Another High Idle Problem
Again, thanks for the tip and instructions. It might just save me a few hundred buck. Smile
Follow up.... Spoke to my shop. The reset procedure that PB was so gracious to detail above was (effectively) done on my ECU when they swapped it to the other bike. The values were all reset before trying my unit on the other bike. So, for good or bad, I'm getting the new ECU.
Also, they misquoted the cost on Saturday. They are charging me a little over $500 for the new ECU and no additional labor to install it. I don't know exactly, but I think they're charging me a couple hours of labor for the diagnostics including the test swap. I suppose that they could have just done the PeterBaron test and skipped the swap out, but I'm ok with their process as it's pretty rare to have the ECU fail and they wanted to isolate the problem to the ECU.
So 1 new ECU and 2 new tires and a repair cost approximately equal to 25% of the bike's value. I must really love my CB1100. LOL
Glad to hear you are happy and the CB is back to your possession Thumbs Up
P.S. dont't worry about the cost, we all go through it Smile
As Willy Nelson used to croon.. "ON THE ROAD AGAIN"
You have to be happy about that
Still waiting on the new ECU to be delivered. Hope to have the bike back later today or tomorrow. Then I have to ride my cuss off to get back on track for 183 days and 15,000 miles.
I am very happy that your problem does not cost you a fortune , pleasures in life cost money.
MTC: Try to keep the old ECU since technically you still own it (?). Maybe down the road it can be fixed and then it be a spare.
Stilllllll waaaaaaaitinggggggggg! The sunny days are the hardest.
If the part arrives today, I’ll be riding this weekend. If it doesn’t, then it will be at least Tuesday before I can ride again. ugh.
(12-01-2020, 04:21 AM)EmptySea_imp Wrote: Follow up.... Spoke to my shop. The reset procedure that PB was so gracious to detail above was (effectively) done on my ECU when they swapped it to the other bike. The values were all reset before trying my unit on the other bike. So, for good or bad, I'm getting the new ECU.
Hey Matt!
Glad you got tour bike back on the road. Never easy to dump money on unanticipated repair costs. Early this year I had to replace a rear tire on my Goldwing due to a screw in the sidewall...right after the PA rally. Tire had less than 2,000 less miles...about 10,000 sooner that normal.
Two things to remember:
(1) “There are no pockets in a casket”.
And
(2) “ I never saw a hearse pulling a U-haul”
Move on and enjoy the next ride!
And you do not want to be the richest man in the cemetery.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 120,039 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,148 05-12-2026, 08:38 PM
Last Post: rdprdp01
  'Factory' high performance spark plugs PowerDubs_imp 17 1,509 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Chain or sprocket problem ? The Gecko_imp 14 1,299 07-30-2024, 10:05 AM
  High engine revs on start up CBX1000_imp 21 1,850 06-06-2024, 02:40 AM
  another idle thread Tom_imp 11 1,037 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 678 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,805 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,403 09-06-2023, 01:36 AM
