White House K10 - a story of regeneration
Ninemeister_imp Offline
Threads: 4
RE: White House K10 - a story of regeneration
(10-29-2020, 06:37 PM)Bazbro_imp Wrote: Very interesting, Nine. The rear end certainly needs "something".
Back in 1972 I fitted a nice rack to my K2, and as I've already said, the rear grab rail on my CB1100 was destroyed in the accident. I've ordered a Fehling rear rack, which is pretty close to the one I fitted in '72. It will give me a rack and a much-needed grab handle in one.
You've obviously suffered the lack of a grab handle, the same as me! They're a bu**er to get on the centre stand without a dedicated grip, aren't they? Big Grin
Not a problem I have at the moment - with the Wyvern 4-into-4 you can't keep the centre stand. It's also highly unlikely that I will be carrying a pillion (unless my other half has an epiphany) so the horizontal grab part of the rail is largely superfluous.
This is just an exercise in making use of what I had and seeing if I like it.
Slightly better side view.
I'm not digging the bend down of the rail at the rear bracket, so before welding I'm going to try bending that straight again in the press.
Obviously the indicators are currently (sic) connected so the alloy grabs are just hanging loosely on the cable.
10-29-2020, 09:17 PM
Threads: 4
It's me again.
One of my less successful ideas was the replacement of the speedo face which unfortunately resulted in an erratic zero-point on the mechanism. I did think about attempting a fix on the servo motor in the speedo itself, however the eBay gods smiled down on me when I found this 2017 speedo listed for parts. The seller said that the display had failed but the two instruments worked, so I made my bid and am glad to say won it for £72 including carriage - less than I paid for the mph dial! Ho hum, you live and learn.
All I needed to do now was to strip out the clocks, pull my instrument cluster apart and change them over. I did this tonight, taking photos along the way as I figured there might be someone interested in what's inside and how the clocks are assembled.
The first three photos are of the eBay clocks.
Next photo is of my clock set which has the speedo zero at 40mph.
Two allen screws remove the chrome covers, three black self-tappers remove the back.
The mounting frame is removed by undoing the four M6 (10mm a/f) nuts.
Another black self tapper on the cable p-clip, lever out the soft plastic covers and the wiring loom can be unplugged from the main board.
The bezel & circuit boards are fixed to the (white) frame with 17 silver self-tapping screws - just remove them all. I did this with a power driver, however one note on that is not to use it to put the instruments back together with same as the screws can easily be over-tightened which would strip the fixing holes.
11-03-2020, 11:49 AM
PowerDubs_imp Offline
Threads: 125
Nice!!!
11-03-2020, 12:14 PM
Coolio. Pretty decent deal.
11-03-2020, 02:26 PM
Threads: 4
Carrying on from where I left off:
This is the view of the back of the main circuit board showing the wired links to the tacho and speedo underneath.
A gentle wiggle is enough to remove the connector from the board.
The main board now lifts off, leaving the clocks loosely sat in the bezel.
When the board is removed, two plastic pegs will drop out. These are the push-rods for the instrument buttons, one either side. You can see on propped up in the corner of the bezel.
And as if by magic, the clocks are on the bench. The 2014 clocks have a satin black background with an orange needle.
The 2017 versions have a dark green background with white needles, red tip and chrome centre cover.
11-03-2020, 11:42 PM
Threads: 4
The chrome trim and round bezel are held on with three small black screws which I removed to replace a scratched trim. Be careful removing these, the screws are VERY tight so a perfect fit screwdriver is essential to avoid rounding out the screw heads.
Before completing the re-assembly I tested the cluster on the bike. Tacho worked, centre display worked, warning lights worked. Obviously I would have to ride the bike to test the speedo.
Refitted all screws, plugged in wiring, screwed down the p-clip.
Frame held on with nuts, outer cover with 3 more screws and the unit was good to fit.
I'll play with the left-overs later...
11-04-2020, 02:06 AM
Bazbro_imp Offline
Threads: 16
That's gonna be very helpful to me when I swap out my damaged rev counter/speeo frame, thanks, Nine. Thumbs Up
11-04-2020, 02:09 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Nine, Put bike on center stand, start engine, put bike in gear and let clutch out, twist throttle. Watch speedometer. No riding needed Big Grin
11-04-2020, 02:49 AM
Is that a button battery next to the two capacitors?
11-04-2020, 02:55 AM
Lord Popgun Offline
Virginia
Likes Given: 142
I saw that too, GO. I hope its not one, but sure looks like one.
11-04-2020, 03:32 AM
  14 STD W/ 17 White Tank JF Coastal_imp 63 4,602 07-23-2022, 11:50 AM
Last Post: ymtnpoah11_imp
  WHITEHOUSE:CB1100 K10 TANK:WHITE peterbaron 10 729 06-25-2018, 07:04 AM
  White House project started Ack-CB11_imp 60 4,085 10-20-2016, 03:38 AM
Last Post: use2b_imp
  Honda parts house CBpat_imp 7 685 08-20-2015, 02:55 PM
Last Post: CBpat_imp
  WHITE HOUSE AND WYVERN PICS FJR919_imp 34 2,502 05-20-2015, 11:32 AM
Last Post: FJR919_imp
  CB1100 Deluxe in White, Gray and Black CB4ME_imp 17 2,382 05-28-2014, 10:33 PM
Last Post: The Spaceman_imp
  White Gauge Faces HondaJon_imp 4 368 01-21-2014, 09:38 AM
  White House - Gold Ack-CB11_imp 12 714 09-04-2013, 04:26 AM
Last Post: Ack-CB11_imp
  "Hakofugu Cafè" #3 by White House Japan Ack-CB11_imp 21 1,433 08-22-2013, 01:00 AM
Last Post: silascopathic_imp
  Different colors ....black, silver, white OEM tanks RajunCajun_imp 1 210 06-28-2013, 06:46 AM
Users browsing this thread: 12 Guest(s)
