Tank Pad
rjk555_imp Offline
Threads: 5
RE: Tank Pad
One more option: using a spray-on plastic film called 3M Paint Defender.
It's more effort to use than applying a pre-cut piece of film. But it has the advantage of covering the corners of the tank where the pre-cut film doesn't reach, and which could still be scuffed. Pros and cons to either approach.
Good luck, whichever way you go.
http://cb1100forum.com/forum/showthread.php?tid=685
04-06-2014, 01:29 AM
Capo Offline
Sea Girt, New Jersey
Threads: 51
Tank Pad
All great advice, and much appreciated. I decided to go with the Honda one, ordered and on the way.
04-06-2014, 03:38 AM
Gumby 1100_imp Offline
Threads: 17
RE: Tank Pad
Does anyone make tank pads for the side scallops where your legs contact the tank? Maybe from a similar pseudo carbon-fiber material as the standard Honda tank pad? My forum searches have only turned up standard hour glass shaped tank pads or 3M type paint protection film.
I don't want anything as obtrusive as the Triumph style pads, but it would be nice to protect the paint from getting worn at leg contact areas, especially where the inner seam on my jeans rub on the paint.
07-22-2014, 10:17 PM
shdwghst457_imp Offline
Threads: 22
RE: Tank Pad
I have the Honda tank pad, though I haven't put it on yet. It's much smaller than I anticipated.
Anyone have tips on how to put it on evenly?
07-23-2014, 05:31 AM
Capo Offline
Threads: 51
RE: Tank Pad
I only have tips on how to put it on un-evenly. I ended up pulling it off and mounting a bit lower on the tank so that only the top 2 pieces show. I't enough to prevent scratches from the jacket.
07-23-2014, 05:59 AM
CB4ME_imp Offline
Threads: 183
RE: Tank Pad
Honda OEM tank pad
[Image: b3a613be4d8accf80820d01e2625799f.jpg]
07-23-2014, 06:21 AM
Threads: 22
RE: Tank Pad
Maybe I can lay them out where I want and hold in place on one side with a light tape while I peel off the backing. I will need the spacing between the three to be obsessively perfect, unfortunately.
07-23-2014, 07:25 AM
CB4ME_imp Offline
Threads: 183
RE: Tank Pad
Honda tank pad is easy to apply. It is sandwiched between 2 oversized squares: a top clear plastic sheet and wax paper bottom. Peel off one end of the paper, position the pad on the tank, start applying and continue to peel the paper as you go. Then peel off the top plastic sheet. All 3 pieces are perfectly positioned. It's so easy even I can't screw it up.
About $30 from Mr T. with free shipping if you combine with another order.
07-23-2014, 07:39 AM
ss2wheels_imp Offline
Threads: 40
RE: Tank Pad
I put mine on yesterday, position it where you want it, use masking tape on top and sides to mark the area, then once you pull off the paper on the sticky side you can lay it right between your masking tape.It is small but any bigger would'nt work out too good...Biker
07-23-2014, 07:58 AM
12cb96vfr_imp Offline
Threads: 27
RE: Tank Pad
i went to a tint shop and had them apply the clear 3M paint protector. you can kinda see the outline in this pic. its on the front of the tank, and covers the entire side (where your legs would rub).
If you're near CLT, NC check out Gordon at SunStoppers on Independence...he's the MAN. And since he made template for my bike he said he'd give anyone w/ a CB a killer deal.
trying to get a better pic where you can see it, but he did such a good job its pretty much invisible
07-25-2014, 12:52 PM
  Removed tank stickers, installed clear tank protector ryanschillinger_imp 6 661 07-01-2016, 12:09 AM
Last Post: Guth_imp
