Who has replaced their chain?
(12-20-2014, 12:38 AM)sanoke_imp Wrote:
(12-19-2014, 05:47 PM)Pterodactyl_imp Wrote: I've put 29000m (47000kms) on the bike and the chain is still within limits and the sprockets good. I'm watching closely though.
Any sign of orange powder around any of the o-rings? Do you use any sort of lube or treatment on your chain? Thanks!
I use MOTUL chain cleaner and road bike chain lube. If I have been riding dirt, or for any other reason the chain is extra grotty, I will use blue kerosine and a stiff brush to clean the chain and then lube with MOTUL. I lube about every 1000kms, or as required. While touring I have often not cleaned the chain for intervals of 3000kms, just given it a squirt of lube. No orange powder.
Cheers Sounds like a winning combination. Thanks!
(12-20-2014, 08:16 AM)HikerToo_imp Wrote: Do most people buy Honda OEM sprockets and an aftermarket chain, any special one?
My CB11 doesn't need 'em yet, but when it does I'll go with a D.I.D sealed chain and JT steel sprockets. I've been using that combo on my other bikes for years (decades?) and I've never been disappointed.
I've never had an aftermarket chain last as well as an oem. Probably just me though.
6,700 miles on Eric's CB, yet to need adjustment.
LUB THAT CHAIN!
I religiously lub my chain every 500 miles.
I clean my chain completely with kerosene every other oil change.
I buy only the best DID available when I replace a chain.
I've gotten 80,000 miles + out of a DID chain, they are a good investment.
The trick to chain life is to keep those o-rings alive, regular lub will help them live a long and happy life.
TINK
(12-21-2014, 09:32 PM)Motogeezer1949_imp Wrote: I've never had an aftermarket chain last as well as an oem. Probably just me though.
I adjusted mine for the first time at 8400 miles ( barely needed adjustment) and then replaced the rear tire 500 miles later. Probably could have waited for the tire change and not messed with it earlier but felt guilty that I wasn't " working" on the bike.
(12-21-2014, 10:17 PM)TINK_imp Wrote: LUB THAT CHAIN!
TINK
That's impressive! What lube do you use?
You could mostly have gotten rust on ur chain and u can easily remove it by putting some oil on it
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,224 03-31-2022, 04:03 AM
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,007 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  Has anyone replaced their air cleaner? the Ferret 17 956 02-14-2019, 12:56 PM
  No start - Battery replaced - No start jerrycon_imp 20 1,455 07-16-2018, 01:28 PM
Last Post: SportsterDoc
  Has anyone replaced bearings in their front wheel on a 2014 CB1100 ? Searcher_imp 0 177 05-30-2017, 07:16 PM
Last Post: Searcher_imp
  Have you replaced your battery? dave 70 3,808 02-27-2017, 09:06 AM
Last Post: olekzap_imp
