An oil thread that (Maybe) is different.
I always pre-fill the filter. It's not like you're going to run dry and break the oil film in the time it takes to fill from dry on first start, but why not help it out as much as possible.
Quail. Mate, your oil is eating up your motor. Do yourself a big, big favour; change the filter, put a banana in a food blender then add it to 4 litres of oil. Fill the bike with the aforementioned oil-banana mix. Then, under an assumed name, and from across the state border, sell the flamin' bike .
Did Ptero just give the formula for Hubris oil???
I always pre-fill my filter too.
I would post a reply but you said you didn't want to talk about it. Tongue
(06-13-2016, 04:46 PM)kmoney_imp Wrote: I always pre-fill the filter. It's not like you're going to run dry and break the oil film in the time it takes to fill from dry on first start, but why not help it out as much as possible.
I actually had not done that since 1970's when I used to work on my Ford Galaxie 500, a 352 V8 four-door. I learned that from a Clymer manual, I think. So it occurred to me to start doing it again with motorcycles just last week.
Very surprising just how much oil is absorbed into that small motorcycle filter. Can't really "fill" it because it's installed horizontally but can get quite a bit in there, several ounces.
As you say, it fills very rapidly from the oil pump, but I figure the oil level will be more accurate after the first warmup and level check. Add less to top it off.
I notice some filters come with a layer of grease on the O-ring, some you need to coat with oil.
We have recycling facilities here, they take the filters and waste oil so don't need to throw it in a fire, lol.
Used to burn our trash back on the farm in the 1960's though. I guess the fire thing would be good, it would burn off all the old oil.
(06-13-2016, 09:22 PM)Lord Popgun_imp Wrote: Did Ptero just give the formula for Hubris oil???
Well that information is classified as "Commercial - FMEO". However let me say, and let's keep this just between you, me and the fence post Pops, that Hubris Omni Grade is, despite being a full synthetic, nutritional and low-GI. In keeping with recent customer demands it is now guaranteed gluten free. No need for the motorcycle equivalent of coprophilia when using Hubris Omni Grade (CB1100 Blend).
And for information, all Honda, and other manufacturers, service manuals require the engine, and presumably the oil contained therein, to be warm on commencing an oil change. But what would those turkeys know; they make 'em, we break 'em Smile.
Cheers The oil was warm when I commenced my oil changes. I just let it settle for a while, like overnight. Sort of like letting a fine wine breathe. Then again, ambient temperature here in my garage is already warm. I order antipasto and espresso prior to changing my oil, too, to set the mood, of course.
I am pretty sure there is going to be more oil in the sump to be drained after letting it settle overnight than, say after a couple of hours. It doesn't retreat back into the engine when it gets cold.
Hey, we found a new Web debate. I searched on hot vs. cold drain and voila! Tons of argumentation about it.
So, since the engine is hot when we turn it off, the longer we leave it alone, the more oil can drain from the upper portions as well as the oil cooler. If we are not in a huge hurry, we just let it drain from the sump for a longer period of time until it just drips very slowly.
I know on my last change, I had to put about four quarts in total, and it was exactly on the upper fill level mark (properly measured, yes) when I started. I also filled the filter. I think the oil cooler drained at least partially by allowing it to sit overnight.
Some claim warm oil will carry more of the suspended particles you want to get rid of, but in truth that is the filter's job and there is always something on the bottom of the sump that can't be drained no matter when we drain the oil, red-hot or room temperature.
^^^^. Hey, you are good. You should write a Service Manual.
Word of the day: Viscosity.
Blimey! This has got me thinking. No more figuring how to change the oil quickly. Henceforth, I'll come in from a ride, decant a bottle of shiraz, get the brie, blue and other cheeses (maybe some antipasto too) from the fridge and take a shower. By then the bike should be cool enough to remove the drain plug which I will do.
While I drink the red, eat the cheese and antipasto and then sleep it all off, the oil can drain away.
Thank you. Changing oil may just have become slightly more of a pleasure than a pain.
And, respectfully, may I suggest that, rather than discussing the temperature of the oil as it drains, we have a thread on menus to drain sumps by? I'm hoping it will be less inflammatory.
And, respectfully, may I suggest that, rather than discussing the temperature of the oil as it drains, we have a thread on menus to drain sumps by? I'm hoping it will be less inflammatory. A fine Camembert is more to my liking. Pouilly Fuisse, perchance, to accompany escargot, followed by a perfectly steamed halibut steak with naught but lemon, butter, and salt. Asparagus spears, steamed to a turn, with Hollandaise, freshly-blended.
Wash it down with a pint of Fat Tire Ale, followed by Turkish coffee, a trifle or two, and a snifter of VSOP to cleanse the palate.
By that time, the oil has cooled to the ideal temperature for drainage, exactly 35 degrees C. And the owner has passed out.
  Another tire thread: Dunlop TT900GP misterprofessionality 1 346 10-08-2025, 11:57 AM
  Another shock thread, but SHOWA JLEECB 17 1,585 02-09-2025, 11:23 PM
  another idle thread Tom_imp 11 939 11-20-2023, 01:30 PM
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 11,962 12-27-2022, 08:35 AM
   Dutch's High idle thread DutchRutter 17 1,503 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another Oil Thread dave 11 915 09-15-2022, 09:13 AM
  new tyres' thread j3gq_imp 0 189 01-03-2022, 10:52 PM
Last Post: j3gq_imp
  another tire thread NickLHG_imp 11 863 03-05-2021, 05:50 PM
  Yet another battery thread... PowerDubs_imp 32 2,035 06-18-2020, 07:15 AM
  A Different Kind Of Oil Thread 2017EX_imp 1 225 09-13-2019, 01:20 PM
Last Post: Stichill
