08-19-2015, 06:22 AM
Inflation and higher quality materials (at least we can hope so) than batteries of the past.
Sent from an undisclosed location
New battery.
08-19-2015, 07:35 AM
Batteries like chains and tires really are better these days. Longer lasting and requiring less maintenance on each all add up to more expensive and a better value.
However IMO std spark plugs and air cleaners are no better than they were 30 years ago and still cost a boatload more.
08-19-2015, 07:10 PM
Well after the battery I have put 2 new tyres and some rear pads on yesterday. I decided to go with the Pirelli sport demons again and at $270 fitted I thought that was pretty good. I now have 37k kilometres on the clock. I washed down the chain and re-lubed it and it still looks like new. Flushed the old clutch fluid out and replaced as it was starting to look a bit grubby.Front brake pads still have a fair bit of life left in them. Off through the Bunya Mountains at the end of the month for an overnighter at Kingaroy with some other club members. Should be a good ride.
12-14-2015, 06:46 AM
(08-15-2015, 11:05 PM)sourdough44_imp Wrote: I've been going to the 'Battery Mart' after doing some research, check it out. The maker is 'deka' out of PA, a big player in power sport batteries. I took your advice, and ordered one of theirs to replace the original Yuasa that gave up this week. At about $67 delivered (which is supposed to be in two days) it sure seems worth a try.
12-14-2015, 10:28 AM
Earlier this year, I bought an AGM battery for my 2010 Can-Am Spyder RT. I bought it from a company called batterysharks.com and it was billed as a Yuasa replacement battery. It was really cheap cheap cheap. When I got it, I noticed it WAS NOT A YUASA. When I called the company to complain, they told me that their printed description meant to say it REPLACED a Yuasa AGM. Anyway, installed the battery and about three months later when going to the drug store, it failed to start for my ride home. It wouldn't take jump so the cells had shorted. THREE MONTHS. I ended up buying the real deal Yuasa and if anyone wants to cheap out, beware a company called batterysharks.com... in fact google them and see a long string of rip off reports. This is FYI.
12-14-2015, 11:01 AM
(08-15-2015, 07:18 AM)Tezza_imp Wrote: Well my original battery finally gave out yesterday after 5 years and 4 months. I think the cold weather of late helped in its demise. Not a bad effort considering my 4wd battery died after only 3 years. Now I just need 2 new tyres. I will probably go with the Pirelli sport demons again. Tezza, have a look at the Pirelli Angel GTs. 160 rear, but I have found them to be really good. Cheers
12-14-2015, 05:24 PM
(12-14-2015, 10:28 AM)wiredgeorge_imp Wrote: Earlier this year, I bought an AGM battery for my 2010 Can-Am Spyder RT. I bought it from a company called batterysharks.com and it was billed as a Yuasa replacement battery. It was really cheap cheap cheap. When I got it, I noticed it WAS NOT A YUASA. When I called the company to complain, they told me that their printed description meant to say it REPLACED a Yuasa AGM. Anyway, installed the battery and about three months later when going to the drug store, it failed to start for my ride home. It wouldn't take jump so the cells had shorted. THREE MONTHS. I ended up buying the real deal Yuasa and if anyone wants to cheap out, beware a company called batterysharks.com... in fact google them and see a long string of rip off reports. This is FYI. Kind of an ironic name for a company that hawks junk batteries. |
« Next Oldest | Next Newest »
| ABS , speedometer and battery | Walter | 10 | 772 |
05-02-2026, 01:29 AM Last Post: Walter |
| Yuasa Battery Life | dave | 28 | 2,475 |
04-01-2026, 04:44 AM Last Post: Tev62 |
| Rattle on right side exhaust / battery | CB1100i_imp | 4 | 655 |
04-18-2025, 02:48 AM Last Post: CB1100i_imp |
| Battery jumper | the Ferret | 14 | 1,032 |
10-28-2024, 10:58 PM Last Post: the Ferret |
| CB1100 SA-E 2017 Battery | Davidjill_imp | 1 | 272 |
08-01-2024, 02:33 AM Last Post: Gone in 60 |
| wonder battery | The Gecko_imp | 58 | 4,357 |
02-19-2024, 11:20 PM Last Post: mvk24_imp |
| Could old/low battery trigger misfire and engine light? | Motorsport3_imp | 13 | 1,208 |
12-17-2023, 08:41 AM Last Post: Jgarciajr40_imp |
| Replacement Battery | dave | 54 | 3,748 |
02-04-2023, 12:41 PM Last Post: GoldOxide_imp |
| Winter Battery Maintenance | Wagonpeddler_imp | 27 | 2,127 |
10-18-2022, 01:55 AM Last Post: GoldOxide_imp |
| dead battery | louied_imp | 62 | 4,151 |
10-16-2022, 03:48 AM Last Post: pdedse |
