what am i looking at here?
SportsterDoc Offline
New Mexico
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
RE: what am i looking at here?
If the question is about the individual pod filters, this thread may be of interest:
http://www.cb1100forum.com/forum/showthr...p?tid=4879
04-13-2018, 09:00 AM
Aussieflyer Offline
Threads: 17
Likes Received: 5 in 1 posts
(04-13-2018, 08:28 AM)misterprofessionality_imp Wrote:
(04-13-2018, 08:12 AM)Cormanus_imp Wrote: Return to edited post http://cb1100forum.com/forum/showthread....#pid201766
ah, i gotcha. so it's not a different part, just something's been added. what does that do for him? what effect does it have on the performance?
The resolution of the image is not so good but I think your pointing to the round shiny section of the throttle body. It's usually a dull silver component installed as a seal. Lots of folks glue in a shiny coin to dress it up a little. The engine looks quite different because of the modification mentioned by Cormanus, removal of the standard air box and four individual filters fitted in its place ... way cool IMO.
04-13-2018, 09:03 AM
New Mexico
Threads: 33
Likes Given: 6
The advantage of pods is an open look.
4 pods may actually be slightly less $ than a factory air box filter.
There could be an air flow advantage on some bikes, but I am skeptical of that on the CB1100.
04-13-2018, 09:04 AM
Ferrealls_imp Offline
Threads: 17
The silver cap on the throttle body looks like it covers a location where an O2 sensor used to be.
The benefit of this installation is that it removes all pressure losses across snorkel, air cleaner and funnels. It breathes much better. It would a custom fuel map to run correctly. Likely you'd want to use an autotuner, so you'd install an O2 sensor with that setup, maybe the reason why that one is missing.
04-13-2018, 10:40 AM
misterprofessionality Offline
Threads: 126
Likes Given: 1
(04-13-2018, 09:04 AM)SportsterDoc_imp Wrote: The advantage of pods is an open look.
according to the thread that was posted above, it looks like it won't actually have any performance increase, but changing the throttle body instead might have more of an effect. am i wrong?
04-13-2018, 10:44 AM
New Mexico
Threads: 33
Likes Given: 6
(04-13-2018, 10:40 AM)Ferrealls_imp Wrote: The silver cap on the throttle body looks like it covers a location where an O2 sensor used to be.
O2 sensor(s) are exhaust mounted
Circled area is throttle position sensor
On many engines, yes.
On the CB1100, very little difference.
I cut off the top of the "funnel" on my CB: no appreciable difference other than I like the intake sound. My 2012 Triumph benefitted significantly with snorkle removal.
Mine runs fine with an opened intake
Stock throttle bodies have more than enough CFM capability.
Not much power to be gained on the 1140 motor with stock cams, AFAIK
04-13-2018, 10:55 AM
Threads: 126
Likes Given: 1
so the conclusion of my dumb post in the end is this: the owner of the bike in the picture did it because Farkle.
follow up: is there any way to improve air intake in a way that increases engine performance? (along side fuel computer adjustments and exhaust system upgrades)
04-13-2018, 12:16 PM
Likes Given: 1,029
MrPty, there’s really no such thing as a dumb question. I’ve learned something because you asked it.
04-13-2018, 12:25 PM
