Whitehouse K17 mods...
Likes Given: 810
RE: Whitehouse K17 mods...
who can't appreciate a CB 1100 that has been given the Whitehouse treatment?
03-14-2022, 01:37 AM
Tev62 Offline
Threads: 33
Likes Given: 95
(03-14-2022, 01:37 AM)The ferret_imp Wrote: who can't appreciate a CB 1100 that has been given the Whitehouse treatment?
Yes, they do look a treat. You can get your own mini slice of one from Tamiya much cheaper if you get the itch! It is a 1/6th scale, a pretty big model. They say limited edition so not sure if these are still around?
Oh crap, very limited! Just seen a new one on EBAY for £400 eek!
03-14-2022, 10:26 PM
Bazbro_imp Offline
Threads: 16
Oh wow! I actually bought and made one of these Tamiya kits back in the '70s!
A beautiful kit, I kept it under a glass display dome for many years.
I don't know if I've got the patience, steady hand or dexterity to make one now! It's easier to make the real thing!! Big Grin
And here are the Instructions to making it...
https://acrobat.adobe.com/link/review?ur...2402650a8b
It seems to be "Out of stock" everywhere... Sad
03-14-2022, 11:33 PM
Bazbro_imp Offline
Threads: 16
FITTING A 'RETRO' CB750 MUDGUARD TO A CB1100...
In this case, it is a 2018 CB1100EX.
I have used a genuine Honda CB750 1972 patten front mudguard (fender, m/guard).
After removing the front wheel ( http://cb1100forum.com/forum/showthread....#pid257750 ), remove the front m/guard. 4x 12mm bolts.
Position the m/guard roughly between the forks, to see what you have and what you need to alter.  I needed to bend the large brackets to make them fit between the (wider apart) forks. I did this using a vice (vise).  CAREFULLY bend or straighten as necessary until you're happy. You may need to.keep coming back to do this.
[Image: c9248aa0c37e049456750c5dae943512.jpg]
I found it easier at this stage to temporarily remove the front, upper stay (two 8mm bolts/nuts)
Cut off the redundant cable guide.
[Image: 91d893bf142a3321fe6fd3f151199fc0.jpg]
Rustproof/paint this when you paint the central brackets, later.
The lower, rear, stays need to be modified to fit round the brake calipers /discs.
Measures 15cm along the stays, from the centre of the securing bolt hole on the end of the stay, and mark that position with tape.
[Image: 035c708c5f2c726e3caa0a77a653968e.jpg]
I am NOT a metalworker and I'm  not entirely happy with what I've done here... it's OK but could be better.  A metalworker would certainly offer a better method.  Anyway, read and weep, metalworkers of the world!
CAREFULLY and slowly bend out the arms of the rear, lower stay, equally on each side - do this on the one rear, lower stay ONLY; the other stay remains intact.  Try not to bend solely at the screw securing point - it is weak there and could snap outwards or upwards.
Bend outwards,  equally on each side, until the tape marks are 25cm apart - this will enable the stays to clear the brake calipers.
[Image: 59453fd99d2213bf88c5b2d79d893a32.jpg]
Then, put the stay in a vice and, using a tube to bend it round, slowly and gently straighten the stay so that the tips are "about" 25cm apart (I stopped when they were 26cm - half a centimeter "spring" each side, I felt was acceptable).
They now clear the brake calipers on each side.
[Image: 43e0ec5ebfb0c2b97437999a92ab0af5.jpg]
[Image: 1065f65e6fe9aac27a379c510e563a66.jpg]
[Image: 6d2682dfe910a6e2608c49817475c528.jpg]
Loosely bolt the stays onto the Special Brackets on the bottom of the forks - Note: these Special Brackets have to be made specially (they are supplied if you buy the Whitehouse front mudguard... at £430 ($560), whereas this genuine Honda mudguard is just £190 ($210) plus the bracket cost!).   I will supply dimensions below.  Any engineering shop could manufacture these if you are not able to do so yourself.  This is with many, many thanks to, and courtesy of, Ninemeister, on this Forum.
[Image: 58251e3937cbb60a6446614e8bb89b92.jpg]
[Image: f8fee8ab7fb7a282d867d0f48752fef2.jpg]
[Image: 0c1f63a33545a6a596204eda37a7e316.jpg]
[Image: 90b1da62911eeb47be41d346c1a35179.jpg]
Line up the entire m/guard squarely in the forks, and temporarily clamp in position.  Refit the wheel, temporarily if necessary, to get the final position of the m/guard "just right".  Mark where securing holes need to be drilled.  It may be that only two bolts can be used, one on each side.  This is the case with my m/guard because the existing mounting bracket is so small.  This should not create a problem, provided the bolts are fitted securely.  Fabricating a completely new bracket is possible, of course, but I don't consider it necessary.
