White House K10 - a story of regeneration
Ninemeister_imp Offline
Threads: 4
RE: White House K10 - a story of regeneration
(10-25-2020, 04:15 AM)The ferret_imp Wrote: Nice.
That would be some wrist stretching company to keep up with.
Yeah, that V-max is a monster, in more ways than one. Was so happy to be running with half of its potential after seeing D taking roundabouts speedway style whilst struggling to harness the torque in the wet. Not for me, I know my limits!
(10-25-2020, 04:24 AM)PowerDubs_imp Wrote: Looks fantastic.
"Front end much improved with the SDBV forks, very noticeable even after 8 mile prior test ride."
Yes- I love them- and as soon as I put them on, it made the rear shocks feel worse to me as well!
Easily fixed with a set of Ikons.
I'm already running the Japan spec HyperPro shocks, so I do have pre-load and rebound settings to play with yet.
Worst case if I think the bump is too stiff I would give them a call in the Netherlands to see if they could possibly re-valve.
10-25-2020, 04:34 AM
Your ride really stands out in the crowd 9.
That V-Max, ... hmmmm, ... yeah ... could never ignore.
10-25-2020, 06:41 AM
Houtman_imp Offline
Threads: 115
(10-25-2020, 04:02 AM)Ninemeister_imp Wrote: Thankfully the weather forecast for Sunday was better, so after a quick text-around last night tads agreed to have one last ride out before the winter arrives.
Set off at 11:00 and after a jaunt around the wet & leafy back lanes of Cheshire ended up down by the river in Chester for a coffee stop, S on his lovely Yamaha XJR1300 anniversary and D on his newly acquired (and insanely quick) Yamaha V-max. Had a very positive reaction from the boys, then had the same from another motorcyclist who singled me out to to discuss what he was looking at and thanked me for bringing it out before I left. Beer
Dropped into local bike store J&S for another quick pit stop, then home for a wash n dry by 15:30 - around 120km all in which was enough for the post-build shake down.
The good:
Rides lovely. instantly felt at home like I had been riding it for years.
Engine like silk.
Clutch & gears perfect
Brakes lovely and progressive
Easy to maneuver at low speed
Confident grip feedback in the wet
The bad:
Rear a little stiff under bump, will look to reduce pre-load
Seat also stiff, might consider rebuild with gel insert
Speedo zero seemingly random, looks like I have a broken internal gear
Gear selector too low (easy one spline adjustment when home)
Clutch bite point quite late on lever
Noticeable "click" from chain for first few hundred yards
All in all, a successful outcome, with a little work to do over winter.
I see the Ice cream kiosk in the back , did you get a 99 Flake or were they closed for the season ?
10-25-2020, 06:56 AM
Threads: 4
The good:
Engine like silk.
The bad:
Too cold for a 99 Houtman, we went straight for the coffee stand to order a piping hot Americano.
(Pet Hate: Since everyone knows an Americano is a black double espresso with added hot water, am I the only one who hates being asked if I want milk in it??)
10-25-2020, 07:10 AM
Likes Given: 1,012
It still looks lovely. What do you think causes the chain click?
10-25-2020, 08:56 AM
Threads: 4
(10-25-2020, 08:56 AM)Cormanus_imp Wrote: It still looks lovely. What do you think causes the chain click?
It's a strange one, probably caused by a tight link, maybe the one I riveted?
I did note a "notch" after I fitted and riveted the chain but from what I recall it was not on the joint. The sprockets were fine, so I put it down to a slightly tight link and as a result made a point of spinning the rear wheel over quite a few times to check for it before taking the bike off the rear stand. Maybe that freed up the joint, as even with the chain set tight and slack, from that point neither setting replicated the noise so I thought all was fine.
The bike has stood still for a week or so since, hence I was quite surprised when the noise came back as I rode away on my street. If it had remained I would have u-turned, but by the time I got to the end of the street it had gone.
Another job for the winter list - I'll make a point to carefully inspect the chain again for any obvious wear on a link.
10-25-2020, 09:24 AM
The good:
Engine like silk.
The bad:
Not sure. I do get a slight aneurysm behind my right eye, brain blank for about two seconds, suck up my pending drool at my right corner mouth, and then say, "Hey, um, no thanks".
10-25-2020, 12:01 PM
Threads: 4
The good:
Engine like silk.
The bad:
I've now got to the stage that I always order a "Black Americano" and yet STILL I get asked if I want milk in it. My usual reply is something along the lines of "well that wouldn't be black then, would it?" to which the retort is "Oh, so is that a no?".
And there was me thinking I would become more forgiving as I got older.
10-26-2020, 12:31 AM
Bazbro_imp Offline
Threads: 16
It doesn't get any better as you get older, Nine.
I used to try and be diplomatic about things but as I've become older, I've become far less diplomatic. I just say it right out now, and if people don't like it... tough.
10-26-2020, 12:44 AM
The good:
Engine like silk.
The bad:
Yeah, I have responded in kind a few times like that, usually with a response of "black" - a single syllable word - is good enough.
(10-26-2020, 12:44 AM)Bazbro_imp Wrote: It doesn't get any better as you get older, Nine.
It seems the more the new generations become "app-driven-thinkin'", the less they think.
(+1) Call it as it is. No point spending more emotional energy, if you don't wish to. Sure, eventually be called "that crotchety bast herd", but heck, I sleep at night - always. We just need to be FAIR and JUST in what we say.
10-26-2020, 01:03 AM
  14 STD W/ 17 White Tank JF Coastal_imp 63 4,656 07-23-2022, 11:50 AM
Last Post: ymtnpoah11_imp
  WHITEHOUSE:CB1100 K10 TANK:WHITE peterbaron 10 733 06-25-2018, 07:04 AM
  White House project started Ack-CB11_imp 60 4,125 10-20-2016, 03:38 AM
Last Post: use2b_imp
  Honda parts house CBpat_imp 7 685 08-20-2015, 02:55 PM
Last Post: CBpat_imp
  WHITE HOUSE AND WYVERN PICS FJR919_imp 34 2,576 05-20-2015, 11:32 AM
Last Post: FJR919_imp
  CB1100 Deluxe in White, Gray and Black CB4ME_imp 17 2,398 05-28-2014, 10:33 PM
Last Post: The Spaceman_imp
  White Gauge Faces HondaJon_imp 4 368 01-21-2014, 09:38 AM
  White House - Gold Ack-CB11_imp 12 717 09-04-2013, 04:26 AM
Last Post: Ack-CB11_imp
  "Hakofugu Cafè" #3 by White House Japan Ack-CB11_imp 21 1,437 08-22-2013, 01:00 AM
Last Post: silascopathic_imp
  Different colors ....black, silver, white OEM tanks RajunCajun_imp 1 210 06-28-2013, 06:46 AM
