Review Michelin Road 3's
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
RE: Review Michelin Road 3's
Contour is much more critical than width. Flatter tires slow down your steering, highly rounded one speed it up; makes the bike much more flickable. Discovered that going through tires on my Quota. With the right tires a buddy on a GXR600 thought my riding was "spirited" - the Quota has a 21" front tire. Smile
I also see the difference between my Griso and the CB1100, similar sized bikes and weight. The CB is much lighter on her feet, more flickable and a delight in the tight twisty bits.
06-03-2014, 12:07 AM
thessler3_imp Offline
Threads: 7
Just a quick comment about the true definition of aspect ratio. It is simply the height of the tire as a percentage of the width in millimeters. For example the 140/70X18 tire on the CB1100 is 140MM wide and 98MM (0.70 X 140) high.
If you switch to a 160/60 tire, the height is 96MM (0.6 X 160). Just a smidge smaller in diameter than the stock tire.
I have worn out many sets of tires on both sport and touring bikes. My personal favorites are Michelin Pilot Power 3's for sport bikes and Pilot Road 2's for sport tourers. Unfortunately, neither are made in sizes to fit the CB1100.
Michelin does not make tires for my Gold Wing and I have tried both Bridgestones and Dunlops - a toss-up.
I would be very reluctant to put bias ply tires on the CB1100 as some of you suggest.
06-03-2014, 11:05 AM
Red Mist_imp Offline
Threads: 12
(06-02-2014, 02:57 PM)lola_imp Wrote: To Bad Bridgestone is withdrawing from Motogp in 2016 and michelin is taking over. Motgp riders are having mix thoughts about the change though.
Would love to see Dunlop back. Actually I would love to see it go back to a non-spec tire.
(06-03-2014, 11:05 AM)thessler3_imp Wrote: Just a quick comment about the true definition of aspect ratio. It is simply the height of the tire as a percentage of the width in millimeters. For example the 140/70X18 tire on the CB1100 is 140MM wide and 98MM (0.70 X 140) high.
Don't be. I'm using the BT45s and as I have stated my experience in other threads, I can affirm they are excellent tires. We used these tires on bikes far more capable than the CB1100 back in the day and they are much, much better now, with dual compounds and more advanced construction and formulation.
I just returned from an overnight trip and rode the most difficult paved roads in this part of the state, bumpy, narrow, 15 mph switchbacks to 90 mph sweepers, hundreds of miles of this stuff.
I was very impressed with grip and handling.
Running 32 psi front, 36 psi rear but will go down to 35 rear as the temperature increase is not sufficient.
However the radials do seem to ride a little smoother.
06-03-2014, 12:30 PM
Jim21680_imp Offline
Threads: 4
Now that 160s appear to be acceptable, anyone give any thought to trying the Dunlop Roadsmart II's? I'm pretty sure they can be had in the same sizes as the Pilot Road combo.
06-03-2014, 12:48 PM
CIP57_imp Offline
Threads: 68
(06-03-2014, 12:48 PM)Jim21680_imp Wrote: Now that 160s appear to be acceptable, anyone give any thought to trying the Dunlop Roadsmart II's? I'm pretty sure they can be had in the same sizes as the Pilot Road combo.
Tire has very good reviews on bikes of similar weight. I don't think you can go wrong with a set of these. Try them out and give us a reportThumbs Up
06-03-2014, 08:58 PM
CIP57_imp Offline
Threads: 68
#26
Fuel mileage with the new tires is above my normal range. I averaged 54 mpg with my last tank. Usually average 48-52 back roads and highway. The slightly lower profile i though may decrease mileage but that's not the case.
[url=http://s1034.photobucket.com/user/cipolla57/media/photo_zpsa630c020.jpg.html][Image: 3744bf702b35edd2594b2e6aa33c9788.jpg]
06-04-2014, 09:43 PM
Threads: 12
#27
With the BT45 150/70, the pressure increased to a little more than I was looking for on the rear tire; it went up to 38.5 psi, running 34 psi. So 36 is the minimum for me as it will give a margin for error. Don't want any more than about a 10% increase in pressure, cold to hot. Would not run lower than that for anyone if you are doing freeway.
06-05-2014, 08:12 AM
Tortuga_imp Offline
Threads: 23
#28
(06-01-2014, 10:50 PM)CIP57_imp Wrote: here's the pic from the rear
[url=http://s1034.photobucket.com/user/cipolla57/media/DSC_2742_zpsfa75370f.jpg.html][Image: 7baef33eca348e051166d4e70aff01a5.jpg]
Meaty! I love it...
Clap
06-05-2014, 08:23 AM
Ridem32_imp Offline
Threads: 51
#29
It does look a lot wider on the bike! Maybe just my eyes!!
06-05-2014, 09:08 AM
Tortuga_imp Offline
Threads: 23
#30
(06-05-2014, 09:08 AM)Ridem32_imp Wrote: It does look a lot wider on the bike! Maybe just my eyes!!
No it's definitely a chunkier look. I really like it. Maybe the whole 'retro thing' is wearing off for me? Sad
06-05-2014, 10:08 AM
  Hagon Rear Shock Review dUh! 2 514 09-18-2022, 10:55 PM
Last Post: KiowaEagle_imp
  Samurider Paniers-review + pictures tomas_imp 76 7,841 05-03-2022, 02:35 PM
Last Post: ChiefJP_imp
  Daytona Cozy Seat - A Review motoWest_imp 11 1,178 06-06-2021, 06:09 AM
Last Post: JLEECB
  Dart Marlin Flyscreen - A Quick Review the_undecider_imp 70 7,170 12-10-2019, 02:16 PM
Last Post: jimgl3_imp
  Michelin Pilot Road 3s...I joined the club the Ferret 384 29,806 06-18-2019, 06:34 AM
Last Post: kennyw
  Yoshimura RS3 Exhaust Can install and review Frulk_imp 4 501 11-02-2018, 06:57 AM
  My $8 helmet cam review use2b_imp 9 1,297 05-04-2018, 04:47 AM
Last Post: chync_imp
  Michelin PR3's: where are you buying them? misterprofessionality 7 776 05-03-2018, 04:36 PM
  Michelin Road Pilot 3 Tires SOURCE! 736cc_imp 2 455 08-18-2017, 01:06 AM
Last Post: jedd_imp
  Ryujin Exhaust System Review Magnus_imp 9 883 02-10-2016, 01:19 AM
Last Post: NightRider_imp
