brake pads which is best?
(03-27-2016, 07:22 AM)kmoney_imp Wrote:
(03-27-2016, 07:19 AM)curlyjoe_imp Wrote:
(03-27-2016, 03:04 AM)kmoney_imp Wrote: I want to say that having the different size islands (with the smaller one being on the leading edge) gives the ABS pads less initial bite and makes them less grabby each time you use your front brake alone.
I've never had my rears off on my '13 ABS but from what I see there, it almost looks like mine has the "regular" rear pads, as I'm pretty sure the gas slot is in the middle.
I pulled my rears off on my '13 ABS to measure thickness and they are identical to the $90 replacements I had ordered (first pic above). I couldn't find aftermarket pads that look the same.
The '13 CB1100A does have the combined braking system with 3 piston calipers on the front. The center piston on the right front engages when the rear brake is applied.
Perhaps these pads are quite unique and in low demand so the manufacturer charges much more for a limited production run.
I think that's it, though I would think we share rear brakes with at least a few other C-ABS Hondas.
From this [url=http://www.hondapartshouse.com/oemparts/p/honda/06435-mej-016/pad-set-rr]link, it looks like the '12 & '13 NC700XD also uses these pads.
I cant say which pads are best of course but have just fitted Brembo Sintered (HH) to the front calipers on my 2017MY EX. They are a good improvement over stock. Nothing mind blowing, if I were to estimate, they felt like they added ~15 to 20% more stopping power under heavy braking. Best of all though is the increased feel and control at the lever for light braking and low speed work around town. I suspect any HH pad is going to feel similar.
EBS is only company I have found that makes them for 2014 standard. front pads anyway...
stock
(05-01-2021, 06:49 PM)Tev62_imp Wrote: I cant say which pads are best of course but have just fitted Brembo Sintered (HH) to the front calipers on my 2017MY EX. They are a good improvement over stock. Nothing mind blowing, if I were to estimate, they felt like they added ~15 to 20% more stopping power under heavy braking. Best of all though is the increased feel and control at the lever for light braking and low speed work around town. I suspect any HH pad is going to feel similar.
What are the Brembo part number for Front that you used?
Thanks
for the 2017-2020 EX it is 07HO45SA
(07-08-2021, 04:36 PM)Tev62_imp Wrote: for the 2017-2020 EX it is 07HO45SA
Thumbs Up
What about CB1100RS? It has radial brakes, not sure if pads are the same.
(08-21-2021, 06:12 PM)mrded_imp Wrote: What about CB1100RS? It has radial brakes, not sure if pads are the same.
The front in a Brembo pad is
I went with the EBC pads front and rear at about 1/3 the cost of OEM.
  Brake Pads... Simplified Yata-Garasu_imp 20 1,980 03-02-2025, 08:28 PM
  Any one use Ceramic Brake pads? mvk24_imp 6 706 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  Suggested brake pads? mvk24_imp 12 1,062 03-21-2021, 04:05 AM
  Rear brake rotor and new pads Sandhog_imp 13 1,067 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Correct part number for front brake pads Frulk_imp 7 663 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,140 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  I looked and I looked... brake pads simplest2remember_imp 3 389 07-01-2019, 08:27 AM
Last Post: itsme67_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,274 02-04-2019, 01:47 PM
  for non-ABS riders: which Brake pads are you all using? misterprofessionality 10 794 12-31-2018, 10:15 PM
Last Post: chync_imp
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,814 09-14-2018, 12:35 AM
