Honda Chrome Engine Guards now availabe in U.S.
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
RE: Honda Chrome Engine Guards now availabe in U.S.
Well the answer is to get a collapsing engine guard that crushes instead of transferring a compression load. Angel
05-16-2014, 12:06 AM
Red Mist_imp Offline
Threads: 12
(05-15-2014, 04:00 AM)TINK_imp Wrote: Your local Honda dealer can now order the OEM Chrome Engine Guards, 08P70-MGC-N20, $199.95
I like these over the aftermarket because they do not use the engine case mounting bolt. If you were to have a heavy tip-over with an engine guard mounted to the engine case bolt you could crack the engine case, resulting in BIG $$$$ to fix. Engine guards are there to PROTECT the engine, not INCLUDE the engine in the crash.
TINK
+1
I tested the Honda engine guards on my 1983 Interceptor. They were chrome and mounted in a similar way to the above guards. They looked a little odd on a superbike but when I low-sided at about 45 mph, the bike slid along on its side for a good ways before coming to a stop. My knee was damaged, but the bike came out of it with zero injuries. Even the engine guard exhibited only the lightest scuffing, and this from 549-lb. bike. The engine guards were hell-for-strong and kept the expensive parts off the ground and out of harm's way.
If I'd been smart enough to protect my own skin, I'd have avoided the necessity of picking dirt and gravel out of a hole ground in my knee. OK, I had a pretty girl along who did that for me. And she wasn't even pissed off that I crashed the bike.
These Honda guards look to be the same quality and type of mounting. Might need to get me some.
05-16-2014, 01:22 AM
Ridem32_imp Offline
Threads: 51
I like the honda oem guards also. Will get a set soon.
05-16-2014, 02:05 AM
furious_blue_imp Offline
Threads: 11
Thanks for the word. I just ordered a set through my dealer. At first I thought the design looked 'weak' because it's not 'braced' with an extra tube like some of the other aftermarket offerings, but then I realized,as someone else mentioned earlier, one doesn't want THIS part to be too strong, you want it to be weaker than anything else around it so that it deforms and absorbs more of the shock and thus gives more protection by sacrificing itself 'for the greater ($$$$Wink good' ™.
05-16-2014, 04:10 AM
Rocky_imp Offline
Threads: 26
As of this writing, Honda Canada does not have one accessory available for the CB. I'm hoping this might change in time.
If not, then it's all after market for me.
05-16-2014, 05:03 AM
TINK_imp Offline
Threads: 36
Bummer. But at least you get the beautiful BLUE CB1100 there.
(05-16-2014, 05:03 AM)Rocky_imp Wrote: As of this writing, Honda Canada does not have one accessory available for the CB. I'm hoping this might change in time.
05-16-2014, 08:20 AM
Ridem32_imp Offline
Threads: 51
Rocky. The crash honda oem bars already on eBay. I'm sure you can find them to ship to canada. Smile
05-16-2014, 08:23 AM
CB4ME_imp Offline
Threads: 183
(05-16-2014, 12:06 AM)Rboe_imp Wrote: Well the answer is to get a collapsing engine guard that crushes instead of transferring a compression load. Angel
The Active crash bars are surprisingly light weigth and apparently have thinner walls than I expected.
The SM Motech crash bars are heavy and built like a tank. They would likely transfer the full load, but like Rboe said, it the engine cases break or frame bends due to a hard impact, cases and frames won't be all there is to worry about.
05-16-2014, 09:37 AM
ride4now_imp Offline
Threads: 87
TINK
Is there enough room to, perhaps, rest your feet on them too??
I still like the opportunity to stretch out a bit and move the old legs around on a ride..
05-16-2014, 12:29 PM
Threads: 12
TINK
You could mount highway pegs on them.
05-16-2014, 02:06 PM
  Front fork seal Guards, not gators peterbaron 30 2,153 02-12-2024, 02:06 AM
  SW Motech engine guards gretle_2.0 3 434 06-05-2022, 09:54 AM
Last Post: gretle_2.0
  R-Gaza engine guards Nightryder22_imp 9 805 04-15-2022, 12:10 AM
Last Post: Nightryder22_imp
  Chain guards Rexburgtom_imp 26 1,661 01-12-2022, 05:32 AM
Last Post: 2017EX_imp
  Frame sliders/engine guards Cqrlm911_imp 81 4,639 11-10-2021, 06:46 AM
  Yamaha hand guards jedd_imp 4 829 12-23-2020, 01:29 PM
  hand guards and heated grips misterprofessionality 33 2,270 11-16-2020, 10:06 AM
Last Post: mrded_imp
  Exhaust coating Jet-Hot Chrome finish Brady Bourgeois_imp 12 1,048 08-04-2020, 03:42 AM
  Engine guards Wind_imp 33 1,839 07-06-2020, 05:28 PM
Last Post: michael1954
  Engine guards and Givi top box LuckyNLife_imp 18 1,287 05-20-2019, 10:38 AM
