Weird Suspension Design
(01-08-2016, 07:28 AM)Rboe_imp Wrote: I think this topic came up in a book on Guzzi's. It's a rather trick way to have a sophisticated suspension with one leg responsible for one behavior, the other leg for a different one.
Apparently, being off center and asymmetrical does not bother the front one wit as the triple tree and axle join the assembly as one and it acts that way. The need to have the fork be mirror matches for each other is just a bias we have in our heads.
It came up in the Guzzi book where one grade of oil was used in one fork, a different grade in the other.
These motorcycle people can be quite clever at times.
Sometimes, too clever by half, but that's another topic. Big Grin
Interesting. Before this, the only asymmetric forks I'd seen were the 80s Hondas with TRAC anti-dive that Joe mentioned above. Common sense would tell you that symmetry is a good thing in two parallel forks attached to the same axle, but I guess sometimes common sense is wrong Big Grin
I learned in my upper division classes; common sense will be your undoing. Dang.
"Economics" is the reason for the different spring lengths in the Deluxe/EX forks...
You will find that the Standard CB1100 uses the same length springs and spacers in both fork legs.
When Honda added weight to the Deluxe/EX design the cheapest way to compensate for the added weight was to beef up one of the two fork springs.
Hench the different length spring has very little to do with engineering.
Buell racing was one of the first to have different internals inside each the fork legs for compression and rebound functions.
(01-08-2016, 09:43 PM)TINK_imp Wrote: "Economics" is the reason for the different spring lengths in the Deluxe/EX forks...
After reading this thread I went to my 13/14 Honda service manual and I found the same info; standard has identical length springs while the deluxe has the different length springs.
I had no idea than any manufacturer was doing this. You learn something new every day Big Grin
I've learned to trust and appreciate Honda engineering. We have both the Honda Jet R&D and mfg facility here as well as the jet engine facility.
They know engineering. And accountants are not in control.
With my Ural a "one off" is a common occurrence, they just use whatever part is handy at the time.
One might think it's common sense but more like common assumption imo Wink
To add to my post above, I went back and looked at the fiche for the DLX. Sure enough it lists different part numbers for the collars. I can't believe no one else looked and called me on this Smile
Read in a moto mag awhile back its related to the increased weight on the DLX. Let's all take a deep breath. Big Grin
  Rear indicator design problem Mixagon_imp 5 482 06-19-2021, 04:23 AM
Last Post: Mixagon_imp
  Suspension Static Sag ozigoo 27 1,787 05-12-2021, 02:05 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 606 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  cb1100 motor design and explanation or video of its operation. Alfgaxatico_imp 4 399 11-22-2020, 01:15 PM
  Race Tech Gold Valves in stock suspension ozigoo 9 622 06-24-2020, 03:59 AM
  4 into one exhaust header design LakeWylieJoe_imp 19 1,195 01-09-2020, 07:46 PM
Last Post: alprider
  Stock Suspension Adjustment riggies_imp 28 1,931 10-16-2019, 02:08 PM
Last Post: jdvalero_imp
  Lower suspension apehair_imp 3 340 08-26-2019, 11:51 AM
  Suspension, have plan but input appreciated Banned_imp 74 3,933 04-21-2018, 01:11 AM
Last Post: Banned_imp
  weird turn signal lenses the Ferret 8 448 08-13-2017, 02:02 AM
