Givi Side Case Racks...Do they exist?
jedd_imp Offline
Threads: 27
RE: Givi Side Case Racks...Do they exist?
look into the sw motech EVO side carrier / rack:
link:
https://sw-motech.us/bike/HONDA/CB1100/2...023365.htm
those side racks have pre punched holes to bolt on the givi monokey mounts:
Link:
https://sw-motech.us/bike/HONDA/CB1100/2...007853.htm
here you can see those Givi monokey hardware parts (triangle clamp on top bar, two mushroom pegs at bottom, 4 rubber bumpers on sides ) fastened to the EVO racks:
i have the EVO racks on my cb1100 , with the givi hardware per above, i have mounted a set of givi e22 (same as e21, different lid) on my bike.
07-21-2020, 06:54 AM
peterbaron Offline
Likes Received: 594 in 325 posts
Likes Given: 1,003
I have these SW Motech EVO side carrier/rack and made total of 70 Kms = NO complaints, excellent !
07-21-2020, 07:43 AM
cbolling_imp Offline
Threads: 7
Thanks, for the replies and sorry for not posting sooner. Yes, I have been a member for a long time but have never really posted. I bought a 2014 over the weekend so I will be an active member going forward.
I looked on SW Motech's web site and the rack are not available. I will have to check some of the other links. Hopefully I can find a set for sale somewhere.
08-26-2020, 04:57 AM
peterbaron Offline
Likes Given: 1,003
Did you check SW Motech - Germany or Twisted Throttle/USA or Canada...eBay???
08-26-2020, 05:02 AM
Threads: 7
Here is my bike by the way.
(08-26-2020, 05:02 AM)peterbaron_imp Wrote: Did you check SW Motech - Germany or Twisted Throttle/USA or Canada...eBay???
I checked Twisted Throttle a few weeks ago but now that I have an actual item # to search for I may have better luck
peterbaron Offline
Likes Given: 1,003
Trapezoid shape side racks are more universal, the biggest issue might be with the hardware for your '14 CB...it also fits '13 model. I did transfer from the '13 onto the '14 = no issue.
May this help you more/better?:
[Image: 46e76793b8b84170a2bca88327b5a5a1.jpg]
[Image: e0629e5b270d8415c5353d85cc1940b3.jpg]
[Image: 7457328ab5715ec78e3fb990986bde36.jpg]
[Image: daf3d3aadb0fefe2fabf295eb1ea1eb7.jpg]
For these ^^ side racks, I use pictured bellow AERO side panniers , also by SW Motech:
[Image: 76c6571cdc395898e79650b13c19a901.jpg]
[Image: 842bcc2d5124932eb18f12c2afb20d54.jpg]
[Image: 8aa5aff96091283512cb773b3c4ae6b7.jpg]
And this is how they look on my bike
[Image: 24d2fea3b7990fdf3a1abbbdcb5c29d3.jpg]
[Image: be02e6c34fac5ed36490f3aaa6eb5f6c.jpg]
[Image: ba22dfc8d1fccd1fc26c87400fcfb136.jpg]
Make sure you get the side racks with hardware matching your side panniers...otherwise may not work together.
There might be some other options by SW-Motech or different companies. Check.
Good luck!!
08-26-2020, 05:56 AM
Threads: 7
I found some SW Motech racks on Amazon. Price seems to be way jacked up though. I guess I will have to relocate my rear blinkers. Has anyone done that?
08-26-2020, 11:28 PM
peterbaron Offline
Likes Given: 1,003
First pic below is a U shape bracket with 6 holes, OEM SW-Motech.
You can easily make it by urself from a nice piece of metal strap, shape it, fold it and drill 6 holes of different diameter: 2 bottom for the U shape bracket holding bolts, 2+2 wing side L+R to accommodate the turn signals. If you chose this design, you'll have to make one side turn signal's harness longer by about 1 foot, and I believe is the R-side, as the turn signals harness runs on the L side of rear fender, then you have to drill a hole below the stop light - in lamp's black housing to run the turn signal wires through it.
Here are some orientation pics:
[Image: 7b3f1ec9637504cb0e55493168dee5f8.jpg]
[Image: 76f2e1bbd756339f4cc86b55d276c6d5.jpg]
[Image: 363a28a1fa29b725a8cf46180e5040d1.jpg]
[Image: 72a33fe645f2123252f5111c8cb17d39.jpg]
This is what I did with my OEM SW Motech.
You may go alternate way and see if lic plate bracket + home made extension can accommodate relocated turn signals + both T-signals harness extension by 1-2 feet
Smile
08-27-2020, 01:10 AM
Threads: 7
That is awesome. Thank you
08-27-2020, 07:16 AM
tj_gee_imp Offline
Threads: 1
Far as I can tell, the EVO side racks have been discontinued.
08-27-2020, 11:03 AM
  SIDE bag racks for my   2014 Honda CB1100 Deluxe? LucienLeFranc 13 831 07-01-2026, 08:51 PM
Last Post: rdprdp01
  Luggage Racks pekingduck 8 772 06-02-2026, 07:57 AM
Last Post: HondaLou
  Racks For DLX 1973cb750 3 557 03-06-2026, 02:55 PM
Last Post: Sadorphan
  Givi Airstar Universal Windshield - A660 peterbaron 2 629 12-28-2025, 02:15 PM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 532 08-20-2025, 06:25 AM
  Givi rack for top box. Nick_imp 6 589 01-17-2025, 03:55 PM
  Top box, Givi, Shad or maybe something else? Davidjill_imp 17 1,452 07-25-2024, 08:22 AM
  SW Motech evo racks question 12milesout 6 721 05-07-2024, 06:55 AM
  Crank Case Cover removal? JF Coastal_imp 47 3,440 08-04-2023, 01:26 PM
  Anyone recommend s a top case for the 13' OEM rear Carrier? iamlegend21087_imp 14 1,187 06-21-2023, 08:51 PM
Last Post: Tbhart89_imp
