Will riding with prolonged speed limiter damage the engine??
Ohh, thanks for the information... That would explained why its kick in a range of RPM. I tried to get the RPM when it kick in but it seems fluctuated...
(03-14-2020, 09:43 PM)Guth_imp Wrote:
(03-14-2020, 09:40 PM)zirconxi_imp Wrote: Well, its a good thing my bike don't have a catalyst. But i think speed cut happen somewhere around 6k-7k rpm, isn't that consider acceptable low rpm for bike?
(03-13-2020, 11:22 AM)peterbaron_imp Wrote: It is OK to hit the limiter once in awhile, but revving your engine that high on a long term basis may cause wear and damage.
In general, a hard limiter cuts either the spark or more commonly the fuel.
If it cuts the spark only, the unburnt fuel (HC) enters catalytic convertor, slowly plugging it on a long run. HC is the prime killer of catalyst, like i.e. frequent misfire...
Cutting fuel is a better option for engine, catalyst and environment.
Biker
The limiter kicks in based on the speed that the motorcycle is traveling, not how many RPM's the engine is turning.
  Speed governor drewdavis_imp 4 581 08-27-2024, 05:49 AM
  Looks like the speed limiter is still on the '14. flynrider 38 3,529 06-12-2024, 05:31 AM
  Found on Ebay- cheap silver 5-speed LH engine cover PowerDubs_imp 1 282 05-18-2022, 07:35 AM
  Top Speed, 125MPH? HikerToo_imp 46 3,700 06-06-2021, 03:28 PM
Last Post: Rox_imp
  Triumph Speed Twin Obleo 5 592 01-14-2020, 01:15 PM
  Possible Frame Damage audiomanipulator_imp 26 2,050 10-19-2019, 11:31 PM
  Low-speed shimmy HondaJon_imp 24 1,840 11-10-2018, 11:36 AM
  Bike damage list PowerDubs_imp 43 3,244 09-06-2018, 05:11 AM
  2017 Honda CB1100EX, still top speed / rev-limited? DaSwami_imp 42 3,215 07-22-2018, 05:36 PM
Last Post: MaFiHa_imp
  5 or 6 speed? Gear indicator? PAULIBIKER_imp 27 2,152 04-20-2018, 02:07 AM
