Whitehouse K17 mods...
Bazbro_imp Offline
Threads: 16
RE: Whitehouse K17 mods...
Yes, Tev, this was the " 'biker's uniform" of the early 60s... 'Lewis Leather's' boots, leather jacket, seaboot socks, white silk scarf and jeans. I don't know about USA then ? Or Oz, NZ, Canada, etc.
So... today's activity, just remove front wheel and m/guard (as in my "How To" http://cb1100forum.com/forum/showthread.php?tid=15104 ) and then start to measure up to fit the CB750 m'guard. This has been problematic, so I'll come back to that later, .it involves drillng stainless steel... say no more!
Removing the m'guard is quite straightforward... 5mm hex key. I've hung the calipers by wire this time, because I will need to move them, depending upon what job (moving the forks for the headlamp 'ears', removing the exhausts or fitting the new m'guard).
[Image: 45334d8671e0e1319813bef600505786.jpg]
Wedges placed in the calipers, between the pads, stops them moving...
[Image: 347b1c834c71e55e7a7afe6baaecbe2d.jpg]
...and an object (in this instance, an old sunglasses case) taped between the handlebar and the brake lever.prevents accidental operation. Belt'n'braces... Wink
[Image: b6cac52b1a2dc4d63ad4845f8a143f36.jpg]
This is the stainless steel bracket, for the bottom the forks, that I had made (from Ninemeister's engineering drawing) that unfortunately needs one more hole drilling... When that's done, I can go ahead and dummy-fit the CB750 mudguard.
[Image: 4b2b297608044a31014b70c023445fa5.jpg]
Finally, where I am now...
[Image: 0d803407120396a12dc81dbc3b50eb17.jpg]
03-04-2022, 04:21 AM
(03-03-2022, 10:51 PM)Bazbro_imp Wrote: Thanks, GO. You're so right.
Even now, when I see pics of my dear Father, there are often tears in my eyes. "So much more in those images now than then. " So true...
Just a shame that the camera was such rubbish! After this, I graduated to a Nikkormat, then Nikon FE, then F2AS before the digital age took over. Our photos got a lot better after these pics!
Here's my Dad on my CB750, same day...
[Image: 34ad0a463d4c6d10bf116eb8c2447099.jpg]
Looks very happy and following his prime joy.
03-04-2022, 04:26 AM
run-tmc_imp Offline
Threads: 7
Great pics Barry. Your space looks cozy and well lit for the jobs ahead!
03-04-2022, 12:44 PM
Bazbro_imp Offline
Threads: 16
(03-04-2022, 12:44 PM)run-tmc_imp Wrote: Great pics Barry. Your space looks cozy and well lit for the jobs ahead!
Well-lit, yes, Tom. I paid a lot of attention to that. Thumbs Up
And WARM... I've gotta be warm out there! Wink
But cozy? I could do without 'cozy'! Big Grin
03-04-2022, 03:32 PM
Bazbro_imp Offline
Threads: 16
Wot I dun this arfternoon...
REMOVING THE OLD EXHAUST SYSTEM...
So... taking off the old, damaged exhaust system... the first job was removing the LH silencer. I'm going to try and work only on the left side first and then do the right later, because of the space constraints in my workshop.
Remove rear nut/bolt (12mm) and then underneath the engine, to loosen the clamp between the silencer and pipe (12mm again)
[Image: 2288738ef2e6c535fa16ffcef59b141a.jpg]
Under the engine, the pipe clamp...
[Image: 07da9b1b155d1cc6a6a4161f4b3f34f9.jpg]
Wiggle and pull and... Silencer off!
[Image: 1820f67bf68e2db0aed33e69fcf58e6c.jpg]
Then loosen the exhaust header clamp nuts (12mm). Another disturbing example of an, albeit very small, amount of rust on the nuts...
[Image: d378dbdf10bc02e8282773290b346e80.jpg]
[Image: 9d34686b09cfd7a5e53f7935df61d8db.jpg]
Now this is where it started to get 'problematic'. A further 12mm nut/bolt below the engine, needed removing in order to pull out the exhaust pipe...
[Image: 0332d6bedfed5542f52e6261d545b51b.jpg]
But the instructions said "Remove the O2 sensor"... I couldn't even SEE the sensor and could barely touch it. I couldn't slide out the exhaust pipe because of it, so I sat back, had a mug of tea and a biscuit, and pondered the problem.
What I'd taken to be a large "engine component" covering the rear is, in fact, just a plastic cover, held on by three 5mm hex bolts. Removing this cover gave superb access to the left side O2 sensor and ability to see the exhaust under the engine. I wish I had removed it as the very first task! It also needs the gearshift to be slid off the selector shaft, by undoing a 10mm bolt on the sector.
[Image: 39eb163c1bac5945653b9ca869c64a37.jpg]
Now it bacame easy and straightforward... The nut on the sensor of my 2018 model is clearly accessible, unlike the 'sunken'/hidden ones of earlier models. A 17mm OE spanner soon had it undone...
