Why don't old motorcycles need a distributor?
So, just to keep it simple, lets talk about the CB750 SOHC and the 1&4 cylinders and static timing. First you set the gap by lining up a particular mark on the points plate with another point on the crankcase. Next you set up a test light or continuity meter so you can tell when the points are open or closed. Finally you adjust the plate so that the points open (light goes out) when a different mark on the plate lines up with the F (for 1&4) on the crankcase. Is that right?
Somebody mentioned marks on the stator and that *really* confused me but apparently on some bikes you remove the stator cover to find your alignment marks in the second step.
Also, I don't understand "dwell". One video seemed to suggest that you set dwell when you adjusted the gap properly.
This is all academic, just trying to understand how these old bikes work.
Ignition dwell is the time when the points are closed. 0.02
Ah, the fog is clearing.
  Richard Hammond's motorcycles Cormanus 2 378 11-06-2025, 03:03 PM
Last Post: MagnaRider
  Race to the Clouds..motorcycles now banned the Ferret 10 897 08-15-2021, 12:20 AM
  Updated Honda motorcycles Roper_imp 30 2,599 03-07-2021, 07:51 AM
Last Post: Allen K_imp
  Italian Motorcycles on display at the Petersen Gone in 60 7 823 01-28-2020, 09:14 AM
  Kawasaki and AI for motorcycles curlyjoe 4 456 02-15-2019, 04:12 PM
  The 11 Most Important Motorcycles of All Time Rebel73_imp 9 776 02-13-2019, 06:54 AM
Last Post: Django
  If You Could Own Just Three Motorcycles.... emptysea 65 5,892 02-10-2018, 05:56 AM
Last Post: Ulvetanna_imp
  Bicycles to Motorcycles, Ships, and Planes Ulvetanna_imp 3 340 11-21-2016, 08:37 AM
  New TV show with motorcycles the Ferret 17 1,172 08-14-2016, 05:58 AM
Last Post: kmoney_imp
  Motorcycles the Ferret 25 1,946 10-30-2014, 10:34 AM
