  where is the sticky post to first time oil change? buckwheat_imp 4 448 09-10-2020, 05:41 AM
Last Post: buckwheat_imp
  Oil Change Time! Jambo_imp 57 4,229 09-06-2020, 08:40 AM
Last Post: Jambo_imp
