Stupid question
(10-23-2018, 04:21 AM)gogoAZ_imp Wrote:
(10-22-2018, 08:55 PM)Houtman_imp Wrote: As soon as I got my 2017 I put RIDE ON in both tires , this is different and better than SLIME , Google Ride ON to see for yourself.
How has this stuff worked out for you?
How has this stuff worked out for you? I haven't got a flat tire yet on the 2017 so I do not know !
If you Google Ride On it seems to work ok.
Make certain that you order enough as it is not easy to get the last drop out of the bottle.
From the horse's mouth:
https://www.ride-on.com/us/support/technical-faq
Q: Does Ride-On work in tube and tubeless tires?
A: Ride-On will eliminate 85-95% of your flats in tubeless tires from objects up to 1/4" (1/8” for tube tires) that penetrate the contact area of your tire. Ride-On’s efficiency in tube tires is reduced to 55-65% since puncturing objects often tear the tube. It is impossible for a tire sealant to seal a tear. It is vital to remove the puncturing object immediately from a tire containing a tube to prevent further damage that can result in tearing the tube.
The last flat I remember having was on the rear a Honda circa mid seventies.
It occurred under WOT acceleration off the line.
Whatever it was ripped the tube so quick it went instantly flat
I did with this result, no mistake: Huh
https://www.google.ca/search?ei=-JzPW975...UNqYvuLEcg
Smile
The Ride On website did come up !
When I found out Dunlop replacement tires for my 2017 CB1100 EX were not available in North America, I looked at what was used on the Triumph Bonneville models: Bridgestone and Metzeler.
I wanted to buy Avon Roadrider tires. But the sizes needed were not available at that time, but they are now.
(10-22-2018, 02:12 PM)Cormanus_imp Wrote: There are varying views on the Metzler Z8— http://cb1100forum.com/forum/showthread.php?tid=6101
Django, who racks up a good few miles likes them.
I also have about 2600 miles on a set of Metzler z 8 tires. So far they seen to be wearing very well and I really like the feel of them. Excellent in the rain
Stock sizes available front and back
Sent from my Moto E (4) using Tapatalk
  Stupid Honda touch up paint kit! Ghis_imp 5 478 06-02-2015, 10:30 PM
Last Post: CB4ME_imp