[Image: e43ec3924ff6b1590b415095dd578944.jpg]
The O2 sensor becomes clearly visible...
[Image: 15c9e5db5002112dd90625ebc791a7e4.jpg]
A 17mm spanner soon sorts it out...!
[Image: 68ed9f423460c6bd51d84323a0b657a7.jpg]
The new position of these sensors is on the new Wyvern exhaust 'cross piece', so there needs to be more cable available to move this sensor rearwards. The (long) cable is clipped under the fuel injector Number 1 - so remove the plastic LH air cleaner cover (one plastic JIS screw), pull off the cover and you can see the clip retaining several cables. Select the O2 sensor cable, unclip it and move the sensor back and under the swing arm, ready to screw into the new exhaust crosspiece. I have not secured this yet, not until I do the RH side, but this MUST BE PROPERLY SECURED, because the cable could run right alongside the gearbox sprocket and chain and become fouled. I will pay great attention to this when I do the other side.
[Image: 8e330bedb21db829aaf37c1ce2503721.jpg]
Now we came to the difficult bit - removing the main stand. I recommend two people to tackle this. If you're doing this job on the ground, it will be very difficult. I think. If you're doing it on a bench and actually using the main stand it will still be difficult, I guess, until you suport the 'bike by other means. My CB110 was jacked up under the engine, so the stand was easily "get at-able", once I'd figured out how it worked. I did not have a 'spring puller' so I went to do what I've always done with centre stands, just pull out the hinge bolt(s). In this case though, I had a problem... the hinge bolt is very long and jammed before I could pull it right out. So... I tapped the upper end of the spring off the piece of frame holding it, and BOINGGG! The spring popped off and the stand was free, held on only by the hinge rod. This rod is captive, with a small, almost hidden, 5mm hex bolt holding it in, situated ABOVE the right hand side. Undo that bolt and tap and manipulate the hollow rod out ( I used a large hex key). The stand is now free and can be removed.
Note the small flange that the retaining bolt fits through.
[Image: 8de4dbcf08db34677acb76c567601db2.jpg]
The spring hooks onto a small piece welded onto the frame - i just pushed/tapped it sideways (with hammer.and long screwdriver!) to push it off.
[Image: 832481d90da96cf96fd21e41b7582f5b.jpg]
I've loosely fitted the LH silencers and Number 1 exhaust pipe, keeping the protective cling film/bubble to prevent accidental damage. The job continues tomorrow...
[Image: be8bb12d8a99326e5b79356cb8603aa9.jpg]
Battle recommences tomorrow, when I'll explain about measuring and fitting the brackets.
03-05-2022, 06:46 AM
Thanks for the detailed images Bazbro. Really - well done.
03-05-2022, 07:55 AM
Nachodaddy Offline
Litchfield Park, Arizona, USA
Threads: 10
Likes Received: 194 in 110 posts
Likes Given: 501
Your photography and explanation are almost as impressive as the cleanliness of your bike and shop. Very nicely done. Someday, some poor soul will find this and breathe a huge sigh of relief.
03-05-2022, 12:23 PM
Bazbro_imp Offline
Threads: 16
Thanks, GO and ND.
ND - I cheat... I don't ride it - it just sits there and I worship it...! Big Grin
03-05-2022, 06:15 PM
Nachodaddy Offline
Threads: 10
Likes Given: 501
(03-05-2022, 06:15 PM)Bazbro_imp Wrote: Thanks, GO and ND.
ROFLBeerBeer
What a great place to sit with a pint and a friend.
03-06-2022, 12:31 AM
Tev62 Offline
Threads: 33
Likes Given: 95
Now you know where the clutch slave cylinder bleed point is too!
03-06-2022, 03:43 AM
  Gauge Mods Seancampbell777_imp 11 1,203 10-16-2024, 04:14 AM
  Short mods list and experience with each for those considering. Motomike7_imp 6 637 04-07-2023, 11:34 PM
Last Post: 1973cb750
  2 small mods until the weather changes inditx_imp 10 1,066 01-02-2023, 10:31 AM
Last Post: inditx_imp
  Mods to OEM seats? 2014ltdltz 7 823 07-05-2022, 05:56 AM
  Best suspension mods? gretle_2.0 6 620 05-10-2022, 06:25 AM
  Winter Mods finished, time to ride! Phadreus_imp 3 546 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Mods Mods Mods Latinrudeboi13_imp 12 1,057 08-23-2021, 01:11 PM
Last Post: Rox_imp
  Mr.P's CB mods, mark II misterprofessionality 18 1,532 05-21-2020, 06:45 PM
  New Mods 89gaz89_imp 1 334 05-15-2020, 08:08 AM
  Newly Purchased 2013 With some Mods HigginsNYC_imp 26 2,124 03-14-2020, 12:02 AM
Last Post: Cobalt23_imp
Users browsing this thread: 6 Guest(s)
