Head lamp Stone guards
misterprofessionality Offline
Threads: 126
Likes Given: 1
RE: Head lamp Stone guards
(04-21-2018, 10:40 PM)EmptySea_imp Wrote: Thanks, peter. Pretty sure that folks doing this mod are well aware that this is an "appearance only" mod. I'm not convinced that the installation of some versions of the grill would result in decreased visibility or an appreciable degradation in range or pattern of the light. At a cost of less than $30, some might find it worth trying.
i'd be open to the idea of upgrading the lamp itself in brightness if it was the best idea to complete the mod. I know some have gone to an LED lamp, which is like the holy sun god itself, blinding all in its path.
Either way i'll confirm again that I don't really have any fears about rocks or anything breaking my lamp. It's about aesthetics.
04-21-2018, 11:08 PM
Likes Given: 82
^^ Yes, I would probably look at upgrading the headlight itself as part of this mod if i decide to do it at all. Also, for myself, I'd want the grill to be removable without tools if I found that it was hindering either my vision or my conspicuity when riding at night.
04-21-2018, 11:18 PM
Threads: 126
Likes Given: 1
(04-21-2018, 11:18 PM)EmptySea_imp Wrote: ^^ Yes, I would probably look at upgrading the headlight itself as part of this mod if i decide to do it at all. Also, for myself, I'd want the grill to be removable without tools if I found that it was hindering either my vision or my conspicuity when riding at night.
now that's something i haven't found at all, other than the zip-tie idea from the other thread. they all have some sort of set screw, bolt, or other apparatus to get them into place.
04-21-2018, 11:32 PM
peterbaron Offline
Likes Received: 575 in 312 posts
Likes Given: 960
More light....
You can go for a complete LED lamp assy upgrade...or just the LED bulb.
Good luck
pb
04-22-2018, 12:03 AM
Likes Given: 82
I may be wrong, but this one looks like it clips in. You mount the clips to the bucket and snap in the grill. I'm not positive, though.
https://www.outpostcycle.com/product-pag...ard-grille
04-22-2018, 02:07 AM
Threads: 126
Likes Given: 1
that looks spot on, the question is, how do you mount it to the bucket? i've never messed around with it, so i've got no perspective on these things. wonder if i could get a peak at the instructions without buying one...
04-22-2018, 02:50 AM
Likes Given: 82
(04-22-2018, 02:50 AM)misterprofessionality_imp Wrote: that looks spot on, the question is, how do you mount it to the bucket? i've never messed around with it, so i've got no perspective on these things. wonder if i could get a peak at the instructions without buying one...
I don't think it will be difficult to install the clips. I'd have to tinker around with it. However, It has occurred to me that one could use black velcro straps to attach the grill to the outside of the bucket or the headlight bracket unobtrusively without having to disassemble anything. Still noodling on this
04-25-2018, 06:37 AM
jtopiso_imp Offline
Threads: 13
I think, on a 17 at least, the headlight is flat, but that grill is like a dome.
I don't know if that would look right.
04-25-2018, 06:33 PM
Likes Given: 82
I haven't seen a flat grill for the flat headlights on most modern bikes, including all versions of the CB1100. I have seen this mod done before on the CB1100 and the convex grill against the flat light does not look odd at all.
However, since the headlight covers are flat, I thought to myself "I wonder if there is a cheaper way to get a flat grill".....and there is!
https://www.amazon.com/Cooling-Multi-Pur...oling+rack
$13.00 from Amazon.
04-26-2018, 05:36 AM
Threads: 346
Likes Received: 829 in 457 posts
Likes Given: 968
Great for using the headlight’s heat for cooking bugs.
04-26-2018, 05:43 AM
  Front fork seal Guards, not gators peterbaron 30 2,153 02-12-2024, 02:06 AM
  SW Motech engine guards gretle_2.0 3 434 06-05-2022, 09:54 AM
Last Post: gretle_2.0
  R-Gaza engine guards Nightryder22_imp 9 805 04-15-2022, 12:10 AM
Last Post: Nightryder22_imp
  Chain guards Rexburgtom_imp 26 1,675 01-12-2022, 05:32 AM
Last Post: 2017EX_imp
  Frame sliders/engine guards Cqrlm911_imp 81 4,642 11-10-2021, 06:46 AM
  Yamaha hand guards jedd_imp 4 829 12-23-2020, 01:29 PM
  hand guards and heated grips misterprofessionality 33 2,270 11-16-2020, 10:06 AM
Last Post: mrded_imp
  Rox in my Head Rexburgtom_imp 7 478 07-14-2020, 11:08 AM
  Engine guards Wind_imp 33 1,839 07-06-2020, 05:28 PM
Last Post: michael1954
  Engine guards and Givi top box LuckyNLife_imp 18 1,287 05-20-2019, 10:38 AM
