How many extra watts of accessories can the CB1100 handle?
If you are not using heated grips, there should be plenty of headroom for small stuff (assuming it's connected in the right places). They built the charging system with the grips in mind.
(05-23-2021, 07:02 AM)j3gq_imp Wrote: The question needs to be seen from a few different angles.
1) CB harness(es) -> can burn through
if you connect to an existing CB wire or harness (in the wrong spot), the risk is to melt that wire, can be a tricky repair; to avoid it you need to know or measure every piece of wire between the new accessory and the battery; a better solution, install a large enough wire / cable straight from the battery to the new accessory. PS: This is true despite the fact that every M/C has fuses installed.
2) alternator -> cannot break
if it doesn't produce enough juice, the extra Amps are drawn from the battery - if and when this happens depends on alternator size, total power draw, how often the new accessories are turned on etc. and last not least engine rpm.
3) battery -> might discharge, cannot break
this can be easily measured with a little Amp meter, temporarily installed (in sight somewhere) in the dash, best use digital.
Another solution, buy and install one of the available LiP phone rechangers. They come in many sizes and capacity and can power anything straight, with 5V or 12 V, without connecting to your CB's systems. I have one in the garage, which would re-juice my phone 10 times without going empty, and is barely larger than an Iphone. Unlike the Li-Ion batteries, LiP do not pose a fire hazard, fit under your seat, and can recharge while you eat a Pizza. Careful so, they don't like too much engine heat.
If you don't like that idea, here is a rule of thumb for your electrical system's capacity. All standard equipment (factory installed equipment) turned on, and the engine running at more than 1800 rpms (cont.), the alternator is dimension-ed to provide 120% of the total power draw, and keep the voltage in the system high enough to charge (a standard) battery up to full.
Hope this helps a little.
This is the purpose of fuses. To protect harness wires and equipment.
When a properly-sized fuse opens, it is telling the owner something is wrong with the circuit (e.g. overloaded).
Correct, that is the theory. But unfortunately it happens (in all sort of machines and machinery) whenever very small wire gauge is used. Is it, because the designers still live in a world where only 1A, 2A and 10A fuses exist, is it for other reasons ... believe me and do yourself a favor : do not trust that the fuse always goes first. It does not.
That is why I was careful to quote, " ... properly-sized fuse ... ".
Good design requires it. A formally reviewed design will not permit an oversized fuse on small gauge wire.
If somebody wishes to put in an incorrectly-sized fuse after the fact, well then that is a different issue and small gauge wires may suffer.
  Stock handle bar specs mvk24_imp 6 607 07-06-2023, 09:22 AM
  Accessories & Spares in Covid times j3gq_imp 4 409 11-01-2021, 05:07 AM
Last Post: rboe
  Ordering Accessories MrJayGLA_imp 8 597 07-25-2018, 07:05 AM
Last Post: SportsterDoc
  Accessories/Parts/Vendors ETC. el duque_imp 9 581 02-18-2018, 08:35 AM
  Handle bar diameter jdvalero_imp 2 285 10-25-2017, 07:48 AM
Last Post: flynrider
  How Are New Bikes Handle Bars Positioned Aka Tsubasa_imp 19 1,281 05-14-2017, 10:24 AM
Last Post: BestStandard_imp
  Sold the CB, Accessories for sale tomas_imp 7 721 03-14-2017, 08:18 AM
Last Post: tomas_imp
  Traded HP for Watts CIP57_imp 11 812 10-01-2016, 10:45 PM
Last Post: CIP57_imp
  Best price on Genuine Honda Accessories TCBronson_imp 2 303 09-23-2016, 05:01 AM
Last Post: TCBronson_imp
  Accessories shop in SanFrancisco JustCruising_imp 4 353 06-10-2016, 01:59 AM
Last Post: Rocky_imp
