Tempted To Trade Her In
(09-23-2018, 10:53 AM)The ferret_imp Wrote: Doc...just going by things I have heard... Isn't the life expectancy of a belt generally less than that of an oring chain? Doesn't it take a specific tool to adjust, and isn't it very difficult to replace?
I am still on my original belt with 110,000km (68,000 miles) and still have room for tightening yet.
Based upon input on the XLForum, life expectancy is very long. Howver, a pebble thrown between belt and pulley can beak it...they do not stretch at all...adjustment is seldom required. When tension warrants adjustment, just move the axle, as on a CB. Slack is measured same as chain.
Never had to replace, personally, but have high-mileage friends who has done it on the road. I understand about the same as replacing a closed loop chain (pull axle, remove one shock).
I was cautious on fire roads, but no problems.
Taking youngest grandson to ranch in Arizona, tomorrow...no email or internet for 3 days. Have a safe trip!
(09-23-2018, 08:23 AM)LongRanger_imp Wrote: I'm seeing loads of K1600GT's on the roads these days, and far fewer RT's than in the past.
This might be another consideration.
I went on a spirited ride last weekend with five BMW's from my little town with a population of 3000.
Two of them were K 1600's just like mine ( well one was a GT and one was a GTL but close enough) the other two were RT's. They were all old men just like me most of them retired.
I learned Indiana has more curvy roads than I thought and I'm not the only one that likes the curves :-)
This in contrast to nearest CB is like a hundred miles from me.
My point is you may find more people to ride with certain motorcycles than you do others.
Interesting. ONe time when I was researching the differences between belt, chain and shaft for life expectancy, servicability etc for an internet conversation, I thought I had read the belt should be replaced every 25,000 miles, that belt tension was measured with a tool nobody but the dealer had, and that replacing it was a hard as replacing the clutch on a BMW.
My Road King has its original belt at 28,000 miles. On visual inspection, it looks just fine. I can't remember the last time it needed adjustment between tire changes. There is a special tool to check tension, but it is a little spring loaded thing and is cheap to buy, although with a bit of experience you don't need it. All that said, to replace a belt on my Road King requires removal of the swingarm, which requires pounding the rear swingarm bolt out from rubber bushings called cleveblocs, which can be an enormous pain. Once that is done, you have to remove the inner primary, which is another major disassembly headache. Off comes the outer cover, then the stator and compensator, along with the clutch to get the primary chain off. Mine is a bit older so the exhaust system comes off to access the starter, which also comes off. It is not a roadside affair.
The belt on my F800GT has a recommended 24,000 mile replacement interval but can be changed on the side of the road in about thirty minutes (so they say).
I decided to keep my 2016 CB1100.
Things didn't feel right at the Harley dealership today. Riding my CB home felt good. I could breathe, relief. Got a great bike that I can trust and a dependable dealership that knows me by name and a forum that has gobs of knowledge about my bike. The riding season is almost over up here anyway. I'm going to place an order with Samurider and get a slip-on for the Girl instead...
Good for you. Walking away because it didn’t feel right was sensible. There will be other chances if the urge comes again.
That sounds more like what I read when I was doing the research. Maybe Sportsters are different?
(09-24-2018, 07:16 AM)Mandrau_imp Wrote: I decided to keep my 2016 CB1100.
Ya know Mandrau if you change your mind someday down the road, you can always sell the CB and get a Harley. In the meantime you have a terrific machine to ride.
Very pleased to hear this .
  New CB 1100 deal cash and trade calipo223_imp 15 954 04-25-2018, 11:28 AM
Last Post: gtmn_imp
  "Hypothetical" Trade-In emptysea 41 3,960 07-23-2017, 03:01 AM
Last Post: Guth_imp
  Sell or trade your CB1100 for a 2017 CB1100 TCBronson_imp 66 4,062 03-16-2017, 08:02 AM
Last Post: Hondahawkrider_imp
  13 trade sell value recent info. Romo1969_imp 7 544 02-19-2014, 03:28 AM
Last Post: Red Mist_imp
  Trade a '13 for a '14 EX? How much will it cost? ride4now_imp 100 6,298 02-17-2014, 08:25 AM
Last Post: Romo1969_imp
