8000 mi service
I'd seriously reconsider the advice that they gave you. It doesn't seem like a judgement call to me as it makes no engineering sense. When the clearances tighten up (become less) with wear, if anything, they are going to make *less* noise, not more..
(edit: putting off the adjustment is a judgement call, but relying on ticking sounds to indicate that adjustment is needed is not a judgement call, it's wrong..)
Also, all engines are different with different characteristics. My CBR250 (and now I hear, also the CB500s) spec'd valve adjustments at 600 miles :-b. When I checked mine at around 600, 3 of the 4 were under specification. Happily, the next valve check on those is not until 16,000 miles.. so I'm set on that for a while :-)
Wow...Honda says valve checks at the 600 mile service for these new 500s??? What ever happened to hydraulic lifters? Aren't they auto-adjusting through the life of the motor?
(08-02-2013, 11:02 AM)Jim21680_imp Wrote: Wow...Honda says valve checks at the 600 mile service for these new 500s??? What ever happened to hydraulic lifters? Aren't they auto-adjusting through the life of the motor?
I've been reading notes from pissed off new 500 owners when they find out *after* buying the bike...
I miss the hydraulic lifters on my long gone 750 Nighthawk and 1100 Shadow for sure...
The first valve check for the CB500 is at 600 miles, but the second one isn't needed until 16,000 miles, and after that they should be checked every 8000 miles. So Honda is just moving the first scheduled valve check up earlier, overall it still comes out to a valve check every 8000 miles.
if you call the life of the adjusters the same thing as the life of the motor, yes.
some pushrod, lower rpm motors have hydraulic lifters. The ohc were hydraulic tappet adjusters, which are different and the engines could spin higher but don't seem to be possible with cam-bucket-shim type valves.
(08-03-2013, 05:39 AM)Yoyodyne_imp Wrote: The first valve check for the CB500 is at 600 miles, but the second one isn't needed until 16,000 miles, and after that they should be checked every 8000 miles. So Honda is just moving the first scheduled valve check up earlier, overall it still comes out to a valve check every 8000 miles.
for some reason that makes perfect sense to me and explains everything.
Apparently the CB500's power plant is the first multi-cylinder engine that Honda has built outside of Japan (it's made in Thailand), so that may be why they're being extra conservative on the initial service requirement.
(08-03-2013, 09:39 AM)Yoyodyne_imp Wrote: Apparently the CB500's power plant is the first multi-cylinder engine that Honda has built outside of Japan (it's made in Thailand), so that may be why they're being extra conservative on the initial service requirement.
Curious, I had a look at some pictures of the 500's valve gear. It's similar to the CBR250's in that it's not a 'cam over bucket' arrangement. There are more pieces involved. The cam doesn't bear down on the valve, instead it pushes on a follower and the follower spreads out to 2 fingers to open 2 valves of a cylinder. Perhaps this 'extra' parts count along with the limits of manufacturing tolerances means that some 'early' wear in can occur and needs to be checked. Significant wearing sure happened on my 250, whereas I read of one case in which someone checked theirs at 600 miles and found that all of them were in spec (lucky devil..).
While I could manage to get the head cover off and measure my valves, it was clear that I was not equipped to carry out the surgery required to change the shims (it's *really* tight in there, the frame gets in the way of everything)... paid the $200 for the dealer to set the valves (not a 600 mile service, *just* the valves)..
  Service manual Billie_imp 32 2,634 11-27-2025, 06:35 AM
Last Post: TheLegend
  How To do your own 600 mile service the Ferret 163 9,062 08-10-2023, 07:42 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 519 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,089 04-23-2023, 01:35 AM
  Service and Repair Manual alexzanutto_imp 5 591 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Factory Service Manual Download ??? markT_imp 24 1,766 10-14-2021, 09:30 AM
Last Post: furious_blue_imp
  Service indicator - unleashed j3gq_imp 6 567 07-27-2021, 03:12 AM
  Free Honda SERVICE Manuals dan88_imp 9 792 03-30-2021, 08:18 PM
Last Post: Enzofour_imp
  DLX is back from service LongRanger_imp 18 1,156 01-14-2021, 08:00 AM
  First Service larryblag_imp 46 2,712 09-18-2020, 09:11 PM
Last Post: spechg
