recommendations on upgrades
(10-16-2016, 12:10 AM)The ferret_imp Wrote: Funny, I find the stock suspension way too stiff and have mine set on full soft all the way around. At 200 lbs geared up you wouldn't think that the case, but I prefer a softer ride rather than a taut " racer" ride, and right now, even on full soft it beats me up like getting hit with a 2x4 in the tush going over any bump.
Let me rephrase the fronts were to soft that it jarred very hard. Rears are set mid to firm and are to bouncy ... I'm 240 plus gear and ride fairly hard.
I did a big twisty ride last week and had to pull over to tighten up the front. Waaay to soft and unstable when pushed hard. Especially in downhill corners. Couple turns on the adjustment screws and she's capable. Not great, but capable.
As for the rear I have no problen with the stock springs.
Like someone mentioned earlier I don't think you'll get much gain from a pipe with out doing a full system sans cat.
Good luck and let us know how you get on.
Running with the rear shocks at "full soft" (i.e. zero preload) but with greater-than-designer-anticipated weight will reduce the rear suspension travel, and thus make the rear more likely to bottom out going over bumps. So for you guys with more meat on your bones, adding some preload may actually smooth the bike out.
(10-17-2016, 05:54 AM)feralchimp_imp Wrote: If someone would post a link to those Ikon rear shocks, I'd appreciate it.
I highly recommend an Alaskan Sheepskin Butt Pad (actually product name). Night-and-day distance comfort vs. the stock seat. If I had to do it over again, I'd probably get one big enough to cover the pillion too.
Here is the link to Ikon USA, but it looks like they are in the progress of updating their web site.
https://www.ikonsuspensionusa.com/shop/7610-1507/
  Windshield Recommendations White Dog_imp 56 3,733 07-06-2021, 03:06 AM
  Tail bag recommendations? Scotty_imp 16 1,116 09-09-2020, 05:08 AM
  How common are wheel & suspension upgrades? Syscrush_imp 8 650 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Thoughts on the 2017 'engine upgrades' PowerDubs_imp 12 731 06-27-2017, 08:45 AM
  Recommendations for Honda dealer in Canada Elipten_imp 3 267 05-05-2014, 08:07 PM
Last Post: Rocky_imp
