The BT54R front didn't last long
(05-10-2021, 08:56 AM)Whoops_imp Wrote:
(05-09-2021, 09:48 PM)Rocky_imp Wrote:
(05-09-2021, 09:21 PM)The ferret_imp Wrote: The oe Bridgestone front tire didnt have much meat on it to begin with, I think 4/32 or something like that. Although I must say most people on this forum reported getting more than 2500 miles out of them.
Ferret is correct. It seems the front tire from the factory is a "good enough" item with not much tread. Mine was toast by 3000 miles and wouldn't pass the mandatory vehicle inspection we have here. I was shocked at the short life until I learned about the so-so factory tire here on the forum.
Well that's discouraging as I am awaiting delivery of a set. Sad
If you bought them aftermarket the fronts will probably have more meat on them.
This is how it works for a manufacturer:
Honda: Dear Bridgestone we will buy 250,000 tires from if you can deliver them for $50.00 each.
Bridgestone: Dear Honda we can do that, but we will have to reduce the tread depth, otherwise they will be just like the ones we sell after market.
Honda: Dear Bridgestone, so they will look the same, perform the same, only won't last as long?
Bridgestone: Dear Honda, that is correct.
Honda: Dear Bridgestone.... ok, we will take them.
My original CB1100 OEM BT54s had over 17000 kms and were still going strong. However, the rear was definitely stronger looking than the front - which is absolutely unusual.
Mr. Gold, reading that (17000km), I'm simply amazed. You must have waaay better roads up there than we do here in southern California!
Based on many of your other California colleagues, that could be right and despite the extreme seasons our roads up here are exposed to.
The BT-45 was OEM , right? From my experience I have NEVER gotten over 5k miles from OEM tires (off the showroom at least). Ever. Nature of the beast. Just burn them up and by a different set.
(05-11-2021, 02:46 AM)Rox_imp Wrote: The BT-45 was OEM , right? From my experience I have NEVER gotten over 5k miles from OEM tires (off the showroom at least). Ever. Nature of the beast. Just burn them up and by a different set.
BT-54. I'd like it if it lasted longer. Not a lot of choices if one wants to stick to stock tire size! Metzler -08 next for me I think.
If the same model of tire on the same bike can get anywhere between 2500 and 10,000 miles, it's probably not the tire. It's the riding style, tire pressure maintenance, and road conditions.
Several years ago, when there were complaints of GL1800 front tires wearing quickly and unevenly with resulting handling complaints, Honda invited a group of local GWRRA members to their Torrance facility for free oil/filter and safety inspections. They asked the GL owners what they set the tire pressures at and when they last checked them.
During the safety inspection, tire pressures were recorded and lo and behold, most were well under pressure, some into the teens. So much for keeping up on tire pressures.
Most of the tires were worn way more on the left side, which had been attributed to the crown in the road. That may be a minor cause, but the major cause is by wear when leaned over in left hand turns, regardless of what kind of bike or tire.
When you take a left hand corner, the arc you take is generally broader, wider, and you have a wider field of vision. You are going faster, with more load on the tire. On right handers, the arc is tighter, maybe less vision, and going slower. Canyon riders live for the left hand sweepers.
Tires never wear out on the right side first - except in LHD countries. Maybe we can swap used tires with LHD countries.Smile
One last thing about OEM tires. The tires Honda has as OEM, depending on application, are spec'd from the manufacturer as having the tightest tolerances, such as run-out. Those batches are selected for Honda (and the other manufacturers) and for their parts stock, with the rest going to the aftermarket. Not to say the aftermarket tire is any worse, but not ruling that out either. Going back to the GL1800s, some customers who bought an aftermarket tire of the same brand/model (and other brands) and had complaints, had OEM tires put on to rectify the complaint.
I like that technical explanation, pd.
Sounds very logical and scientifically proven.
Thanks for sharing.
I did keep the recommended pressure in my original CB1100 OEM tires. There was no sidewall cracking, but the front tire may had started to micro crack in the meager thread. In addition, I believe overall the tires were "harder". One thing for sure: In the warming spring time (e.g. March, April warm days) I noticed the rear tire would precipitate a sort of "black goo". So I knew the tire was going through some sort of aging process.
I never treated my tires with any aftermarket bling bling crap.
(05-11-2021, 04:41 AM)pekingduck_imp Wrote: If the same model of tire on the same bike can get anywhere between 2500 and 10,000 miles, it's probably not the tire. It's the riding style, tire pressure maintenance, and road conditions.
That's interesting because years of riding behind people has convinced me riders like to take right hand curves more than left hand curves. ( when taken properly the arcs should be identical only reversed). When I question riders about this they invariably tell me they are uncomfortable being out by the edge of the road by the white edge line looking left. I take lefts and rights equally well, and at rallies find myself running up on the back of people in left hand curves because I am entering them and exiting them faster.
Line selection is everything in going quickly, smoothly.
  Winter thread...how long? pdedse 19 1,353 01-18-2026, 09:00 AM
Last Post: Ollie
  Long Ranger SportsterDoc 2 328 01-10-2024, 10:17 AM
  How long will a CB engine last? the Ferret 63 5,219 05-22-2023, 02:14 AM
Last Post: DaSwami_imp
  Been a long time. SCCBrider_imp 4 414 07-03-2022, 02:35 AM
Last Post: SCCBrider_imp
  How long do you plan on keeping your CB? the Ferret 84 6,682 12-16-2020, 08:29 AM
  Tips for a long vacation out-of-town andyferd_imp 13 1,099 07-24-2020, 06:05 AM
  Why the CB1100 didn't take off... Beerman_imp 47 3,311 03-20-2020, 07:22 PM
  How long has your CB sat the Ferret 80 5,993 03-14-2019, 03:04 AM
  How Long Have You Waited For An Item From Japan? HeavyMetalMech_imp 18 1,241 11-10-2018, 12:36 AM
Last Post: Nortoon_imp
  The long goodbye use2b_imp 6 552 08-29-2018, 09:39 AM
Last Post: rboe
