Race Sprockets
bigsheep_imp Offline
Threads: 46
RE: Race Sprockets
If the speedo is calculating how many times the wheel spins to determine speed how would a sprocket change affect that? It's using OD of the wheel and RPM of the wheel, the sprocket and engine speed would not affect it at all, unless I'm missing something... which I usually am when it comes to mechanical things.
There are two limiters, one which limits the redline in any gear, (which I manage to hit easily after riding my CBR600 for the day) and the other which limits the top speed at 110 MPH. I've read somewhere that it only limits in gears 4,5 and 6, so you could exceed the top speed of 110 in third gear if the conditions where right.
With these race sprockets Gearing Commander indicates a top speed of 107.4 MPH with a 16/45 for the CB, which means with stock gearing and a limiter of 110 we're leaving a lot on the table. Mind you it's speed I would never use really...
11-30-2020, 02:16 AM
LakeWylieJoe_imp Offline
Threads: 11
RE: Race Sprockets
That's what I'm asking... Does the speed limiter use the rear wheel speed, or are there preset rev limits for each gear that effectively limits the top speed?
11-30-2020, 02:38 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Race Sprockets
Well both. There is a speed limiter, from the rear wheel, and rev limits.
11-30-2020, 03:15 AM
Likes Given: 1,012
RE: Race Sprockets
Could you help me understand that better, Lord Popgun. Does the limiter cut in at 112 mph because the ECU determines the bike is doing that speed? Or does it cut in because the ECU determines the combination of revs and gear means the bike ought to be doing 112 mph?
11-30-2020, 07:42 AM
Threads: 46
RE: Race Sprockets
I've approached the rev limit of third gear which I'd estimate to be around 170-180KM/hr on the CB on a track. (Speedo taped over as per regulations). I gotta tell you, I felt like I was being ripped off the thing, wouldn't want to do much more. I've done 220+ on the CBR which seems much less hectic.
11-30-2020, 08:22 AM
Lord Popgun Offline
Virginia
Likes Given: 142
RE: Race Sprockets
Cormanus, the speed is limited when the bike speed is the 112mph. Because, you know, the Japanese rulers don’t like people having fun Wink
The revs are limited when the revs are too high. I don’t know how high is too high and it may not be in all gears according to member posting. Here is a post and the one after that is interesting: http://cb1100forum.com/forum/showthread....#pid195376
11-30-2020, 08:54 AM
Threads: 46
RE: Race Sprockets
(11-30-2020, 08:54 AM)Lord Popgun_imp Wrote: Cormanus, the speed is limited when the bike speed is the 112mph. Because, you know, the Japanese rulers don’t like people having fun Wink
Don't those same Japanese make the H2R?
11-30-2020, 09:23 AM
Lord Popgun Offline
Virginia
Likes Given: 142
RE: Race Sprockets
According to one Japan site it can’t be ridden on public streets.
11-30-2020, 09:35 AM
Threads: 11
RE: Race Sprockets
The national speed limit in Japan is 100kph (roughly 62mph).
11-30-2020, 12:48 PM
tod.branko_imp Offline
Threads: 19
Race Sprockets
Interestingly enough, as we all know, not all Honda motorcycles have the 180kph speed limit, one that comes to mind was the X4, which was built on the CB1300sf platform, with the same 1284cc water-cooled inline 4 engine with the same 100hp and 121Nm as the CB1300sf however the speed wasn't (isn't) limited on the standard, and is one of the most venerable Honda motorcycles ever produced [Image: 52c34a8a4ddb33f959fd681c91201cfa.jpg]
'14 CB1100 STD 5 speed
11-30-2020, 07:13 PM
  anyone manufacturing race inspired fairings/cowls? infinite_ideation_imp 11 1,019 06-02-2021, 10:50 AM
Last Post: paisa_imp
  7th Gear Designs..sprockets? ozigoo 33 2,293 04-16-2021, 10:31 AM
  Revzilla offer -- the race to the bottom LongRanger_imp 6 463 04-15-2020, 09:11 PM
  Sprockets Lower RPM 1953andrejrigoli_imp 4 404 03-17-2015, 08:37 PM
Last Post: CIP57_imp
  Question about street use of Yoshimura 4:1 "Race" exhaust anyonecandoanything_imp 6 496 01-21-2015, 08:57 AM
Last Post: emptysea
