Likes Received: 581 in 317 posts
Likes Given: 980
(11-20-2018, 12:29 PM)The ferret_imp Wrote: Lol no but laying it down on the right hand side and crushing those 3 mufflers might prove to be expensive. I imagine an oem replacement set of those would be more than a few grand.
Minimum$::
https://www.britishbikebits.com/silencer...ricane-x75 +
https://www.britishbikebits.com/front-ex...-hurricane
Likes Given: 980
(11-20-2018, 01:09 PM)peterbaron_imp Wrote: error
I don't understand, didn't you just post this link?
Indeed, yes. In any case, these would definitely see earth quickly.
Likes Received: 599 in 266 posts
Likes Given: 774
Reproduction pipes are one thing, oem or a set of original equipment pipes would be something else I would assume. Maybe unobtainium.
Ah well, PB did a fine job. Hey! The claim on the link says they are Made In England.
Likes Given: 980
(11-20-2018, 01:21 PM)GoldOxide_imp Wrote: (11-20-2018, 01:09 PM)peterbaron_imp Wrote: error
yes , I did and corrected due to misspell
Threads: 14
Ok thanks everyone. I take away that the boxer layout is not a big deal.
Threads: 129
Depends on who you ask. Lots of BMW aficionados will defend the design religiously, and others will be indifferent. It's no different from fans of other brands. Personally, I don't view the boxer layout as a significant feature or must-have. As I suggested earlier, try one before you swallow the Kool-Aid. You may find it's not for you.
Threads: 43
As other's have said, no big deal if you lay it over. I owned a 1200GS I bought used and it had some nice little valve cover covers. When I went to check my valves on that bike, I pulled the covers off the valve covers and found some nice little scratches hiding under there. The rest of the bike, assuming no parts had been replaced, were unscathed. It was obviously a very low or no speed tip, so likely no other damage was done. There in lies an advantage of the boxer design. It often protects the rest of the bike from further damage since those cylinder heads allow the bike to rest and something close to a 45 degree angle. This also makes it much easier to pick back up.
This orientation also lowers the COG of the bike making it handle better and easier to ride at slow speeds.
One disadvantage, to my ear anyway, is the exhaust note. I always thought it sounded a bit "flatulant" and agricultural. Some find it quirky and enjoyable in it's own way. They aren't wrong. I've always admired the sound of a nice, prominent fart!
