Crank Case Cover removal?
Nortoon_imp Offline
Threads: 28
RE: Crank Case Cover removal?
(04-11-2017, 10:56 PM)PowerDubs_imp Wrote: Guys- RTFM!!
There is no gasket on our bikes- just sealant.
Put the bike on the center stand, drain the oil, remove the side cover, clean the mating surfaces, apply new sealant as shown in the manual (some of it goes on both sides, but only in certain spots), reinstall side cover, refill oil. Done.
Do not just guess at the bolt tightness as everyone will overtighten that way. If you don't have a tq wrench, you should not be working on a motorcycle / car.
Men don't read manuals.
Until we screw things up.
ROFL
04-12-2017, 01:17 AM
Rocky_imp Offline
Threads: 26
ROFL
ROFL
ROFL Thumbs Up Thumbs Up
04-12-2017, 01:24 AM
jimgl353_imp Offline
Threads: 4
probably shouldn't work on this Honda without a shop manual sounds like to me. never had a manual for the gsxr. guess i just got lucky.
dubs, if you would be so kind as to post from the manual where the sealant goes and doesn't go, I'm sure there would be many appreciative.
that said, I do get a chuckle at folks who talk about gaskets moving, folding, shifting, etc. because I have always put the bolts in whatever part it was with grease and then put the gasket on the part with the bolts to line it up and hold it in place.
04-12-2017, 03:36 AM
PowerDubs_imp Offline
Threads: 125
Yup- I'll snap Pics when I am done working.
04-12-2017, 08:12 AM
Nortoon_imp Offline
Threads: 28
(04-12-2017, 03:36 AM)jimgl353_imp Wrote: probably shouldn't work on this Honda without a shop manual sounds like to me. never had a manual for the gsxr. guess i just got lucky.
I learn something new every day. Thumbs Up
04-12-2017, 12:01 PM
jimgl3_imp Offline
Threads: 27
hang out at some club racing events sometime. you can learn a lot real fast. once saw a dude tear his forks down between races. I was like dang!
another really good example is the leaky cover I mentioned... another racer noticed the toe of my boot was shiney. He said you've got an oil leak. I asked why he would say that. He said the toe of your boot is shiney. it's got oil on it. He was right.
04-12-2017, 01:11 PM
Threads: 125
MODERATOR'S NOTE
Apologies both to PowerDubs and jimgl353, but I have had to remove these images as, so far as I understand the law, publishing them here breaches copyright and may expose our esteemed form owner to potential grief. If that's wrong, I'll certainly not stand in the way of their republication.
Cormanus
04-12-2017, 11:27 PM
Carguy1959_imp Offline
Threads: 8
The left side is the stator cover. I had to replace mine after I wrecked it. No gasket and if I remember there was little to no oil in it without draining oil. The hardest part was the magnets. Once you remove the bolts, the cover will appear to be stuck. It is the magnets hold it together. No manual required...
04-13-2017, 08:28 AM
motoWest_imp Offline
Threads: 5
I know this thread is old, but I thought I would chime in with my experience. To make a long story short, I was unable to remove my cover. I drained the oil, removed all the bolts, got a rag and mallet and . . . . the dang thing wouldn't come off! I'm not sure if someone had removed it before me and applied a super gasket of some sort, but I was in my garage for two hours tapping and pulling and cursing.
In the end, I had to refill the bike with oil, apply some JB Weld to the hole in the stator cover (side-swiped in traffic, that's another story) and take it to the shop with my tail between my legs.
On the plus side, because I provided all the parts, the shop bill was only $90. In hindsight, I would've saved myself a lot of grief had I taken it there to begin with.
02-01-2020, 01:29 PM
Houtman_imp Offline
Threads: 115
Well, that is how we all learn ; some jobs are easy and other times it can be a pain. It is like having kids : they can be wonderful sometimes and other times a pain in the neck.
02-01-2020, 10:21 PM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 527 08-20-2025, 06:25 AM
  Anyone recommend s a top case for the 13' OEM rear Carrier? iamlegend21087_imp 14 1,181 06-21-2023, 08:51 PM
Last Post: Tbhart89_imp
  Accessory Removal Wagonpeddler_imp 13 997 03-22-2022, 05:22 AM
Last Post: Wagonpeddler_imp
  Honda top case install Jonnyteabag_imp 11 918 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  Givi SR1118 Top Case Rack active1951_imp 4 500 06-28-2021, 07:08 AM
Last Post: Tom_imp
  Apache 4800 top box. (HF/Pelican case) mvk24_imp 12 1,016 04-16-2021, 04:01 AM
  Givi Side Case Racks...Do they exist? cbolling_imp 21 1,271 08-28-2020, 08:34 PM
  Case paint - need a suggestion to match stock skidmarkart_imp 15 858 03-16-2020, 08:20 PM
Last Post: FLYTYM_imp
  Stripping black finish off of 2017 engine case and cylinders Greaseball_imp 9 803 09-12-2019, 09:59 AM
  iPhone anti-glare case (or alternative ideas) emptysea 9 828 08-05-2019, 08:10 AM
