Tank Removal...
teamvisegrip_imp Offline
Threads: 4
RE: Tank Removal...
I would like some more into on this Quick Release Fuel Connection, price, part number and where to get them.
I am looking for a Quick Release Fuel Connection for a bike build. I need to be able to disconnect and still be able to hold the fuel in the tank. I would like to have the option to drain afterwards too.
Any thoughts as to what would work best would be very appreciated.
03-08-2019, 02:33 AM
Bazbro_imp Offline
Threads: 16
RE: Tank Removal...
(03-08-2019, 02:33 AM)teamvisegrip_imp Wrote: I would like some more into on this Quick Release Fuel Connection, price, part number and where to get them.
These - https://tinyurl.com/y3pc8fa8 - are the sort of items I've fitted to my BMW to facilitate easy tank removal, but that's a simple gravity-feed system.
Questions have been raised by the guys here on whether they are suitable for 50+ psi pressure-fed systems.
Keep us posted as to what you discover?
Good luck with the build..
03-08-2019, 02:52 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Tank Removal...
These inexpensive quick disconnects are designed to be used with a petcock or gas valve. They do not have any check-valve on either side to hold fuel in the line, and will be open on both sides when disconnected.
Look for metal ones to do that, like those used for air compressor hose lines. Be sure they are fuel resistant. And if you use one like that, and have the check-valve end on the tank hose, it will not drain unless you put an open male coupler on it.
03-08-2019, 07:05 AM
peterbaron Offline
Likes Received: 575 in 312 posts
Likes Given: 958
RE: Tank Removal...
+ 1 = Right on, do it right or do NOT do it at all!!!!!!!!!!!!!!!!!!!!
03-08-2019, 07:46 AM
Bazbro_imp Offline
Threads: 16
RE: Tank Removal...
Thanks for that, pekingduck. Smile
03-08-2019, 10:43 AM
tommymck Offline
Florida/Maryland
Threads: 34
Likes Given: 9
RE: Tank Removal...
I dunno. Me, personally, I’d just leave it stock (and I did). You’ll need to figure out the stock arrangement anyway just to remove the tank. And once you do, it really isn’t so terrible. My issue was that the whole thing is non-obvious. Removing a tank is common enough that I’d have thought that the design of the release mechanism could have been a little more straightforward... that’s all. When you figure it out, it isn’t that bad. It just took me a few hours to figure it out. Were I to do it again, a tank swap would be a 45 minute job at most, but the fuel line part of it would add maybe a few minutes extra over some easier quick disconnect.
My main advice is to have patience the first go-round. Like most things mechanical, the problem will succumb to perseverance.
03-08-2019, 12:14 PM
RE: Tank Removal...
Just like the winter regions will succumb to the CB owner's perseverance to ride. Smile
03-08-2019, 12:18 PM
Bazbro_imp Offline
Threads: 16
RE: Tank Removal...
(03-08-2019, 12:14 PM)tommymck_imp Wrote: I dunno. Me, personally, I’d just leave it stock (and I did). You’ll need to figure out the stock arrangement anyway just to remove the tank. And once you do, it really isn’t so terrible. My issue was that the whole thing is non-obvious. Removing a tank is common enough that I’d have thought that the design of the release mechanism could have been a little more straightforward... that’s all. When you figure it out, it isn’t that bad. It just took me a few hours to figure it out. Were I to do it again, a tank swap would be a 45 minute job at most, but the fuel line part of it would add maybe a few minutes extra over some easier quick disconnect.
Thanks, Tommy. Big Grin
03-08-2019, 05:42 PM
  Crank Case Cover removal? JF Coastal_imp 47 2,980 08-04-2023, 01:26 PM
  Accessory Removal Wagonpeddler_imp 13 927 03-22-2022, 05:22 AM
Last Post: Wagonpeddler_imp
  Custom rear fender removal. Rebel73_imp 17 1,185 03-15-2017, 06:49 PM
Last Post: c-breezy_imp
  Removed tank stickers, installed clear tank protector ryanschillinger_imp 6 583 07-01-2016, 12:09 AM
Last Post: Guth_imp
  Rear brake light LENS removal DIY? Riko_imp 13 897 01-10-2016, 03:41 AM
Last Post: Riko_imp
  Yoshi system - oil filter removal Razor 7 560 07-19-2015, 10:34 PM
Last Post: Razor
