Flashed CB1100 Review
Threads: 700
Likes Given: 866
RE: Flashed CB1100 Review
(05-02-2014, 07:52 AM)CIP57_imp Wrote:
(05-02-2014, 07:11 AM)Tortuga_imp Wrote: At last some conclusion to this whole debacle.
I have to say, if all this expense and drama nets us only around 10 mph, bearing in mind that was on the centre stand, no drag, now wind resistance, no tyre friction or heavy rider to carry.... Is this all placebo and did Honda just get it perfect to begin with?
I can count on no hands the number of times that extra 10mph OVER 112 mph will be essential, or even useful.
Just sayin' Beer
Why I respond to this im not sure, it was I demonstration, could have buried the speedo since bike is limited to 186
It would have buried my 2014 Dlx speedo Wink
05-02-2014, 08:49 AM
Tortuga_imp Offline
Threads: 23
I'm leaving this thread alone, since arguing with the tuning fraternity is tantamount to shagging ones daughter it seems.
Bye, Hello
05-02-2014, 08:54 AM
avsbezzy_imp Offline
Threads: 6
That 130 mph on the center stand made me laugh....I owe you a cold one for that.
05-02-2014, 09:04 AM
Threads: 349
Likes Received: 941 in 515 posts
Likes Given: 1,105
Thanks CIP. Glad to hear the result is positive. And that this can be done successfully as the experts predicted.
05-02-2014, 09:11 AM
thessler3_imp Offline
Threads: 7
CIP57 you have done many of us a great big favor by getting your ECU reflashed. Can you do us a second favor and repost the exact details of where you had it done and whether the ECM had to be drilled and any other pertinent details?
05-02-2014, 10:54 AM
CIP57_imp Offline
Threads: 68
#26
(05-02-2014, 10:54 AM)thessler3_imp Wrote: CIP57 you have done many of us a great big favor by getting your ECU reflashed. Can you do us a second favor and repost the exact details of where you had it done and whether the ECM had to be drilled and any other pertinent details?
http://guhlmotors.com/
The contact is Don. The unit does not have to be opened or drilled.
(05-02-2014, 07:02 AM)HikerToo_imp Wrote: How is the exhaust sound, any gurgling or backfiring when you let up? ( I forget if your exhaust is stock or nor.... )
And the big question "Was it worth it, would you do it again, would you recommend to a friend?"
Hiker,
My bike is stock, the back pressure has not changed so no there is no ill effects regarding exhaust issues, in fact with less engine braking it might be minimized.
Was it worth it, indeed, let forget about the limiter, more low end torque, snappy throttle response with less throttle input and all for the cost of a set of side covers. Yes, i would recommend it to anyone regardless of how the ride. Who would not want a bike that responds better.
05-02-2014, 11:07 AM
xpacpal1x_imp Offline
Threads: 4
#27
Would the reflash improve throttle response and other engine performance attributes of a CB1100 that already has 1) Staintue exhaust, 2) PowerCommander V, and 3) professional dyno tuning?
05-02-2014, 12:57 PM
Red Mist_imp Offline
Threads: 12
#28
(05-02-2014, 12:57 PM)xpacpal1x_imp Wrote: Would the reflash improve throttle response and other engine performance attributes of a CB1100 that already has 1) Staintue exhaust, 2) PowerCommander V, and 3) professional dyno tuning?
Yes, just let Don know exactly what you've done to the bike. If you have PCV, he can do the reflash for the stock ECU and fueling adjustments are then made using the PCV, however, a dyno is needed to get those right.
The reflash will remove factory detuning (restrictions) in the first four gears, change the way the engine responds (much more lively whilst increasing power everywhere), and of course remove the top speed limitation. Engine braking can also be reduced, you can ask about that as it's adjustable.
05-02-2014, 01:03 PM
hedstrom_imp Offline
Threads: 2
#29
CIP57 Wrote:
"Yes, i would recommend it to anyone regardless of how the ride. Who would not want a bike that responds better."
Tortuga
(05-02-2014, 05:42 AM)CIP57_imp Wrote: Installed the ECU put the key in, no FI codes (phew) started her up and idle was perfect still no FI codesThumbs Up
Warmed the bike up and checked the limiter ( see pic ) limiter is gone, there will be a time and place to check it, today was not the day.
Realized gains:
Stock 0-60 4.2 0-100 8.9
Flashed 0-60 3.7 0-100 8.3
I figured on these gains with the timing retard gone.
Whats impressive is the throttle response at 1/4 and 1/2 opening in lower gears. You just have to touch the throttle and the bike responds.
I assume i will be getting better fuel mileage and will report after a few tanks at normal riding conditions.
The front wheel gets real loose in first gear but not off the ground, same as my GS1100 but does not make the crazy power on top. HP gains i think are minimal, if i had to guess i would say about 5hp on top but more in the lower gear mid-range.
I think there's more to get out of the motor with a dyno tune, but I'm very happy with the way it runs now. Fueling is still spot on with no dead spots.
We'll that's it in a nut shell, I hope this helps those who are interested.
Edit: almost forgot, on off throttle response is sooooo much better Thumbs Up
What about the Rev limiter?
05-03-2014, 01:32 AM
PAULIBIKER_imp Offline
Threads: 7
#30
Realized gains:
That's worth it right there.
All about driveability IMO. Especially on the CB1100, a bike made to "enjoy the ride".
05-03-2014, 01:59 AM
  Hagon Rear Shock Review dUh! 2 518 09-18-2022, 10:55 PM
Last Post: KiowaEagle_imp
  Samurider Paniers-review + pictures tomas_imp 76 7,856 05-03-2022, 02:35 PM
Last Post: ChiefJP_imp
  Daytona Cozy Seat - A Review motoWest_imp 11 1,204 06-06-2021, 06:09 AM
Last Post: JLEECB
  Dart Marlin Flyscreen - A Quick Review the_undecider_imp 70 7,189 12-10-2019, 02:16 PM
Last Post: jimgl3_imp
  Yoshimura RS3 Exhaust Can install and review Frulk_imp 4 520 11-02-2018, 06:57 AM
  My $8 helmet cam review use2b_imp 9 1,297 05-04-2018, 04:47 AM
Last Post: chync_imp
  Ryujin Exhaust System Review Magnus_imp 9 885 02-10-2016, 01:19 AM
Last Post: NightRider_imp
  Matching helmet/Shoei NeoTec review Papa Weeley_imp 17 1,436 10-20-2015, 09:21 AM
Last Post: Desert viper_imp
  Bridgestone Battlax T30 Review lola_imp 19 1,547 03-26-2015, 05:30 AM
Last Post: lola_imp
  Ryujin Seat Review xpacpal1x_imp 10 886 01-05-2015, 03:48 AM
Last Post: Timpo_imp
