About the problem of high idling. (2014 cb1100ex)
GO i used a 4 pole cable with different colors, they have fitting " header connectors " and one header connector has 4 thin wires which fit into the iacv connector and has 2.5 mm pin spacing.
The shield of the cables is connected to the bike chassis ( battery ground ) through the red clip and the others tap into two of the four wires.
And a closeup of the connectors;
This way i can get easy access to the connections
The two inner wires connect to coil 1 and the outside wires connect to coil2, i think i used yellow and orange
Very good max. Tanks.
Nice little handheld scope Max. I want one of these: https://www.tek.com/en/products/oscillos...series-mso
They have been spamming my email about the new series. Its working but I'm not getting one. Wonder if they take Apple pay...
Yeah, i've watched several videos with an initial review, it looks daunting to me and the quick start guide is 331 easy pages.
It also requires 24 volts at 2.5 amps with a proprietary dc connector, so not very portable without the optional battery back assembly.
This little handheld thing falls definitely in the toy category and in true chinese fashion was unstable until i added a 100 ohm resistor to one of the i2c data lines......
but it runs for 5 hours on a built-in battery and it is practical to use for some things except in outdoor light.
it does not have the automotive capture facility that the hs402 has, that scope tablet is nice for analyzing engine performance and i play with it with various transducers and that is satisfying, i watch a lot of automotive diagnostic video's, ATS's Bernie thompson is fascinating to watch with his e-scope tablet.
My use of scopes is very sporadic and i have no training with them but they are able to show me what i want to know so they get used from time to time
(06-15-2022, 12:38 AM)max_imp Wrote: Yeah, i've watched several videos with an initial review, it looks daunting to me and the quick start guide is 331 easy pages.
That seems to be the role of an oscilloscope: Burst need, then collect dust until the next burst need.
That said, these days (2010 and beyond) having a scope in the house seems to be the "new essential DVM" given the continuous growing complexity of current day electronics that are typically "none-serviceable".
A modern home HVAC is another example where three-phases feeds are emulated electronically to drive a blower motor efficiently. Another is evaluating a failing gas valve, and the signal commands they are receiving / statuses transmitting.
Seems to make sense to have the tool around the CB1100 if you have the time to understand technology and likely save some $$ doing so. In other words: The bar for tinkering with system electronics is higher today than in the 1960s - for sure (although I think tinkering with tube electronics is still a pain in the butt).
It is a shame Honda does not do something about it, as it has thoroughly destroyed any confidence I had in Honda products.
I know EXACTLY how you feel. I have owned about 12 - 15 different Honda motorcycles in my lifetime and have thoroughly enjoyed all of them. However, the response Honda has provided for CB1100 owners just leaves a very bad taste in my mouth. I have only experienced one other warranty related issue with a new Honda product I purchased, and unfortunately it was a challenge to receive satisfaction from Honda for this repair also - but I eventually did.
(06-15-2022, 06:04 AM)Dave_imp Wrote: It is a shame Honda does not do something about it, as it has thoroughly destroyed any confidence I had in Honda products.
Thumbs Up
The warranty experience is not just limited to the Honda CB1100.
I think Honda is desperately clinging onto their overall reliability across the product lines and playing the numbers game as long as they can, and at the expense of individual owner grievances.
Just noticed partsfish has new part numbers for the pgm fi , wonder if would fix our problem?
2013;
https://www.partsfish.com/oemparts/a/hon...re-harness
and 2014;
(06-15-2022, 10:55 PM)max_imp Wrote: Just noticed partsfish has new part numbers for the pgm fi , wonder if would fix our problem?
2013;
and 2014;
Well, it is expensive, but would be worth it if it did the job. More money down the drain if not. Have to look at their return policy. Thanks Max.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 117,267 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,065 05-12-2026, 08:38 PM
Last Post: rdprdp01
  'Factory' high performance spark plugs PowerDubs_imp 17 1,471 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Chain or sprocket problem ? The Gecko_imp 14 1,209 07-30-2024, 10:05 AM
  High engine revs on start up CBX1000_imp 21 1,765 06-06-2024, 02:40 AM
  2017 Honda CB1100EX modifications kennyw 28 2,083 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  O ring chain problem Mixagon_imp 7 633 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,536 09-14-2023, 10:08 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,127 06-24-2023, 08:27 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 550 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
