Fork Protectors, an alternative to Gaitors?
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 200 in 118 posts
Likes Given: 142
RE: Fork Protectors, an alternative to Gaitors?
Welcome CB1100RS!!
Post up a pic of your fix if you get a chance.
04-03-2021, 11:34 PM
Tev62 Offline
Threads: 33
Likes Given: 95
(04-03-2021, 11:09 PM)CB1100RS_imp Wrote:
(04-03-2021, 03:39 AM)Tev62_imp Wrote: Addendum - don't do this with these Triumph ones, they just catch the horn on heavy braking. They sit a tiny bit too far forward but other designs may not. There is a drain channel at the base of these at the front and it holds the blade slightly too far forward to clear the horn. Blush
I fitted these on my RS and just fitted two 10mm spacers under the horn bracket, sorts the problem.
I fitted these on my RS and just fitted two 10mm spacers under the horn bracket, sorts the problem. I had thought about this, I might try it too. Beer
04-04-2021, 01:16 AM
CB1100RS_imp Offline
New to the Forum
Threads: 0
I fitted these on my RS and just fitted two 10mm spacers under the horn bracket, sorts the problem. I had thought about this, I might try it too. Beer [Image: 79ebf4b64524e19969f6c2051d2ed981.jpg]
[Image: eabede6d3eb62f6ca4e01e21f2d06110.jpg]
I just swapped out the original allen bolts for longer 35mm items.
If i remember correctly Triumph do actually make a shorter version of the fork protector, i believe for faired models but i chose to go with the longer variant for maximum protection.
04-04-2021, 02:18 AM
Tev62 Offline
Threads: 33
Likes Given: 95
Many thanks for the pics.
Yes, I thought they had shorter ones for the faired models too and I had ordered these for my Daytona from the Daytone parts fiche but they are too long for that aswell?
04-04-2021, 02:48 AM
Ulljanrich_imp Offline
Threads: 3
I used these:
https://shop.montagestaender.de/motorrad...hwarz.html
But they only can be mounted in combination with their fork stabilizer (which I had to use due to my front fender modification):
An it looks like this when mounted:
04-06-2021, 04:22 PM
Tev62 Offline
Threads: 33
Likes Given: 95
That looks very well Ulljanrich, suits the bike nicely. Thumbs Up
04-06-2021, 05:17 PM
Jfro5687_imp Offline
Threads: 23
Racy looking headlamp you have there. What make is it?
04-06-2021, 07:14 PM
Threads: 3
It's this:
https://motodemic.com/shop/jw-speaker-7-...-adaptive/
The brackets come with the Dart Flyscreen for the 2017+ CB1100 Models. These brackets need to be longer in order to get the flyscreen fitted. So Dart supplies their own (longer) brackets, which are of superb quality and at least as good as the originals. It looks like laser-cut stainless steel. Very strong quality.
To fit the JW Speaker unit, a new and sufficiently large headlight bucket was needed. When I started this modification in around 09/2019, Motodemic still offered the steel made black bucket in 7" size, and I ordered it. It could be of Triumph origin, but I cannot guarantee that. Heavy duty quality bucket, that is for sure. Looks 100% like those on Triumph bikes...
However, right now, in their Motodemic webshop I can find 5 3/4" Buckets only.
I have described the mod in this forum earlier. Wire-wise it was a medium headache at least, as Honda uses a very "unusual" 8-pin-plug for their LED headlight. That had to be figured out and happened to work only with the help of special adapters solution eventually. For me as a complete non-electric a real adventure and I had to learn and understand a lot. For those who are familiar eit elctricity, it should be easy, or at least easier.
[url=http://cb1100forum.com/forum/showthread.php?tid=7548&page=3]http://cb1100forum.com/forum/showthread....548&page=3
So far, the headlight-mod has proven very, very good and dependable. Very nice bright light indeed, on both wet and dry roads. It really puts its lumens on the road, yet not blinding the uncoming traffic. I really like it so much, even after 18 months of using it. Nightrides have become so much safer. Every ride, a real "high-light" Cool
And the look - I like it myself, too.
04-06-2021, 07:54 PM
(04-06-2021, 07:54 PM)Ulljanrich_imp Wrote: It's this:
That is a serious headlight offering.
04-06-2021, 09:36 PM
teamvisegrip_imp Offline
Threads: 4
I added these to my bike to stick with the carbon fiber look of the rest of the items I added. I think they look great and do the job. I did have to shorten the screw so that they would not harm the fork tubes when installed.
https://japan.webike.net/products/1548106.html
04-11-2021, 11:02 PM
  Instrument panel protectors? LucienLeFranc 9 546 05-11-2026, 03:17 PM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 383 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,112 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  Fork gaitors on E bay. hondadownunder_imp 15 1,193 06-29-2022, 03:27 AM
Last Post: 2017EX_imp
  Fork Protectors apex1_imp 10 791 03-24-2021, 06:09 AM
  transparent tank protectors Enzofour_imp 2 431 03-03-2021, 09:35 PM
Last Post: Enzofour_imp
  Radiator Protectors michael1954 3 421 05-31-2020, 02:35 PM
Last Post: zirconxi_imp
  iPhone anti-glare case (or alternative ideas) emptysea 9 877 08-05-2019, 08:10 AM
  R&G Racing Supermoto Exhaust Protectors apex1_imp 3 405 06-25-2018, 01:22 AM
Last Post: aschem_imp
  Alternative Fork boots (not the kawa boots) misterprofessionality 11 1,122 06-01-2018, 05:39 AM
Last Post: Rocky_imp
