Raising CB1100 onto centerstand
A little tougher getting it on the center stand than my '77 cb750f because of weight. More of a challenge getting it off. Loves to slide on a garage floor. Installing the stock luggage rack makes it much easier to lift onto the center stand.
I grab the cb by the handle bars and rear rack, lift it straight in the air and then flip the centre stand over with my right foot and put it down, but only when I'm angry...and you don't want to see me angry.
I read on the ctx forum about how some people buy the wrong centre stand, because no centrestand existed for the ctx700. People would modify an nc700s stand to work, and some would buy the nc700x stand which doesn't work. The local dealer had trouble installing my centre stand and had to take it off to order the part I told them they would need when I ordered the thing. Anyways I get it home, not 100% confident in their abilities and tried to get it on the centre stand, by stepping on it and pulling with both hands from the handle bars! Then I watched a YouTube video after I nearly gave myself a hernia and I found both bikes to be a snap to get on the centrestand.
I push straight down with my foot while pulling straight up. Sort of like pulling it apart. Stiff soles and start with it level. Helps to weigh 250.... Wink
Ben
I agree with the stiff sole. I've put my deluxe up with worn out tennis shoes and beefy Danner boots. Night and day. Boots for the win!
(06-22-2017, 09:14 AM)Graymark_imp Wrote: A little tougher getting it on the center stand than my '77 cb750f because of weight. More of a challenge getting it off. Loves to slide on a garage floor. Installing the stock luggage rack makes it much easier to lift onto the center stand.
I solved the slick garage floor problem with a small piece of carpet positioned for the center stand, then you can push right of. Have to try the wood under the rear wheel trick to ease getting it on the stand.
I don't think a wedge under the rear wheel would make mine easier. Backing it out of the garage onto a sloped driveway does though. Maybe I should put the wedge down and drive the front wheel up on it. Then lift the bike off the side stand and onto the center stand.
I do have a 2'x4' sheet of 1/8 inch hardboard under my CB1100 EX. I used it to keep the garage floor clean when oiling the chain on my CB500XA. The hardboard does not move when I put the EX on the center stand.
Learned a trick from Lemmy of Revzilla watching his chain oiling video. I used to put a piece of cardboard behind the chain to catch any misplaced oil when spraying my CB500XA chain. But using his technique of holding the spray can tube against the rear sprocket directs the oil right down onto the chain rollers. Any excess that drops off the chain, can be wiped off the hardboard with a couple of shop towels.
I find that much of the center-stand issue on these bikes is psychological. At ~210lbs, I was having trouble with it at first. Part of the problem was overcoming the fear that I would drop the bike. Once I fully committed to it, put my weight on the stand and allowed the laws of physics to take over, it was a piece of cake.
(06-26-2017, 07:15 AM)Rebel73_imp Wrote: I find that much of the center-stand issue on these bikes is psychological. At ~210lbs, I was having trouble with it at first. Part of the problem was overcoming the fear that I would drop the bike. Once I fully committed to it, put my weight on the stand and allowed the laws of physics to take over, it was a piece of cake.
Yep. Push down hard with your foot while pulling up on the back of the bike. Cake.
Totally agree. It was difficult at first because I didn't want to drop her and the hesitation was robbing me of the momentum I needed. Now I pop her onto the center stand every time I'm in my own garage.
Press down on the stand lightly until contact with the ground-and then the most important part- make sure both sides touch so the bike has 3 points of contact.
If that is done- then the bike will be stable and pop right up.
If you are trying to put it up while it is leaning a bit towards you- good luck.
  Moving a bike in tight quarters - Centerstand dolly pekingduck 50 3,961 12-11-2022, 12:59 PM
  Centerstand leans me a touch glenridgerich_imp 23 1,991 05-29-2021, 06:59 AM
  Put bike on centerstand the Ferret 148 14,523 05-17-2020, 12:06 AM
   Centerstand - Noob question... quietguy_imp 27 1,754 12-18-2015, 06:19 PM
