08-31-2020, 09:18 AM
Can some one with RS share pictures with risers?
Handlebar Risers
08-31-2020, 06:02 PM
08-31-2020, 10:51 PM
Jtopsio, if this thread [url=http://cb1100forum.com/forum/member.php?action=profile&uid=4724]http://cb1100forum.com/forum/member.php?...e&uid=4724 doesn’t help, PM me and I’ll help.
08-31-2020, 11:31 PM
09-01-2020, 03:44 AM
From the Department of Shameless Cross-Promotions:
I just posted some pics of Rox Speed 2" adjustable risers for sale in the classifieds. http://cb1100forum.com/forum/showthread.php?tid=15951
09-01-2020, 06:55 AM
Apologies, jtopsio. Try this, http://cb1100forum.com/forum/showthread.php?tid=12717
09-01-2020, 09:12 PM
Massive compression. Let's se what you get...
(09-01-2020, 06:55 AM)Cormanus_imp Wrote: Apologies, jtopsio. Try this, http://cb1100forum.com/forum/showthread.php?tid=12717 Thanks, I've found a workaround to avoid setting up an imgur account. (08-23-2020, 11:43 PM)TXBikerGuy_imp Wrote:(08-23-2020, 10:35 AM)Crazyirv_imp Wrote:(08-23-2020, 07:47 AM)TXBikerGuy_imp Wrote: Just installed [url=https://twistedthrottle.com/shop/ergonomics/handlebar-risers-barbacks/sw-motech-handlebar-riser-kit-to-fit-22mm-handlebars-for-many-aprilia-bmw-honda-kawasaki-ktm-suzuki-triumph-yamaha-models-25mm-rise-silver/]these on my '17 EX today. Super easy install. That empty space at the bottom is required. If it wasn't there, what are you clamping? You need to make sure the flat faces do full contact, and all the bolt load goes into compressing the joint. If the round section was making contact before the flat face did, the bolt load wouldn't compress the flat face: it would bend it. When you are clamping a handlebar, the design is opposite: you need to make sure that you are clamping the bar, so there must be a gap between the flat faces.
07-16-2021, 03:23 PM
I found the forum posts helpful when I was looking into taller risers to raise the handlebar height. I went with a cheap and flexible option from BikeMaster:
https://www.revzilla.com/motorcycle/bike...id=1068521 these are cheap at $34 and offer 4 options for straight raising of the bars: +1", +1.1875", +1.374", +1.5" I opted for +1.374" which went on easily with no problems with regards to cable or hose lengths, stock worked just fine. They don't look factory, but they work fine and were cheap. <I haven't been able to figure out how to upload an image as an attachment and then add it to a post>
07-17-2021, 02:00 AM
photo of Bike Master risers installed:
07-19-2021, 05:33 AM
(05-31-2020, 10:26 PM)mrichi_imp Wrote: Hi just wanted some ideas on which handlebar risers suit the CB1100 if you can include a link to the web site that would be appreciated Hello, I've got these I pulled from my '13 when I swapped bars. I'd take $40 all in (shipping included to lower 48) if you're interested. -Mike |
« Next Oldest | Next Newest »
Need original 2013-14 Handlebar with weights | HondaLou | 5 | 335 |
08-13-2026, 06:16 PM Last Post: HondaLou |
| Handlebar Vibration | Bodizafa_imp | 9 | 1,234 |
09-05-2018, 05:29 AM Last Post: Houtman_imp |
| Handlebar end weights | lash_imp | 9 | 662 |
06-06-2015, 04:29 AM Last Post: kennyw |
| Can Someone Measure Handlebar Length for Canyon Dancer 2? | PJV_imp | 8 | 697 |
10-17-2013, 02:19 AM Last Post: meowguy_imp |
