Farklin the Fourteen
Likes Given: 747
RE: Farklin the Fourteen
(04-06-2014, 10:59 PM)ss2wheels_imp Wrote: Ferrit, put a small piece of rubber hose on your spare key and it wont scratch anything, just slide it off when you need to.Idea
Dang, why didn't I think of that? Sometimes the best solutions are the simplest. Good plan SS, one I will implement. Thanks!
04-06-2014, 11:44 PM
Likes Given: 747
Got some more done today since it's pouring down rain outside
Got my battery tender pigtail hooked up
[url=http://smg.photobucket.com/user/theferret111/media/Batterytenderpigtail_zps67f97fdc.jpg.html][Image: 1299bcd468f63cf08d108afa1e994f12.jpg]
Decided angle of bars was good so no adjustment needed
Got my clutch and brake levers adjusted both for angle and span.
Got the throttle play set to the low side of the spec
dropped my rear shocks into the lowest slot for now
and got a piece of clear hose over the end of the key on my key ring that goes to my helmet guardian as SS suggested (good tip)
04-07-2014, 04:45 AM
Aussie_imp Offline
Threads: 2
(04-06-2014, 02:31 PM)The ferret_imp Wrote: Aussie easiest way if you have an air compressor is to remove bar ends weights then blow off old grips by wedging air nozzle under outside lip of grip. When you hit it with air, it will expand and pull right off..almost fly off as a matter of fact. Then start the new grip on, stick the air chuck in , kind of close the end of the grip around it and blow the new ones on. OR spray some hair spray or contact cleaner in the new grips, sling out amy excess and slide those puppies on. Be careful not to get the throttle side tight against the throttle housing which may keep the throttle from returning.
If you don't care to save the old grips and don't have air, you can always use a razor blade and slice them off. Remember there is a plastic throttle tube under the throttle grip.
Then put your bar end weights back on
( I use the air from the other end not like this guy but you get the drift)
http://youtube.com/watch?v=xg3w1YnQBVo
http://youtube.com/watch?v=tL3_3_4pdcY
Thanks for the tip. I don't have compressed air but the old grips came off easily with a bit of WD40 and a thin screwdriver. New grips feel good Thumbs Up Not quite the same as having a whole new bike though!
04-07-2014, 08:55 PM
Threads: 346
Likes Given: 961
Ferret & Aussie, can you tell me why you've replaced the grips?
04-07-2014, 09:57 PM
Likes Given: 747
Personally, I really like the feel of the 719 Progrip. I've used them on every bike I've owned including the scooters for years. I have them on my ST and on my wife's Majesty too. The only exception was the Bonnie which had 1" bars. A little softer and stickier than the Honda grip and being a gel grip maybe that's why I don't feel the vibes thru the grips that some people speak about.
04-07-2014, 10:11 PM
Aussie_imp Offline
Threads: 2
#26
(04-07-2014, 09:57 PM)Cormanus_imp Wrote: Ferret & Aussie, can you tell me why you've replaced the grips?
The OEM grips are ok; I was just looking for something a bit softer and with a bit more grip. I saw them on Ferret's bike and thought I'd give them a go.
Just installed tonight, was easy and quick. Went for a quick spin, new grips and now sans Dart. First impressions are good in terms of comfort so I'm happy.
A cheap little mod and a bit of fun allowing me to tinker around a bit... allows me to put off spending big $$ on a new seat, headers, luggage etc etc!!!
04-08-2014, 12:21 AM
howlindaug_imp Offline
Threads: 1
#27
Ferret, Wow!, that's how to share info. Great photos, descriptions, it helps a lot. Thank you!
BTW, where can I get the shock spanner for a 2013? I need to tighten mine up a tad.
04-08-2014, 04:40 AM
Likes Given: 747
#28
(04-08-2014, 04:40 AM)howlindaug_imp Wrote: Ferret, Wow!, that's how to share info. Great photos, descriptions, it helps a lot. Thank you!
Ill take a pic of the things in my tool kit. I got everything I needed at a little speed shop up the road that buys wrecks and redoes them ... buckets full of stock Japanese tool kit tools cheap. 25-50 cents each. You might ask at your motorcycle shop if they have any old tool kits laying around or if there is a bike junkyard nearby they would have them too. I got shock spanner, axle wrench and extender, 8 and 10 mm wrenches etc.. Everything I need to adjust shocks or chain on road for like $4
04-08-2014, 05:29 AM
CB4ME_imp Offline
Threads: 183
#29
I'm still using the tool kit that came with my 1978 GS1000. Bike was totalled but I kept the tools.
04-08-2014, 06:24 AM
Likes Given: 747
#30
Under the seat in tool tray
[url=http://smg.photobucket.com/user/theferret111/media/CBtools001_zps891aacbf.jpg.html][Image: 9e2078844bca587a73455d93f8b2a1e2.jpg]
Can of chain lube, shop towel, disposable gloves, 5 mm allen wrench for side covers, screw driver for battery tray and battery posts, 8x10mm open end 8mm for chain adjuster and 10 could be used for battery posts, 32 mm box end and extension for rear axle nut (*see note below), shock spanner tool, fuse puller and spare 7.5 amp fuse for battery tender jr pigtail for when using pig tail with small air compressor
[url=http://smg.photobucket.com/user/theferret111/media/CBtools002_zps66113067.jpg.html][Image: 926138cc843c47bef38a940ef2f4e5c6.jpg]
* note.. just found another difference between 13 and 14. My 13 had a rear axle nut that requires 32 mm wrench. The 14 has a rear axle nut that requires a 27mm wrench so I have to go find a new wrench lol.
04-08-2014, 06:53 AM
