What voltage direct from Alternator
Hi, thanks for all the input, I've done some more checks and results as follows
Alternator yellow wires, all continuity tests as per book
Voltage from yellow wires to earth all 14 to 15 volts AC
Voltage from yellow wires to each other, only about 7 or 8 volts AC
Red/White from harness to Green from harness into Reg/rec 12.9 volts, full battery voltage
With fused link removed and ammeter fused in its place I get negative 8 amps when ignition first switched on, when running the ammeter goes to zero or + 2 amps max
Looking at the head light when running there is a little brightening of the light as you go off tickover but then it goes back to how it was before starting the engine
Thanks again
  CB1100 Alternator postoak_imp 32 2,913 09-15-2018, 12:59 PM
Last Post: SportsterDoc
  Battery not Charging - High output Alternator? beardyweirdy@me.com_imp 12 1,000 01-03-2017, 08:30 AM
Last Post: AzBob_imp
