Got in first crash recently.
Go through your insurance. You will be amazed as to what this stuff will cost to replace.
Repainting the engine covers will never make it look right, and besides you don't want to take the chance that there is a tiny crack that isn't leaking....yet.
Also go to the hospital and get checked out because you never know how bad you are really hurt.
Don't forget to inspect your helmet. Replace it if shows any sign of impact.
(07-29-2015, 03:55 PM)Randy B_imp Wrote: Go through your insurance. You will be amazed as to what this stuff will cost to replace.
Most likely if as described the replacement parts will be less than his deductible.
Not with the faring being damaged. That will be covered in the accessory portion of the policy and I'd bet the turn signals got scraped as well. Look at EVERYTHING closely and I'd bet you'll find more than that.
I went down on the same side, albeit a bit faster, but I had a laundry list of stuff that they replaced.
Glad your injuries weren't more severe....health trumps money every time.
A couple of consideration on letting insurance fix it.
1. There might be more damage than you think.....forks twisted? My wife was recently hit and we could see no damage....body shop immediately saw miss alignment of bumper, etc....estimate over $1000.
2. Not they the CB's are holding their value, but someday a scratch might affect the re-sale value. I know that is the first thing I want to know. My GPz750 was put down in a gravel driveway by the 1st owner....took me a long time to see the handle bars weren't in alignment with the front wheel (fairing in the way helped hide it).
I'm glad your all right its always good to hear that a rider walked away from a crash with no major injuries, good gear can make all the difference. One thing to consider is if your cost of insurance. I had an incident where the cost of the deductible plus the rise in premiums led me to streetfighter a bike. If the parts can be obtained for less than the cost of the deductable I would lean in that direction.
I'm like you. I have the black side cover damaged when I laid her down on day in the Woodbury TN square. I came up to a stop sign on the square and the road angles down on the left side into a drain, enough that when I dropped my left boot down when coming to a stop it leaned over past the point of no return and down she went. I learned a lesson never to stop on a road that dips at that angle. Other than her left side cover that was all she suffered and there is no dent, just a scrape. I thought about sanding and painting have decided to do it after the riding season just in case I decide to lay it down again this summer. Smile
I've locked the rear up in low speed emergency stops and remembered the lessons taught me in riding schools to ride it to a stop keeping her locked to keep from high siding and frankly after I practiced several hours in the local school parking lot, practiced emergency quick stops, I've gotten real good in stopping her without locking and also locking the back when safe. I bet I practiced such stops thirty or more times before I was happy. I've never locked the front and these brakes are so easy to control without ABS that I am almost afraid to get a bike with ABS for fear it will take over the braking for me and not letting me control her as I decide. I was coming down a longish downhill twisty road just north of Pikeville Tennessee, coming off the plateau, and the road suddenly twisted left in a 45 degree turn with a straight up bluff in front and a drop off to the other side. I downshifted and applied the front and rear almost to a lockup before the turn, came of both and give her gas to lift her up and flipped her to the left in a hard lean, this bike has a lot of clearance when you bring her up off the suspension with a little gas, and she turned and stayed up and then came upright as if nothing happened. This is a great bike. I also don't know if I want ABS on my next bike. It scares me that I won't have total control of the brakes.
Oh, I likely will replace the side cover with new to keep her in undamaged condition rather than try and sand and paint. With yours, that puppy is dented pretty good so replacement is required I would think. Sooner the better in case the metal is weakened by the stress of this impact. I suspect the points are to replace the bolts in their original locations and tighten them in the order and at the correct torque specified by Honda. When I do this, I draw and outline of the side cover on cardboard and punch a hole in the outline where each bolt goes and then when I remove each bolt I place it in the correct position in the outline. Then when I replace the cover I take and tighten each bolt in the order Honda specifies. One place to find this is the manual or someone who has one.
  Crash Bobbins or bars Maturecheese_imp 14 1,179 07-04-2022, 02:29 PM
Last Post: run-tmc_imp
  Rust on tank from crash calipo223_imp 6 702 09-17-2020, 05:06 PM
Last Post: jtopiso_imp
  Crash bars make me crash cosmos_imp 47 4,290 04-18-2020, 11:14 AM
Last Post: michael1954
  Had a small crash jermo47_imp 17 1,362 09-25-2017, 10:37 AM
Last Post: dsan1964_imp
  Crash Bars for an other bike activedirt_imp 0 232 08-18-2017, 02:26 AM
Last Post: activedirt_imp
  Engine Guards / Crash Bars RonLyke_imp 93 8,293 06-02-2017, 09:55 AM
  Bad Crash LouA_imp 11 967 10-29-2016, 02:58 PM
Last Post: emptysea
  Kury arms and pegs on OEM crash bars White Dog_imp 0 196 11-13-2015, 02:43 AM
Last Post: White Dog_imp
  Open Face Crash Tortuga_imp 87 6,449 06-20-2014, 05:29 AM
Last Post: pechorin75_imp
  Possible first CB11 crash :( PowderToastMan_imp 17 1,241 06-18-2013, 12:50 AM
Last Post: PowderToastMan_imp
