New owner... Vibrations.. And a question
Those bar end screws are ALOC fasteners and the book says to replace them after removal. ALOC fasteners just have a thread locker on them. Just use some medium locker on them and they should be OK.
Vibration— Is it possible your counter balance needs adjustment? It is easy to do. I don’t know if it would cause vibration or just be noisy though.
(05-27-2021, 08:35 AM)Lord Popgun_imp Wrote: Those bar end screws are ALOC fasteners and the book says to replace them after removal. ALOC fasteners just have a thread locker on them. Just use some medium locker on them and they should be OK.
thanks for your input
workshop manual says work on the balancer requires engine removal... Or am I missing something?
OOPS ignore me, I found it. Thanks for the tip, will definitely give it a go
Not for adjustment...
UPDATE
thank you ever so much Lord Popgun.
I performed the adjustment, it appears to me that the balancer was on the loose side.
From the very small ride I can perform around the yard, it definitely seems to have improved matters somewhat, but hard to be sure until I take it out for a longer test.
I'll take it out in the morning to go and get some BBs for the handlebars and um.. update this update
cheers
Sometimes I have a clue. Sometimes I don’t know there are clues! Smile
I hope that does it, or at least helps some.
Two CB's, the '13 & '14 both like to see the bar weight screws like to back out. Even with thread locker. Kinda annoying.
I used to get a bit of a buzz around 70 mph in top gear but in either bike now I don't notice the vibes any more so perhaps a bit of a break in period does help. The balancer was completely off my radar so I hope sorting that cures your problem.
Very keen on seeing how this plays out for you.
I was going to suggest that perhaps an injector was not working properly, leading to lower power in that cylinder and leading to a vibration. Probably a bit of a reach but there you go! Good luck!
After reading all the posts I am going to go out on a limb and suggest that Lazz's bike has a problem. I ride my 2014 Deluxe in the 70 mph to 85 mph range on our California freeways all the time and I have never noticed any unusual or excessive vibration. (I know this is not as fast as Lazz rides, but that the fastest I can tolerate for any length of time on an unfaired bike). I suggest finding another CB1100 Honda owner and swapping bikes for a ride to see if there is any difference in the two bikes.
Sorry if this has been covered before, but 've heard more than once that exhaust systems mounted in tension may transmit quite some vibrations to the frame. Remedy:
1. loosen exhaust system mounting points,
2. start bike and let idle for a few minutes,
3. re-tension mounting points.
The logic beeing that the loose system settles in its favoured (least stress) position and this allows the rubber mountings to better do their job. I've not tried this on the CB1100RS - although I do admit it vibrates annoyingly much, almost too the point of being a showstopper - but on other bikes I imagine that it made a difference.
Again, sorry if stating the obvious/already covered.
Those are good points Olof. I would think it could be a lot of things-tires/wear balance, loose head bearings, wheel alignment or not true, forks not aligned properly. IDK. Remember one member had a swingarm that was loose in the frame and had to deal with that. He had to shim it to get it right.
When these bikes first came out in the US and UK someone started a UK board. This board had not been started then. Ferret and I were on it, and some others. Anyway one guy in the UK had either a noise or vibration that turned out to be (we think, Honda was cagey about it) counter balancer problem. They pulled the engine and replaced the balancer, or something, and he was good. I’d check as many things as I could.
That UK CB site never had much traffic and once Guth put up this site, it faded away and this one took off.
Thanks guys,
I'm in contact with the dealer, I still have full factory warranty, so if there is a fault I should be covered...
I did another 3 hour ride yesterday, some city, some A-roads and about an hour on the highway. It's a truly bizarre experience. On the highway, 80-90mph in top gear puts you right in the no go area of the rev range (where it vibes so bad that your hands would be a goner in around 15mins if you stayed there.)
BUT if you drop 2 cogs you end up at 5K where its noticeably smoother
or even shift all the way to 3rd, you end up at 6K where it's REALLY smooth
...and deceptively fast! like glance down at the speedo and you're suddenly cruising at 100-110mph, an absolute 'gentlemans express'...
keeps getting smoother as the revs increase too
but, as soon as I need to slow down back to say 65-75 I found myself pulling the clutch in, letting the speed drop and then flicking 2 or 3 gears back up to 6th and clutching back in at 3k
sounds crazy? It is....
It's a really weird feeling, going down the highway at 70mph in top gear and knowing that you are limited by a nasty buzz from the engine.
I can't really explain why that rev range should be so rough, and yet the bike be so smooth at higher and lower rpms. I know every engine has it's rough point, but this is the most extreme version I've ever encountered
I kept asking myself, how would I be riding this thing differently if it wasn't for the vibraions, and the answer is, I would be riding in a much less complicated way!!
City work was great though, fizzing along at 2- 2.5k and yes, feeling the programmed 'character'
Oh and regarding the high speeds, I made a fairing many years ago that 99 per cent eliminates wind blast (for me) at highway speeds and luckily it slips straight on to the Honda!
Will keep you updated...
  CB1100 Questions from a potential new owner E11even_Hunnit 88 6,930 02-12-2026, 06:02 PM
Last Post: E11even_Hunnit
  New owner looking for front turn light, signals and exhaust recommend lfminto_imp 8 661 06-11-2024, 08:19 AM
Last Post: devildogdoc_imp
  Owner's Manual Bighonda14_imp 35 2,551 04-04-2024, 02:29 PM
  New Owner of a 2017 CB1100 EX Kalamari_imp 22 3,146 11-18-2021, 03:03 AM
Last Post: Whoops
  The CB owner willsmith_imp 15 1,262 10-31-2021, 08:58 PM
  Met a new CB owner misterprofessionality 26 1,929 10-10-2018, 03:05 PM
  New Owner Report grandpagl_imp 3 359 09-04-2018, 03:39 PM
Last Post: DBM_imp
  New owner with a lot of questions.... jdinaz_imp 7 620 10-25-2017, 02:15 PM
Last Post: jdinaz_imp
  Prospective owner JonC1985_imp 15 997 10-23-2017, 07:42 PM
Last Post: alprider
   Gotta love owner forums Mikestib1_imp 13 830 01-09-2017, 10:46 AM
Last Post: nhawk7504_imp
Users browsing this thread: 6 Guest(s)
