considering the Honda heated grips for the CB1100
The Bike Master grips are just as good for $300.00 less. They have 5 settings. I can't imagine paying over 300.00 for heated grips.
Hi,
Did anybody measure the diameter of the stock vs the heated grips? Are the heated grips any softer than the stock grips? Stock grips are too small and hard.
Thanks
(11-16-2015, 03:52 AM)hdvalente_imp Wrote: Hi,
Thanks
Have installed the OEM heated grips on two Honda bikes now, and both times the grip size and firmness remained unchanged. Some have added Pro Grips atop the heated grips without adverse results on the warming effectiveness. YMMV.
Good luck getting a grip on the situation at hand! Tongue
fritz
I have the Oxford Premium Heated Touring grips on my other bike. 5 heat settings 30% 40% 50% 75% and 100% although I have never used anything more than 40% so far down into the high 30's for temps. Easy plug and play install although the inner tubes MAY take some fiddling. Did on mine, didn't on my brothers. $89 retail. Hardware is not as "clean" as factory grips with a controller on an arm and a rubber arm on throttle and clutch grips you have to make sure won't interfere with levers. Not a big deal, but you must be aware. Installation was about 45 mins to an hour total if you don't have to fiddle. I must say they work really well, putting out a lot of nice warm heat. They do measure 1/4" larger n circumference than my 719 Gel grips (and the stock Honda grips, although that is one of the first things I upgrade on all my bikes) and you can definitely feel it. I like smaller grips (stock diameter is fine with me) and these feel "too big" but I can live with it for the heat.
[url=http://smg.photobucket.com/user/theferret111/media/ST%20heated%20grips%20003_zps0poc75gh.jpg.html][Image: f457c89f18cf72787f5edb911c5702dc.jpg]
[url=http://smg.photobucket.com/user/theferret111/media/ST%20heated%20grips%20004_zpshlcpeyc3.jpg.html][Image: eaf7aa0c6f199f078b1e3fbac07d574e.jpg]
[url=http://smg.photobucket.com/user/theferret111/media/ST%20heated%20grips%20005_zpsuut2ftcv.jpg.html][Image: 60c915a68f3c85c7b75678bc268a3c1c.jpg]
Thanks for the info!
Sent from my VS990 using Tapatalk
Thanks
fritz
fritz
Thanks fritz! With that being said, I will probably order the BMW grips. I am used to larger and softer grips that I have on my Harley Heritage and after a ride this weekend with the CB I will have to take care of that asap.
Magnus
  Importing a 2022 Honda CB1100 EX from Japan to Europe YellowNimbus 9 2,202 05-17-2025, 03:18 PM
  Heated gear? ride4now_imp 10 966 12-08-2024, 09:04 PM
  What is the fork oil level for a Honda CB1100 RS 2017? motorducquangngai_imp 1 315 10-03-2024, 01:36 AM
  Parts for my 2013 Honda CB1100 Saarang_imp 5 535 08-15-2022, 03:10 PM
Last Post: rboe
  Looks like I'll have to install some heated grips .... ohiorider_imp 15 1,235 10-17-2018, 04:06 AM
Last Post: ohiorider_imp
  Advice on removing Honda and CB1100 badges ManInBlack_imp 7 601 08-16-2017, 10:48 AM
Last Post: ManInBlack_imp
  Winter Storage - thinking of a heated crate buckwheat_imp 14 1,371 06-25-2017, 10:57 AM
Last Post: stateboy_imp
  17 Honda CB1100 EX For Sale Melbourne, FL clearviewx 18 1,391 06-03-2017, 10:07 PM
Last Post: the_undecider_imp
  2017 Honda CB1100 EX Anticipation Thread Stichill 43 2,913 12-22-2016, 09:36 AM
  2017 Honda CB1100 EX MSRP clearviewx 59 3,580 12-19-2016, 12:13 AM
