Acewell Speedometer
arse-onist_imp Offline
Threads: 2
RE: Acewell Speedometer
I'll try it out and will update.
05-22-2019, 09:52 PM
Threads: 2
OK so moving forward from the speedometer gauge. I checked some YouTube guides and managed to find the tyre circumference number. For those of you who are interested, the number is between 1850-1900. You have to play around with that number.
Now, I'm playing around with the fuel gauge meter. If only I have an ohmmeter with me.
05-25-2019, 03:08 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
I don’t think Max listed it, so here is the resistance of the fuel sensor:
8-12ohms Full, and 213-219ohms Empty. If that helps you any.
05-25-2019, 03:35 AM
Threads: 2
(05-25-2019, 03:35 AM)Lord Popgun_imp Wrote: I don’t think Max listed it, so here is the resistance of the fuel sensor:
that actually helps a lot! Beer
05-25-2019, 04:17 AM
Threads: 2
Question.
Anybody know the size of the bolts for the front disc brakes? The tiny magnet isn't cutting it when I'm going over 110kmph as it keeps jumping.
http://www.acewell.co.uk/Acewell%20Acces.../index.htm
Sorry for the noob question. Confused
06-22-2019, 12:36 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
does the fuel gauge work now and if so what setting did you use?
06-22-2019, 02:34 AM
Threads: 2
(06-22-2019, 02:34 AM)max_imp Wrote: does the fuel gauge work now and if so what setting did you use?
I'll get back to you on Friday for that. I think there was an issue with the wiring so I wanna see if the current sender works with the fuel gauge. Fingers crossed!
06-22-2019, 01:16 PM
Threads: 2
Welp! Managed to get everything in check. Now everything works as intended.
The fuel gauge issue was because the shop that I sent to for the initial installation kinda misread it. I had to get a second opinion from another shop to get it right.
According to him, there were only 1 wire connected to the meter instead of 2. Confused
Anyways, here are some images.
(I'm still not good at this)
[Image: a58b3a949839ea650ecf76a5ea407781.]
[Image: 83025e18c1fe573b2553d754b2ec4bbd.]
[Image: cf66c59c6e22437e2d0bfee010e70fcd.]
07-01-2019, 01:35 PM
max Offline
Threads: 39
Thanks for the photo's, seems you have a full tank and the grey/black wire is back in action, it must be confusing without a diagram but you got it done anyway, thanks for the update and best wishes.
07-01-2019, 07:02 PM
Likes Given: 1,014
Well done arson-ist. There's no way to link from Google photos so the pictures display on the forum. For that you'll need Imgur or Postimage or Photobucket.
07-01-2019, 09:24 PM
  Speedometer Upgrade!? DirkDiggler_imp 12 1,300 02-23-2025, 04:57 PM
Last Post: Jurlie_imp
