First Oil Change
K and N have a CB1100 filter (KN-204). It has a hex extrusion which allows a spanner on it. Probably even a torque wrench if you have OCD. OCD or not, don't forget to apply a little oil to the O-ring before tightening.
[Image: 24259da7bdc2f3838973211abd2db795.jpeg]
Or use a "ripper gripper" like this:
[Image: d148528f16f4351428d8784fc40ce199.jpeg]
As for oil. Why even ask. There is only one answer.
[Image: 974793e4f28310ac4fdedb16e601ca57.jpg]
HUBRIS is a fully synthetic Omni Grade Motorcycle Oil. It is especially formulated for the CB1100. It is, despite being synthetic, a fully natural, grass fed, cholesterol and gluten free product. It is approved by the UNHCMO*, the IPCC and the CIA. It is guaranteed to eradicate and/or prevent engine noises, rattling, sputtering and vibration, frame rot, suspension chatter, brake binding, steering oscillatiions and other common CB maladies. A drop or two applied to the ECM will remove all limiters and result in massive increases in power and torque. It also may be effacious in the prevention of high side, low side and other rider induced moments. It is rumoured that a certain very successful MotoGP racer uses HUBRIS. To obtain Dr Dactyl's HUBRIS oil please send to Dr Dactyl your credit card details by Email. Large cash deposits can be made to my account at the Bank of Abuja, Nigeria. Be quick, it is in very short supply.
* the United Nations High Commission for Motorcycle Oils.
The oil filter is tightened with a torque of 26 Nm. That's heck of a lot for an oil filter. The ones I have known so far get just tightened by hand.
You can order the Honda oil filter as a set of filter + hex nut, so you can use a standard tool and a torque wrench to mount that beast.
The Honda part# of the set is 15010-MCE-H51 and you can see it here, ref# 2:
http://www.hondapartshouse.com/oemparts/...n-oil-pump
The filter alone is ref# 13.
Django, you're right. Tightening a lubricated oil filter other than by hand, or simple tool as pictured above, is fraught with danger.
I gotta get me some of that HUBRIS.
LongRanger,
BE CAREFUL!!!!! [url=http://cb1100forum.com/forum/showthread.php?tid=5796&pid=88675#pid88675]READ THIS FIRST. See the end of the post.
Thank you! I am enlightened. Great post!
AMSOIL MCT 10W30 for a smooth shift with lightThumbs UpThumbs UpThumbs Up
Got it changed today at 621 miles...plenty dirty.. new filter as well..no trouble getting original filter off as I used a vise grip tool as mentioned previously...Very easy job...filter and oil plug very accessible.
  Time to change Obleo 4 358 08-26-2020, 10:51 AM
  ‘13 Change the clock? Jalsar27_imp 12 1,116 11-06-2018, 02:28 AM
Last Post: Nortoon_imp
  Oil change... Randy B 14 984 03-10-2017, 10:59 AM
Last Post: Randy B
  2 Years without an Oil Change Bighonda14_imp 39 2,347 07-23-2016, 11:03 PM
  Tire Change JF Coastal_imp 9 652 03-07-2016, 12:06 PM
Last Post: LongRanger_imp
  A change is gonna come.... hondahoarder_imp 36 2,332 10-23-2015, 04:15 PM
Last Post: capttwb136_imp
  somethings never change gossman_imp 13 1,047 09-12-2014, 10:38 AM
Last Post: Blockhead_imp
