09-30-2016, 01:17 AM
would be interesting to see what the ST batt reads since it is fairly new. Bike doesn't have to have ign on I don't think.
New Battery Today
09-30-2016, 01:22 AM
Just depends on where you have the connection. On my CB I'm plugged into the headlight accessory connector so the ignition needs to be on. On my ST it does not as I have a Powerlet outlet wired directly to the battery.
On the CB I also have a battery tender cable like yours wired to the battery, but I keep the end behind the left side cover so only use it every now and then, mostly in the Winter.
09-30-2016, 02:16 AM
I just checked getting 13.0 and green light on CB, 12.9 and green light on ST
09-30-2016, 02:50 AM
I have an older analog test meter so I'm not how sure accurate it is. Here's my ST readings.
With ignition off: just under 14 volts Turn ignition on (headlights on): Monitor voltage for a couple of minutes: Holds steady at just over 12 Volts (A steady drop in voltage means bad battery capacity I think) Crank starter: Voltage holds steady at 10 Volts (a steady drop also means a bad battery). I think the battery is OK. The battery I have only has 120 CCA rating so maybe that is why it cranks a bit slow to my taste. The OEM battery has a CCA rating of 230 amps so I would think that would crank the engine over more quickly.
09-30-2016, 04:30 AM
(09-30-2016, 01:22 AM)Lord Popgun_imp Wrote: Just depends on where you have the connection. On my CB I'm plugged into the headlight accessory connector so the ignition needs to be on. On my ST it does not as I have a Powerlet outlet wired directly to the battery. If it's wired to anything other than the battery, you're going to get the flat 11.8ish volts that the rectifier puts out rather than the battery voltage. In other words, you're getting a false reading. If the battery reads 11.8 volts directly, it's close to dead (it's ~ 1/3 charged). The battery should read 12.7v when it's 100%.
09-30-2016, 04:34 AM
I agree. But its under load when using the accessory plug as the ignition is on and so are the lights, etc.
If you watch it close it will usually flash up 12.7 or. 8 then 11.8 as the load kicks in, so to speak.
09-30-2016, 04:48 PM
(09-29-2016, 02:52 PM)kmoney_imp Wrote: Does the CB use an AGM battery from the factory? I always though it was a zero maintenance wet cell, but I never looked that close. My '13 had a Yuasa YTZ14S AGM battery. Best bet for a voltage test is directly on the battery terminals. A resting voltage test is a pretty good indicator of battery health, but not quite as thorough as a full load test. Expected voltage depends on the battery type. A conventional flooded cell battery should show around 12.5V. An AGM type should be around 13V. A Lithium Ion should show 13.5V or better. Test should be performed with the ignition off and after the bike has been off for awhile.
10-01-2016, 12:39 AM
(09-29-2016, 08:25 AM)Motogeezer1949_imp Wrote: My battery on the DLX died earlier this year and I replaced it with the one out of the '13 salvage I brought back from Ohio. Haven't given it another thought since. Jim, what model Moto battery is it? I'm having a hard time finding the right one on their website. They don't even list a 2014 CB1100 as being available.
10-01-2016, 11:11 AM
MBTX9U. They don't list the '14, but they're all the same.
(10-01-2016, 12:39 AM)ride4now_imp Wrote:(09-29-2016, 08:25 AM)Motogeezer1949_imp Wrote: My battery on the DLX died earlier this year and I replaced it with the one out of the '13 salvage I brought back from Ohio. Haven't given it another thought since. Jim, what model Moto battery is it? I'm having a hard time finding the right one on their website. They don't even list a 2014 CB1100 as being available.
11-13-2016, 01:03 AM
Well, my battery kicked it yesterday. A good thing that I never
got anywhere, because I might still be there. I guess being off the tender for the last few months along with inconsistent riding did it in.
« Next Oldest | Next Newest »
| ABS , speedometer and battery | Walter | 10 | 791 |
05-02-2026, 01:29 AM Last Post: Walter |
| Yuasa Battery Life | dave | 28 | 2,519 |
04-01-2026, 04:44 AM Last Post: Tev62 |
| Rattle on right side exhaust / battery | CB1100i_imp | 4 | 677 |
04-18-2025, 02:48 AM Last Post: CB1100i_imp |
| Battery jumper | the Ferret | 14 | 1,083 |
10-28-2024, 10:58 PM Last Post: the Ferret |
| CB1100 SA-E 2017 Battery | Davidjill_imp | 1 | 277 |
08-01-2024, 02:33 AM Last Post: Gone in 60 |
| wonder battery | The Gecko_imp | 58 | 4,545 |
02-19-2024, 11:20 PM Last Post: mvk24_imp |
| Could old/low battery trigger misfire and engine light? | Motorsport3_imp | 13 | 1,227 |
12-17-2023, 08:41 AM Last Post: Jgarciajr40_imp |
| Replacement Battery | dave | 54 | 3,967 |
02-04-2023, 12:41 PM Last Post: GoldOxide_imp |
| Winter Battery Maintenance | Wagonpeddler_imp | 27 | 2,162 |
10-18-2022, 01:55 AM Last Post: GoldOxide_imp |
| dead battery | louied_imp | 62 | 4,242 |
10-16-2022, 03:48 AM Last Post: pdedse |
