Pretty Much My First Big Boy Long Trip Ever
tod.branko_imp Offline
Threads: 19
I used to use WD-40 for a clean-up and then apply gear oil, but gear oil would spray all over the wheel and chain guard and front sprocket cover, so I decided to go with something specialized, I used Petronas, but currently on the muc-off cleaner and dry-lube, they are very clean, and smell nice (unlike gear-oil)
Mentioning front sprocket cover, I wanted to ask how often you take it off and clean it up from the inside, and give the sprocket and scrub and lube?
'14 CB1100 STD 5 speed
08-19-2021, 05:20 AM
RE: Pretty Much My First Big Boy Long Trip Ever
(08-19-2021, 05:20 AM)tod.branko_imp Wrote: I used to use WD-40 for a clean-up and then apply gear oil, but gear oil would spray all over the wheel and chain guard and front sprocket cover, so I decided to go with something specialized, I used Petronas, but currently on the muc-off cleaner and dry-lube, they are very clean, and smell nice (unlike gear-oil)
Never.
I have always let it cake up nice 'n' thick.
(Give me my shaft!)
08-19-2021, 05:45 AM
NHCB1100_imp Offline
Threads: 1
I’m pretty much the same as tod with great luck. Muc off every 500-600 miles and then maxim wax. Works great and tod is right.....these newer products even smell good.
When I used to use oil lubricants I’d remove front sprocket cover every year or so and clean up the mess. Since switching to the newer wax product there really hasn’t been anything to clean when I’ve looked under the front cover and at the sprocket.
I’ve been really amazed at how well the wax products work.
08-19-2021, 05:58 AM
I used chain wax products for several years some 10 years ago. But in winter my chain still corroded orange because of the dang road salt.
So for the past many years I let the passive [url=https://www.tutorochainoiler.com/]Tutoro chain auto oiler do all the work.
08-19-2021, 06:33 AM
Threads: 19
(08-19-2021, 06:33 AM)GoldOxide_imp Wrote: I used chain wax products for several years some 10 years ago. But in winter my chain still corroded orange because of the dang road salt.
We don't get winter [Image: 71dcf7e6c9fcfb385bbb5187204bf43d.png]
08-19-2021, 06:38 AM
DRB146_imp Offline
Threads: 2
#26
(08-19-2021, 04:15 AM)Tev62_imp Wrote: WD40 also make a chain lube, DRB146 may of been referring to that.
Yeah, no… I appreciate the potential smarts, but I just threw the good ol regular stuff on there. As I mentioned, this particular ride was “get up and go”. But thank you all for the heads up!
08-19-2021, 01:35 PM
j3gq_imp Offline
Threads: 78
#27
So another nice, interesting thread slowly turning into a chain lub, oil & tire thread, gime a break, guys.
Back to confidence building. My fav road after a longer break is a local parking garage, with spiraling ramps from deck to deck. Try it if you find one. The turns are tight, and they are as hard as twisties in the mountains.
One other tip, follow your guts. If it feels as if a spectator “might think” you’re too slow for this bent, ... fine, so be it. Remember, most spectators sit in a very stable and safe 4-wheeler.
08-19-2021, 01:36 PM
  Long Beach to Portland Gone in 60 11 751 07-29-2022, 05:39 AM
  1st long ride Jeffhorn_imp 8 632 05-21-2021, 10:16 AM
  CA winds make pretty views Gone in 60 15 825 02-03-2020, 01:06 PM
  Long Ride Saturday Foothills Parkway TwoBrothersBusa_imp 8 516 04-06-2019, 11:52 AM
  LONG TRIP ALONG NORTH SIDE OF ST. LAWRENCE RIVER peterbaron 15 906 08-02-2018, 09:10 AM
  Really Long Distance Riders Mscb1100_imp 1 212 05-12-2018, 11:42 AM
  To Waycross the Long Way redbirds_imp 12 710 02-21-2016, 12:37 AM
Last Post: capttwb136_imp
  Riding the Rockies (long overdue post) flynrider 21 1,145 10-06-2015, 11:53 AM
Last Post: flynrider
  Holland, MI: A First Timer's Long Trek Experience specialist8 6 371 09-18-2015, 03:43 PM
Last Post: JustPassinThru_imp
  Long Tan day. Pterodactyl_imp 5 414 08-19-2015, 01:22 AM
Last Post: Dharma_Jones93_imp