I used G-cramps to hold the m/guard in position while measuring.  I needed to straighten and then bend again, the central bracket, using my vice.
[Image: e825e0df487025b5e1592db665d18ab9.jpg]
[Image: 4f9f30f50b8c6b812829d9fa911ce2a9.jpg]
Positioning of the new bolt holes is CRITICAL, and can affect the appearance of the entire m/guard, so be careful.
I am also concerned that removal of some of the bracing of the forks via the m/guard bracket (just two bolts instead of four securing the m/guard) 'may' affect handling.  Again, experience will tell me if an additional arch of bracing, under the m/guard, between the forks, will be necessary.
Finally, cut off the excess of the central brackets (if you consider necessary), dress down the sharp edges, undercoat,  paint, and fit back on the 'bike.
Step back and admire!
I'll post a picture when it's all painted and fitted.
03-15-2022, 12:47 AM
Man, stellar coverage.
03-15-2022, 01:47 AM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Received: 194 in 110 posts
Likes Given: 501
Bazbro, I will likely never do this, but I must tell you I sure enjoy your write-up and photos of this project. Thank you.
03-15-2022, 03:18 AM
Bazbro_imp Offline
Threads: 16
Thanks, GO and Nacho'. I'm glad this is appreciated.
I've said elswhere that I'm really doing these "How To's" for those who would LIKE to 'fettle' or service their 'bikes but are nervous about it. I hope these Posts will give guys the encouragement to 'have a go'. The only BIG caution I would give is to 'know your limitations'.
03-15-2022, 03:29 AM
Likes Given: 810
Lol when it comes to wrenching my limitations are quite high. You folks that can take things apart and put them back together again amaze and impress me.
03-15-2022, 04:57 AM
(03-15-2022, 04:57 AM)The ferret_imp Wrote: Lol when it comes to wrenching my limitations are quite high. You folks that can take things apart and put them back together again amaze and impress me.
(+1)
" ... dang. ... I dropped a set screw into the engine block ... "
" ... again. "
03-15-2022, 05:14 AM
Bazbro_imp Offline
Threads: 16
(+1)
" ... again. "
(+1)
" ... again. "
Big Grin Big Grin Big Grin. Thumbs Up
We've all been there... Sad
(+1)
" ... again. "
(+1)
" ... again. "
My best one was after I changed the clutch on my Range Rover. Last job, topping up the oil via a small dipstick hole, I squeezed the bottle a bit too hard and the nylon nozzle shot off the end of the bottle and disappeared down the hole into the gearbox innards! I was distraught!!
I noticed on a cutaway drawing in the Workshop Manual, a cast-in rib, with a small inspection plate almost next to it. I hoped and prayed...
Yup! After undoing the plate, I could JUST get a couple of fingers in and around the bit of tibe, and everso g-e-n-t-l-y eased it out...
"Home mechanics"... you've gotta love it! Big Grin
03-15-2022, 05:46 AM
  Gauge Mods Seancampbell777_imp 11 1,204 10-16-2024, 04:14 AM
  Short mods list and experience with each for those considering. Motomike7_imp 6 638 04-07-2023, 11:34 PM
Last Post: 1973cb750
  2 small mods until the weather changes inditx_imp 10 1,070 01-02-2023, 10:31 AM
Last Post: inditx_imp
  Mods to OEM seats? 2014ltdltz 7 824 07-05-2022, 05:56 AM
  Best suspension mods? gretle_2.0 6 621 05-10-2022, 06:25 AM
  Winter Mods finished, time to ride! Phadreus_imp 3 546 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Mods Mods Mods Latinrudeboi13_imp 12 1,058 08-23-2021, 01:11 PM
Last Post: Rox_imp
  Mr.P's CB mods, mark II misterprofessionality 18 1,547 05-21-2020, 06:45 PM
  New Mods 89gaz89_imp 1 334 05-15-2020, 08:08 AM
  Newly Purchased 2013 With some Mods HigginsNYC_imp 26 2,148 03-14-2020, 12:02 AM
Last Post: Cobalt23_imp
