Tubeless tires
Aka Tsubasa_imp Offline
Threads: 6
RE: Tubeless tires
(08-02-2017, 07:15 AM)Nortoon_imp Wrote:
(08-01-2017, 10:59 AM)Houtman_imp Wrote: They do show the Dunlop 205 on the 2017 parts fiche , will it be a Honda OEM tire for a while ? ( about $ 170 )
I love them on my 2017 and would like to fit them also as a tubeless tire on my 2013/2014.
Thanks for the lead. I checked the fiche and found the part numbers. Used Google and found them listed on Babbitts, ProCaliber, and Honda Service websites with prices.
I telephoned Dave Johnston at Dunlop Motorcycle Tires in Dayton, Ohio again. He confirmed that Dunlop would not be importing them as the numbers required would be too small. He feels that Honda USA has not ordered them either, but he will check on that.
I mentioned the three websites. He replied they would all rely on Honda USA to provide the tires for them to sell.
I called Babbitts and they are on back order. He confirmed they rely on Honda USA to provide them with the tires.
I am not getting that warm and fuzzy feeling that Honda is going to do the right thing here.
We will just have to import them from a site like Samurider. A pain in the butt for sure but not an insurmountable issue.
08-02-2017, 07:20 AM
Likes Given: 1,018
RE: Tubeless tires
Or just fit another brand of tyre.
I suspect part of the reason the PR3s became so popular is that it was impossible to get either of the OEM Dunlop or Bridgestone tyres as replacements.
08-02-2017, 07:56 AM
Nortoon_imp Offline
Threads: 28
RE: Tubeless tires
(08-02-2017, 07:56 AM)Cormanus_imp Wrote: Or just fit another brand of tyre.
Unfortunately a search for radial tubes and tires for the CB1100 EX 18 inch rims turned up nothing in North America.
Having mailed large scale model trains to Britain I know the shipping costs are ridiculously expensive. It would probably cost as much as the tires. Buying a set of CB1100 cast wheels here might be cheaper.
08-02-2017, 01:44 PM
Likes Given: 1,018
Tubeless tires
Nortoon, that's interesting. I was referring to the impossibility of getting OEM radial trees for the 2010-11 models in Australia and, I suspect, in North America.
Even if you bought cast wheels, would you get tires for them? If you could, why not get them for the spoked wheels and put tubes in them?
Or is that not possible?
08-02-2017, 05:51 PM
Macduff_imp Offline
Threads: 11
RE: Tubeless tires
As a side note other Bike makers have fitted Tubeless tyres with tubes to thier spoked wheeled bikes as OEM . So you could look for Tubeless tyres in the sizes wanted and fit them (with tubes). I know this as KTM did this with their old 950 and 990 Adventures. Check inside of Tubeless tyres for items that might wear a hole in a tube.
08-02-2017, 05:57 PM
Henrik_imp Offline
Threads: 24
RE: Tubeless tires
I am using Metzeler Z8's on my EX. These are tubeless tyres available in the stock size, but I have fitted tubes in them without a problem. I know there are quite a number more EX riders doing the same. I certainly would not want to replace my spoke wheels simply because I can no longer find the D205 tyres here.
08-02-2017, 10:41 PM
Nortoon_imp Offline
Threads: 28
RE: Tubeless tires
(08-02-2017, 10:41 PM)Henrik_imp Wrote: I am using Metzeler Z8's on my EX. These are tubeless tyres available in the stock size, but I have fitted tubes in them without a problem. I know there are quite a number more EX riders doing the same. I certainly would not want to replace my spoke wheels simply because I can no longer find the D205 tyres here.
Sounds like a viable option. There are still a few tire brands available for the CB1100s with cast wheels.
Buying a set of Deluxe wheel assemblies would cost about US$900. I do like the looks of them and they would be easier to clean than spoke wheels. But the spoke wheels are what give the EX its retro look. Wherever I stop for gas or food lately people are drawn to the bike because of it 1970s look.
08-03-2017, 01:34 AM
Threads: 6
RE: Tubeless tires
Unless there are no tires for my bike on this planet, my spoked wheels are staying in place! Angry
08-03-2017, 02:12 AM
Aussieflyer Offline
Threads: 17
Likes Received: 5 in 1 posts
RE: Tubeless tires
You might consider using the Outex tubeless conversion kit. I used it and can say from experience that it works as advertised, no leaks. I refitted the stock D205 tubeless tyres to the spoked wheels after the conversion and it works great.
08-03-2017, 04:02 PM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
RE: Tubeless tires
It may be my imagination or failing memory, but I recall reading that tube rims and tubeless rims have different bead properties (i.e. differently angled beads). And that tubeless rims had extra bumps in the bead area to keep a tubeless tire's bead from moving inward.
08-03-2017, 08:02 PM
  Tires ~ Converting tube to tubeless type. 17-CB-002 30 2,356 05-14-2026, 05:50 AM
Last Post: Kikemon
  120-80/18 tubeless endure tire...anyone? Ferrealls_imp 2 399 06-25-2015, 02:20 AM
Last Post: lemontree_imp
