Thinking of a new gadget...
Csory_imp Offline
Threads: 2
RE: Thinking of a new gadget...
(07-29-2019, 01:02 PM)GoldOxide_imp Wrote: I think I got the answer to my question from your Owner's Manual draft document.
Should've made it more clear in the manual. Will add it now. Configuration data is stored in non-volatile memory (EEPROM) of the brain module, no need to re-enter or re-calibrate unless explicitly specified so with a new firmware version. (As long as the ROM memory map remains the same there is no need to re-configure the device, not even when updating firmware.)
(07-29-2019, 05:05 PM)Cormanus_imp Wrote: Given that it's recommended the module be wired into a circuit linked to the ignition, I'm guessing the configuration will be stored in non-volatile memory.
How did I do?
You came to the correct conclusion, for the correct reason Big Grin Configuration data is indeed stored in non-volatile memory, since the unit is not powered unless the ignition is switched on (=one could even cut the wires and it would still maintain configuration data indefinitely).
07-29-2019, 09:18 PM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
Very comprehensive indeed, it may be of benefit to some riders to have a very brief explanation of the features and how to access them possibly with a picture or series of small pictures early on in the manual.
more detail can then be had in subsequent pages at length but initially you just want to find the little bit of information you want to update personal very volatile memory.
07-30-2019, 05:08 AM
Csory_imp Offline
Threads: 2
(07-30-2019, 05:08 AM)max_imp Wrote: Very comprehensive indeed, it may be of benefit to some riders to have a very brief explanation of the features and how to access them possibly with a picture or series of small pictures early on in the manual.
Max, thank you for your comment. I'm already working on a revised edition with summary "flowcharts" at the beginning of "normal operation" and "setting up" sections as a quick overview. Will have it posted once finished.
07-30-2019, 05:13 AM
Csory_imp Offline
Threads: 2
Uploaded a new version of the [url=https://1drv.ms/b/s!Ap1u16zFXQ1_jTXt0k6M00DHa0iF]BikeGadget MkII Installation and User Manual. Please review and let me know if this one is better Big Grin
Mods: is there a way to remove the old file so that it would not take up space?
08-03-2019, 11:22 PM
Threads: 347
Likes Received: 844 in 464 posts
Likes Given: 977
Csory, if you follow the link at the top of the page to your UserCP, there's an option in the left-hand column that says "Manage Attachments". You can delete it from there if you want.
08-04-2019, 08:38 AM
Csory_imp Offline
Threads: 2
Thanks, Cormanus! Just checked that if I replace the file behind this second (two posts above, from OneDrive) link of mine, the link remains alive, while the file gets replaced. This is very convenient. Already made a minor correction to it.
08-04-2019, 06:17 PM
Threads: 347
Likes Given: 977
Phew! I'm pleased I haven't had time to read the revision yet.
08-04-2019, 06:27 PM
Csory_imp Offline
Threads: 2
You're right, my comment was downright confusing. Will not post new versions unless some large-scale change warrants it, and will somehow make the changes easily visible (say, print them in orange). This time it was only the correction of a single misplaced illustration. New version number reflects this (1.01f vs 1.01 where "f" stands for "fixed"). And as always, thank you all very much for your time, patience and comments!
08-04-2019, 06:31 PM
Threads: 347
Likes Given: 977
I didn't find it confusing, Csory. Being able to see where the text has been revised would be helpful if you're looking for feedback on revisions. Are you preparing it in a program that can track changes? I'm sure you could output that to a .pdf showing the revisions.
08-04-2019, 06:40 PM
Csory_imp Offline
Threads: 2
The file is in Apple's "Pages". It can track changes, not sure though if that would appear in PDF (or would be easy to follow). Will check.
Major changes:
- This new version contains an entirely new section at the end ("Installation Example"), to show a sample installation on the '17 CB1100 EX.
- Also added two "flowcharts" as an overview at the beginning of the "Standard operation" and "Adjustments" sections.
- Screenshots are now replaced with drawings - not sure if these look better though.
- The BikeGadget has new adjustments for cold engine / hot oil / hot coolant thresholds, these are explained in the setup section.
- New "Technical data" section added with specifications.
- Lots of minor changes in device functionality and clarifications in the text, based on your previous feedback.
Todo:
- One image is missing in the "What's in the Box" section, with the display and brain module.
- "Updating the firmware" section is only a skeleton now - will have to be vastly expanded.
08-04-2019, 07:01 PM
  The mountable gadget I'd like to see Tom_imp 23 1,541 01-03-2022, 07:26 AM
Last Post: tommymck
  Thinking about belt conversion Ralph_imp 12 1,009 10-19-2015, 08:41 AM
Last Post: Ralph_imp
  Thinking about a wider rear tire silascopathic_imp 97 6,482 04-12-2015, 05:24 PM
Last Post: lemontree_imp
  Thinking about gaiters the Ferret 10 689 08-06-2013, 02:04 PM
Last Post: BuffaloBill_imp
