Can't get speedometer working after accident
(04-25-2014, 07:28 AM)lccb1100a_imp Wrote:
(04-25-2014, 05:18 AM)dBuster_imp Wrote: could it be a "limp mode" or something like that with the ECU???
It goes into limp mode because the speedo isn't turning. That's not the problem. The problem is why the speedo isn't turning.
(04-25-2014, 07:20 AM)Deanohh_imp Wrote: Both the meter and ecu get a signal from one wire coming out of the abs unit. I think its pink and blue. If no signal or bad signal you'll go into limp mode. Check for continuity this wire.
The mechanic is saying this signal is good. He's baffled.
if its a good signal in the wire that comes out of the brake box and to the Speedo and ecu, then it would have to work..... Any error codes?
Not super knowledgeable in this field, but trying to think in terms analogous to what I know.
Certainly the ECU is not "reading" the speedo itself. Am I correct in thinking this is a digital speedo, and not cable driven?
Could you perhaps use a known good CB1100 and probe it's wiring looking for where the two are different?
Check the tip over sensor. When the bike is laid over the tip sensor kicks in. I saw in my 2014 shop manual it has 2 I think. But there under the seat one could be bad or needs to be reset. Most of the time cutting key on and back off resets it.
Michael
The speedo is analog. Whether it's being driven by a digital signal is another question. He did say after I mentioned the pink blue wire that he had not traced the wire all the way back because it's buried and he'd have to take the whole center of the bike apart. He said that the signal was getting to the abs box, and the meter was fine, but from what you are saying even if this signal is fine the signal to the ECU may not be. But he said it's not throwing any error codes saying the abs is bad. Wouldn't it be saying this if the cable was bad?
(04-25-2014, 09:30 AM)Ridem32_imp Wrote: Check the tip over sensor. When the bike is laid over the tip sensor kicks in. I saw in my 2014 shop manual it has 2 I think. But there under the seat one could be bad or needs to be reset. Most of the time cutting key on and back off resets it.
Michael
I will have him do that.
Whoever gets this right wins my "Hero of the day" award. I'm not quite sure what that is yet, but I'll think of something.
I think Deanohh's on the right track. The symptom you're getting has been replicated by people disconnecting the speed sensor wire at the back of the bike. The Speedo gets no signal and the ECU doesn't detect speed input and goes into limp mode.
I think your mech's basic issue is going to be finding where that signal is going bad (which is a little more complicated on ABS bikes). At this point, you can be fairly confident that neither the speedo, nor the ECU is seeing a valid speed signal from the rear sensor. Time to pull the shop manual and start tracing the path of the signal.
This guy is wasting your time and money. Get it to somebody that knows what they are doing if you want it fixed.
(04-25-2014, 04:13 AM)lccb1100a_imp Wrote:
(04-25-2014, 04:04 AM)HikerToo_imp Wrote: What happen by BTW?
Back in January we had an unusually warm day, and I took it out. Going around a turn I lost traction because I hit the throttle too hard. I tried to get it back up, but I couldn't and I wound up going down and slamming into the curb head first. Luckily the curb was at a 45 degree angle and not 90 degrees or it would have been much worse for the bike and for me. I was just bruised, but the whole front of the bike was smashed in. I waited about 2 months before I even called to get it repaired, and now it's been about 5 weeks and it's still not done. It's rideable, but no speedo, and it won't go over 6000 RPM, so that's no fun.
The mechanic said the needle does sweep when powered up. Meter is brand new and sensor is working fine. Signal is getting into the antilock brake box. Ugh!
(04-25-2014, 02:05 AM)TINK_imp Wrote: The speedo uses the rear wheel sensor, your shop guy will need to troubleshoot the meter and the rear wheel sensor connections.
Q: When you turn on the key does the speedo needle sweep? If not start looking for bad connections at the meter.
Back in January we had an unusually warm day, and I took it out. Going around a turn I lost traction because I hit the throttle too hard. .
Another refutation of the "underpowered" nature of the CB1100.
Agreed. I've had two run-ins with the low, low power of this bike. I felt the back slip out a bit from under me once (but caught it) and another time I accidentally downshifted an extra gear (to second) when attempting to speed up to pass a car and I swear the bike lifted the wheel a bit.
Just wondering lccb1100a why you decided not to make an insurance claim on the wreck. If you don't care to answer, of course please ignore the question.
Michael
Michael
Whoever gets this right wins my "Hero of the day" award. I'm not quite sure what that is yet, but I'll think of something. I am with Ridem32 on that one.
  ABS , speedometer and battery Walter 10 793 05-02-2026, 01:29 AM
Last Post: Walter
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,724 03-06-2026, 04:31 AM
  Basic Speedometer Troubleshooting George050994_imp 5 483 07-03-2023, 03:30 PM
Last Post: George050994_imp
  Clutch Not Working Henrik_imp 7 625 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 557 12-08-2022, 09:24 PM
Last Post: leung_imp
  New Speedometer Not Working wanobiben_imp 15 1,131 04-13-2022, 01:38 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,240 03-31-2022, 04:03 AM
  Indicators not working AlexCB_imp 8 597 02-28-2021, 03:22 AM
  Speedometer and Odometer aren't working caleb_dud_imp 13 1,007 01-07-2021, 02:59 AM
Last Post: Gover_imp
  One horn not working peterbaron 2 270 06-11-2020, 11:04 AM
Last Post: LakeWylieJoe_imp
